BMIFlyer
Amazing Milky Way Shot Taken In Flight.....
Wed Jul 27, 2011 11:46 am
One of the best in flight shots i've ever seen!
Photo © Kavin Kowsari - AirTeamImages
Well done!!
JakTrax
RE: Amazing Milky Way Shot Taken In Flight.....
Wed Jul 27, 2011 11:48 am
Really good shot. How did he manage to keep the camera so still for a 5 second exposure?
Karl
Dehowie
Wed Jul 27, 2011 11:57 am
Now that is photography..
Keeping the camera still is easy keeping the aircraft from rolling and keeping the stars stationary was the hard part.
Flown that route a few times now and once in this aircraft and smooth conditions a shot like this needs are few and far between.
Great work!
2EOS1DX,EF14.2.8LII,17TS,85/1.2,16-35L,24-70LII,24L,70-200F2.8LII,100-400,300/400/500/800L
SNATH
Wed Jul 27, 2011 12:59 pm
Quoting BMIFlyer (Thread starter):
Indeed! And I wonder whether there's any other camera, apart from the D3s with its amazing high ISO performance, that could have taken it...
Tony
Nikon: we don't want more pixels, we want better pixels.
JohnKrist
Head Support
Wed Jul 27, 2011 2:06 pm
What I am interrested in knowing is how he kept the light of the cabin ut. I have tried blankets, jackets combined with hood and what not, and can still see the Lens specs reflecting in the image...
5D Mark III, 7D, 17-40 F4 L, 70-200 F2.8 L IS II, 50mm 1.4, EF 1.4x II, EF 2x III, SPEEDLITE 600EX-RT
Ychocky
Wed Jul 27, 2011 3:19 pm
Well done Kavin!
The consistent quality and creative presentation of subjects in his work are a real treat!
Silver1SWA
Wed Jul 27, 2011 3:42 pm
That is INSANE! Wow...it's hard to get a clear shot of the milky way from the ground... But 5 seconds in a plane??
Amazing stuff.
Stealthz
Wed Jul 27, 2011 3:52 pm
Quoting Dehowie (Reply 2):
And Deh... has the advantage of larger windows so his praise is well earned... and seconded!
sovietjet
Wed Jul 27, 2011 5:29 pm
How??
launchphoto
Wed Jul 27, 2011 8:34 pm
You don't have to have a d3s to take a shot like this; if you can keep a camera still (tripod, clamp, etc) for 15-45 seconds, you can use ISO 3200 or 6400 as well. Very well done for a plane, yes.
Ben Cooper
G-CIVP
Wed Jul 27, 2011 9:32 pm
I'm surprised that there wasn't more blur in this photo. Can someone explain how this was avoided?
vishaljo
Wed Jul 27, 2011 10:27 pm
^ Well blur in the sky would be a non-issue due to it being as away as the Milky Way, so not much would change in 5 seconds if the a/c was flying smooth, which seems like it was as the winglet area is rock steady.
Sure keeping a heavy apparatus like the D3s + 14-24 steady for 5 seconds would've been a task i'm curious in knowing.
HELL of a shot though!
Nice few photos on his SmugMug Gallery too - http://kavinkowsari.smugmug.com/
Also, i would like to say that after a LONG break come along a photo that makes you dream, you long for it in its absence, then you somehow lose the expectation, which is when BOOM! it comes to Thrill you  cloudnine
[Edited 2011-07-27 15:49:52]
iamlucky13
Wed Jul 27, 2011 10:51 pm
An A330 at high altitude, over the open ocean on a clear night - that's a good recipe for smooth air. Brace the camera against the window firmly to steady it, and cover it with a blanket to kill reflections, and I could see him getting good results from a handful of multiple shots taken.
Even so, there's hints of blur in the stars if you look close, which is not intended to detract at all from the awesomeness of his photo. It simply helps illustrate how difficult this shot is.
JakTrax
Wed Jul 27, 2011 11:49 pm
I think a little micro-blur is expected and easily forgiven here. Perhaps luck played a huge part (doesn't it always in photography?) but praise where praise is due - great work, however lucky the circumstances might have been.
Karl
Silver1SWA
Quoting G-CIVP (Reply 10):
5 seconds is doable with a proper setup. What's impressive is how much detail came out in the sky at 5 seconds. That means a very high ISO was needed.
