JimmyLWH
How About A 300mm Prime Lens?
Sun Jul 17, 2011 3:47 pm
Hi all,
I currently have a Sigma 100-300/4, and I'm thinking if I should have a 300mm lens, like Nikon's 300/4D. The 300mm prime lens is good no doubt, but the fixed focal length means I can't take whole fuselage shots easily. Hesitating about that.
Jimmy.
ckw
RE: How About A 300mm Prime Lens?
Sun Jul 17, 2011 10:49 pm
What don't you like about your 100-300? As a general rule, a prime is going to offer superior image quality in theory - whether this will translate into an improvement of your images to justify the cost is an entirely different matter!
While I tend to advocate buying the best glass you can afford, this might not be the solution to a particular problem which may be related to technique or the camera (eg. issues with noise).
Colin
Colin K. Work, Pixstel
NIKV69
Mon Jul 18, 2011 5:08 am
Best lens I ever bought.
Hey that guy with the private jet can bail us out! Why? HE CAN AFFORD IT!
ptrjong
Mon Jul 18, 2011 9:23 am
Quoting NIKV69 (Reply 2):
Amen. Of course it can be too long sometimes, even more so if you insist on side-on pictures.
Peter
darreno1
Tue Jul 19, 2011 1:59 am
You should consider renting one first to see if it'll work for you.
Nikon D7000 / Nikkor 105mm AF f2.8 / Nikkor 35 f1.8G / Nikkor 50 f1.8D / Nikkor 85mm / Nikkor 300mm f4 AF
viv
Tue Jul 19, 2011 6:15 am
I would have little use for a 300 mm prime.
Depending on the circumstances, it would either be too long or not long enough.
ckw
Tue Jul 19, 2011 1:11 pm
Quoting viv (Reply 5):
I have 70-200 and 500mm (sold my 300mm f4 to help pay for the 500) - guess what focal length I miss the most
I have held off on replacing the 300 as the plan was to get whatever Canon replaced the 100-400 with. Sadly that has taken much longer than expected, and the price looks like it may be a bit rich!
Fortunately the 70-200 f4 IS works very nicely with the 1.4x convertor, and I can live with the loss of a stop. The old 100-400 is not an option as I know it doesn't match up to either the 70-200 (with or without the 1.4) or 500 so I see no sense in taking a step backward.
Colin
NIKV69
Tue Jul 19, 2011 1:58 pm
Quoting ptrjong (Reply 3):
That is why I also have a 80-200 2.8
ptrjong
Tue Jul 19, 2011 3:07 pm
Quoting NIKV69 (Reply 7):
So do I. Well, 70-200 2.8 VR
Users browsing this forum: flleitee and 1 guest
