JohnJ
Strange Canon 100-400L Problem
Sat Apr 16, 2011 2:37 pm
I haven't seen an issue similar to this posted, and was wondering if anyone has experienced it. I was up at BOS on Thursday with my Canon 100-400L (on a 40D body), and for the very first set of shots the image in the lens shook rather vigorously. The effect was similar to the IS "shake" that some Canon lenses produce, but it was more pronounced and lasted a lot longer. It would clear up intermittently to allow me to take a shot, but ultimately ended up with the camera giving me an "error code 1". I reseated the lens, and while the error code cleared the intermittent shake continued. Turning the IS off or changing its mode had no effect on the problem.
When I got home I found the metal lens mounting ring on the camera was pretty dirty and cleaned it up. I'm not sure if the problem still exists or not; for the first use after I turn on the camera after it's been left alone for awhile the lens will give me a couple of quick jumps, then settle down to operate normally.
The lens is still under warranty (until July), but the camera is not. Do you think the problem was caused by the dirty mounting ring or is this something more serious? Doing a Google search on this problem doesn't yield any matches that sound like what I'm experiencing, so it doesn't look like a common problem.
John
Samuel32
RE: Strange Canon 100-400L Problem
Sat Apr 16, 2011 8:38 pm
If you've cleaned out the lens mount and contact points thoroughly and it still shows up I'd send it in.
You've guys got the best Canon service on the planet so I wouldn't think twice about sending it in, especially if its still under warrenty. Send it to the Canon Center in New Jersey (forgot exactly what the center is called). You guys are lucky to have such a great service in the US. It's a mob here in Switzerland. Warranty is pretty much useless here. They will always find a way to charge you.
Sam,
Fly-K
Sat Apr 16, 2011 11:06 pm
I've had a "shake problem" with the IS on a different Canon lens (17-55/2.8) that was similar to the one you describe. The IS had to replaced which wasn't cheap (the lens wasn't under warranty anymore). As the lens eventually had other issues which would have required another pricey repair, I eventually replaced it with a different one.
On my 100-400L the IS has worked well for 9 years now.
So I would recommend seeking Canon service's advice.
Once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been...
Moose135
Sat Apr 16, 2011 11:45 pm
John, if you are having any problems with it, especially since it is still under warranty, let Canon take a look at it. You can call their Factory Service Center in New Jersey to arrange shipment. Phone number is 732-521-7007 (I'm sure they have a toll-free, I just don't have it handy). A couple of weeks ago, I brought in my 5-year-old 28-200mm that wouldn't lock focus - since I was in NJ, I dropped it off on a Monday afternoon. Wednesday at 9am they called to say it was ready. Since it was long out of warranty, it cost about $100, but they replaced the AF motor and gave it a thorough checkout.
ckw
Sat Apr 16, 2011 11:46 pm
This is a problem with the IS module - not common, but not that unusual with the 100-400 (which has one of the earliest - possibly first - implementations of IS). Replacement is the only option.
Colin
Colin K. Work, Pixstel
JakTrax
Sun Apr 17, 2011 3:36 am
My first 100-400L (I was second time lucky with this lens) had a very similar problem with its IS, and I sought a replacement. Using mode 2 the IS would constantly jump and judder, so panning was pretty much out of the question.
Karl
n314as
Sun Apr 17, 2011 6:03 am
Folks, to be a good photographer, you do not need all this autofocus image stabilizing baloney. They add all those features and they are useless. Good pro level aviation photographers have never used any of that.
1. Pan an area to shoot the action shot (fly by or approach) about 30 degrees of shooting area.
2. Manually focus on that location and keep it there.
3. Now you are clear to shoot the plane as it goes by in that location and all you have to worry about is the width
of the plane.
4. Remember to shoot prop action at 1/250 or less speed.
Image stabilization is a gimmick that will add $200-$3000 per lens depending on which top level lens you buy.
It is not needed for aviation photography if you have the right touch. I have been doing this, even with L and older top level FD Canon lenses for over 35 years and usually never a problem. The results have been fine even in poster shots (slide and digital).
No signature
jrowson
Sun Apr 17, 2011 1:23 pm
I had a similar fault when I got my 100-400 back in 2004. It was 6 months old when the IS failed, doing a similar thing to what you have described. I sent it into Canon who replaced the IS free under the warranty. Put me off the lens a bit though, especially when a year or so later I had AF problems and bluriness appear on the left side. A costly out of warranty fix though this time. I eventually got rid of the lens in favour of a 70-200 + 1.4x combo which has been far more reliable.