Typically when photographing the night sky, the biggest cause of blur is the rotation of the earth.
johnr
Wed Jul 27, 2011 11:55 pm
That photo was taken over the Tasman Sea which on that particular sector is at about 3:00 am when the cabin service is over and the interior lights are off so it would have been fairly dark inside making it easier to deal with reflections. This incredible photo has inspired me to do some star gazing next time i fly that sector! Very well done.
soon7x7
Thu Jul 28, 2011 2:06 am
Didn't know the "Atlantis" had winglets!...My jaw dropped upon seeing this image. While I'm no stranger to hand held time exposures in static aircraft, seated in an airliner seat, trying to wedge yourself tightly in the seat and sure up the camera for a handheld time exposure is most difficult...the shot is an eyegrabber. How high was his ISO?...a wide angle lens does help reduce relative motion blur in such a shot. Author should enter in AV/WK's annual contest.       Great use of the camera...g
vikkyvik
Thu Jul 28, 2011 2:27 am
Quoting soon7x7 (Reply 16):
ISO12800 per his remarks on the photo.
That is really something else. I struggle to get un-blurred shots at 1/4s on an airplane!
Thu Jul 28, 2011 4:03 am
Quoting SNATH (Reply 3):
I also wonder.. Amazing what technology can do these days!
cpd
Thu Jul 28, 2011 4:12 am
Quoting Silver1SWA (Reply 14):
yes indeed, and it's a great result. That's real photography. It's probably the most inspiring shot I've seen in ages on here - it's more inspiring for me than a hundred photos from ATC towers or air-to-air shots from Skyvans.
Pretty high, but to be honest, 12800 is actually really easy with the D3s. 20,000 ISO is also quite good. Kevin Kowsari is a pretty good photographer - and that's the bit that matters, not the camera - although it helps to have a D3s.
Quoting NZ107 (Reply 18):
Maybe 1D Mk. IV might manage it, but I don't know what its noise is like at ISO12,800. The Nikon is really good at that ISO. It only starts to get difficult at above ISO20,000.
[Edited 2011-07-27 21:14:22]
G-CIVP
Thu Jul 28, 2011 7:49 am
Thanks for the replies. I think I misread the ISO as 800 rather than 12800!
McG1967
Thu Jul 28, 2011 5:03 pm
Certainly a great shot. Notice how the 5s exposure captures the red beacon illuminating the outer part of the wing.
I bet we all try stuff like this now on longhaul or overnight flights.
iamlucky13
Thu Jul 28, 2011 9:02 pm
Quoting McG1967 (Reply 21):
No good photo goes un-imitated, and imitation is the sincerest form of flattery.
None of the future attempts, however, are likely to get the 45,000 views in 2 days that Mr. Kowsari's has. He put it to pixels first.
It's nigh on impossible to shoot something original these days, what with tens of millions of SLR's out there, and tens of millions of people clicking away like monkeys trying to produce the works of Shakespeare...err...Adams...
...but this is as original as anything I've seen on this site in a while.
However, you don't have to worry about me being one of the multitudes of imitators - I never get a window clean enough to be worth trying.
JohnKrist
Head Support
Thu Jul 28, 2011 9:32 pm
Quoting iamlucky13 (Reply 22):
I hear you man, and if they are clean, some other bozo have scratched it with the UV-filter while trying to get a picture like the one from Kavin
[Edited 2011-07-28 14:33:09]
ckw
Fri Jul 29, 2011 7:13 am
That's not the milky way - that's what noise looks like at 12800
Seriously, a very impressive shot, and confirmation that you should always have your camera with you - you never know when an opportunity will occur.
Colin
Colin K. Work, Pixstel
JakTrax
Fri Jul 29, 2011 3:27 pm
I never did; until last week.
I always wondered how folks managed to get so lucky with a clean window but I actually had a perfect one on a Ryanair flight last week!
Not a lot to shoot though.....
Karl
soon7x7
Mon Aug 01, 2011 2:36 am
Quoting vikkyvik (Reply 17):
I've got two D300's...are they even capable of 12,800iso...and no noise or was the noise in the shape of the milky way?
GLEX
Fri Aug 05, 2011 11:45 am
If he had a circular lens hood (not the tulip-style) he could have pressed it onto the window to reduce reflections. Combined with a dark cabin and a blanket it seems well possible to capture a shot like that. At least my
