jetcrazy
Canon EF 70-300mm F/4-5,6L Is USM - Happy With It?
Wed Jun 08, 2011 8:55 pm
Hi!
I got this lens (Canon EF 70-300mm f/4-5,6L IS USM) some weeks ago, but I´m not really sure if it was a good idea to use it instead of a 100-400 and 70-200 4L IS USM. I´m missing the little rest of crisp/sharpness at around 220-250mm focal lengths...
Does anybody use this new lens and can say something about it in comparison to 100-400 and 70-200?
Jens
highguy76
RE: Canon EF 70-300mm F/4-5,6L Is USM - Happy With It?
Wed Jun 08, 2011 11:34 pm
I just rented this lens from BorrowLenses.com and am taking it to GVA tomorrow for a test run. I will let you know what I think in a couple of days.
HG76
scopedude
Thu Jun 09, 2011 1:27 am
I have been using mine since February, and so far I never touched my 70-200/4 IS anymore
It's very sharp, and I see no problem above 200mm - although at 300mm it's slightly less sharp than the shorter settings.
this was taken around 180mm;
http://www.airliners.net/photo/Triga...d=28dddf595b521809fc906b2431cce2af
I got it for $1250 and it's definitely a great buy!
5DSR, 6D, X-T1, 70-200 IS II, 70-300 L, 18-55, 55-200
jcoz
Fri Jun 17, 2011 8:41 pm
My experience is that it is better than the 100-400. My father compared his 100-400 with my 70-300, and at 300mm my lens is a tad sharper, but that doesn't make much difference. The IS however is much, much better (twice as effective), and the lens is cheaper. When it comes to spotting, I had no problem with it as airliners are nowadays pretty large, and a good spot at an airshow will let you get good shots of small warbirds, most of the time. I did wish I had something between 300 and 400 at my last air show though...(I have the 70-300L and 400 5.6L).
My father also owns the 70-200 f4. It is excellent, but weighs the same as the 70-300 and is shorter, with a similar IS. He hasn't used it since he get his 100-400.
Hope it helps
scopedude
Sun Jun 19, 2011 2:55 pm
Quoting jcoz (Reply 3):
I also have a 70-200/4 IS, and mine is actually longer than 70-300L (at shortest position) and lighter as well. The drawback of 70-300L is its weight IMO.
F38
Mon Jun 20, 2011 8:37 pm
@scopedude totally agree!
XT6Wagon
Mon Jun 20, 2011 10:46 pm
Only time I regret getting the 70-300mm L is low light when the 70-200mm F2.8 would clearly be better...
jcoz
Tue Jun 21, 2011 8:12 pm
Quoting scopedude (Reply 4):
Indeed, my memory failed me   The 70-300L is still very light compared to the 100-400 and Sigma 120-400.
c172akula
Fri Jun 24, 2011 4:31 pm
I've had this lens for a couple of years and find that from 200-300 if you can go f10 or f13 you get pretty sharp images.
scopedude
Sat Jun 25, 2011 12:32 am
Quoting C172Akula (Reply 8):
Are you talking about the 70-300 IS USM? The L was introduced late 2010.
c172akula
Sat Jun 25, 2011 1:18 am
Quoting scopedude (Reply 9):
Whoops, I am talking about the IS USM. Didn't notice the "L" in the title.
XT6Wagon
Sat Jun 25, 2011 7:20 am
Quoting C172Akula (Reply 10):
yah I have both and in no way is the non-L comparable in performance. The plain 70-300mm IS is a good $500-600 lens, just not L quality. Just the focusing and IS of the L lens sets it a world apart, and the awesome sharpness from 70 to 300mm is as good as you can find in any L zoom.
Users browsing this forum: No registered users and 4 guests