James Rowson
timdegroot
Sun Apr 17, 2011 3:23 pm
Quoting n314as (Reply 6):
It helps though
Alderman Exit
JohnJ
Mon Apr 18, 2011 3:00 am
Thanks for the feedback. I'm going to do another outing with the lens to see if it's still giving me trouble - I suspect if the problem can't be reproduced I won't get far with the service folks. I also might try to pair it up with my old 300D to rule out problems on the camera end. We'll see how it goes. I guess I'm spoiled; my cheap Canon non-L 75-300mm has performed well since I bought it in 2003.
ckw
Mon Apr 18, 2011 11:21 pm
Of course you don't need them. Nor do you need computers, refrigerators or any one of a million technological developments. Frankly, anything other than an 8x10 view camera with glass plates is a gimmick.
Seriously, everyone would do well to look at the work of Charles E. Brown - fantastic photographer, and much of his work was done on 5x4 view cameras on sheet film.
But, I don't see this as a reason to ignore technology. AF and IS etc. without a doubt help get shots that would otherwise be impossible (for me at least). The problem is when you become dependent on the technology.
Colin
Chukcha
Tue Apr 19, 2011 12:43 am
Quoting ckw (Reply 10):
Reading glasses are also technology. Nothing wrong with being dependent on them, is there?
Some people have steady hands, some don't.
I met this photographer at an airshow, a young bloke who complained that he has very shaky hands and can't shoot without IS. Meanwhile he is a pretty successful aviation photographer, runs a business selling prints of military aviation; some of them are nothing short of stunning.
Without the technology however he wouldn't be able to pursue his passion.
n314as above has expressed his view on the subject. It works for him, and it is fine. Other people may have other opinions, and it is also fine.
I still remember the time when it was said that 'real photography' is done on film, and that 'real pro photographers' don't use all that digital 'baloney'. Wasn't that long ago, actually, within a decade.
Andrei
JohnJ
Tue Apr 19, 2011 2:17 am
Well, fir this particular problem it doesn't matter whether I need the IS or not... The lens came with it like it or not, it's apparently malfunctioning and causing problems whether or not it's switched on, moot point.
Silver1SWA
Crew
Tue Apr 19, 2011 4:36 am
I'm not really sure how your post is relevant.   Modern DSLRs and many high quality lenses come with autofocus and image stabilization. As far as I know, the 100-400L doesn't come with an option without IS, so if you want that lense (excellent lens), you get IS. In this particular case, the owner of the 100-400L is having a problem with his lens.
ckw
Tue Apr 19, 2011 8:03 am
Quoting Chukcha (Reply 11):
Well, as a glasses wearer, yes there is - though there is little I can do about it! They are a pain (I have to keep taking them on and off when shooting), and if I forgot them or break them it is extremely inconvenient. I can't get by without them, hence for me this dependence is a problem.
Note that I didn't say it was wrong to be dependant on the technology, but any dependency tends to be restricting in some way - if you can learn to work without it you may find you are more versatile, flexible and above all less vulnerable - anyone not been caught out by flat batteries? Technology can be enabling and should be embrassed as, if you like, an extension to your abilities. But it should not be used as a subsitute for aquiring a good basic skill set - like relying on Photoshop to fix dodgy exposures.
Colin
Chukcha
Tue Apr 19, 2011 2:40 pm
Quoting ckw (Reply 14):
Yes, but what if you were told, "Forget glasses, a good reader can go without"?
The example I brought up was case in point - the guy can't go without IS.
My point is - everyone can deside for himself to what extent to use technology. But in any case, it is great that it is available.
Dehowie
Wed Apr 20, 2011 7:38 am
LOL...gathering you have never used it so therefor how can you say its a bunch of baloney??????
Mmmm zone focusing died 15 years ago along with the art of manual focus...thank god.
Now its off to my "The Earth is flat" club meeting" guess i'll see you there....
2EOS1DX,EF14.2.8LII,17TS,85/1.2,16-35L,24-70LII,24L,70-200F2.8LII,100-400,300/400/500/800L
Users browsing this forum: JakTrax and 1 guest
