dumbell2424
Quick Question Regarding Location
Wed Apr 20, 2011 9:02 pm
Hey guys, recently got a photo accepted
Photo © Scott Butler
Since autofill wasn't available for AGS, I tried to best guess with other examples, so I put "Augusta - Bush Field (AGS / KAGS)"
Well, I just found a picture today
Photo © Jonathan Birdwell
that has it as "Augusta - Regional / Bush Field (AGS / KAGS)"
Since the full name of it is Augusta Regional Airport at Bush Field, I was wondering if I should send a correct info on my picture or if it's just fine as it is.
Scotty
coninpa
RE: Quick Question Regarding Location
Thu Apr 21, 2011 12:36 pm
Hi Scotty,
As it is a database with Keyword searches, it is always better to have the exact same name for airports. However, we observe variants when the auto-fill gives nothing. As there are only 2 photos at KAGS, I would suggest to align Your location name to the existing one. You may do so by using the "Correct Information" link.
Another suggestion, when the auto-fill gives no result, is to use the advanced search function and type the airport code (either ICAO 4 letters or IATA 3 letters) in the "Location" field. You could get results even if the auto-fill gives nothing.
Hope it helps. Editors might give their opinion on this.
Patrick
Patrick De Coninck
dumbell2424
Thu Apr 21, 2011 8:01 pm
Quoting coninpa (Reply 1):
Alrighty, did the correct information. Thanks for the help
