ebentes
Spotting At SIN, SYD, YVR And YYZ
Fri Jul 29, 2011 5:43 pm
Hi guys..
I´ve bought a Star Alliance round the world ticket to fly in FEB 2012 with the following itinerary: MAO-GRU-ZRH-SIN-SYD-YVR-YYZ-NYC-MIA-MAO and I´d like to know if in SIN, SYD, YVR and YYZ airports there is an opened observation deck for spotting.
Thanks in advance.
Eduardo
SIA6696
RE: Spotting At SIN, SYD, YVR And YYZ
Sat Jul 30, 2011 4:28 am
SIN has observation decks but none of them are open decks, and only T1 has clear glass, the others are double layered and have a green tint.
SYD has an open deck, it is quite good for spotting but only if they are using 16R.
Im not sure for YVR and YYZ
Come fly away!
aussie18
Crew
Sat Jul 30, 2011 6:58 am
Sydney's observation deck is great for 16R operations as you can get some nice touchdown shots and some nice shots with the city skyline in the background,Only downfall is when an aircraft is parked at certain gates with APU running it can generate alot of haze distortion which can be a pain.
When 34L is in use you can also get some shots of them heavies on climb out.
Photo © Mark H
Photo © Mark H
Photo © Mark H
Cheers Mark.
ebentes
Sat Jul 30, 2011 6:03 pm
Thanks to SIA6696 and aussie18...
Aussie18, in one of the photos I can see the hotel I´ll stay. The Stamford Hotel.
gmonney
Mon Aug 01, 2011 3:09 am
There is no observation deck at YYZ nor YVR, however both have fantastic locations to photograph aircrafts. It's not hard to sees from the photos from both locations that there is great variety and worth a stop. At YYZ, my home airport you will need transportation to get to the good spots. The wind is a huge factor, Rwy 23/24 is good, the 33's are great and 5/6's can be ok but the local authorities will escort you from the threshold of 06L. As well, in February you will be dealing with very cold weather in YYZ, however without shamelessly plugging my own photos, the clear air is amazing and can offer great photos, sorry I am going the shameless route!
Photo © Grant Feggi - t.dot photography
How long will you be on the ground in YYZ?
Grant
Drive it like you stole it!
dlowwa
Mon Aug 01, 2011 4:03 am
Quoting gmonney (Reply 4):
Can't speak for YYZ, but that's certainly not true for YVR. Your info is out of date as there are now two observation decks here, plus the official viewing park at the east end of the south runway. The one in the domestic terminal opened two years ago, and the south terminal outdoor observation deck opened just last month.
Rotate
Mon Aug 01, 2011 8:22 am
Quoting dlowwa (Reply 5):
Ui! Thats great news Dana ... Is there any more info on the www re the 2 observation decks? What can you expect and what to see, opening times, etc ... Any info highly appreciated.
Robin
ABC
Ryan h
Tue Aug 02, 2011 3:55 pm
First time to Vancouver for me, but have found Templeton street a great place for approach photos.
dlowwa
Wed Aug 03, 2011 4:07 pm
Quoting ryan h (Reply 7):
Templeton is great for blue-sky approach shots for 26R. It is relatively easy to access without a car, and no ladder is required.
Quoting rotate (Reply 6):
Both open 24hrs as far as I know. The indoor one overlooks one of the domestic gate areas, so you'll mostly see small AC stuff, 319s and DH8s. It looks out to the west, so almost all international departures will pass by when taxiing to the south runway. They tend to be a bit closer if the 26s are active, but you will need to contend with the usual thick green glass, and reflections can be a problem. The new outdoor deck is basically just a raised platform they've built so you can see over the fence. It's right in the south terminal parking lot so it gives a pretty good overview of the south terminal ramp - lots of regional props and the like. It can be a bit cluttered at times, but you will be able to see all departures from the south runway. Heat haze will ruin many shots though, so keep that in mind for photography.
cpd
Thu Aug 04, 2011 1:26 am
Quoting ebentes (Reply 3):
Domestic terminal at Sydney airport has a great observation area, not official - but where the upstairs loop road runs around between the two terminals - there is a stair-way at the end, going to the lower level road-way. Stand at the end of that, and you have excellent morning views of runway 16 right landings.
If a Dash-8 is parked in front of you - you'll get heat haze, otherwise - you can get nice images that look like you are really close to the planes.
Rotate
Thu Aug 04, 2011 7:49 am
@ Dana: Thx vm for the info !
ABC
cargolex
Thu Aug 04, 2011 4:14 pm
I had a spotting question about YVR and the infamous "rental car" area (formerly Avis). Is it really okay to be on that street (outside of any rental car company's property, of course) with a ladder shooting aircraft on 26R? Obviously it's paramount to respect property and rules, and I've been wondering about this for awhile.
dlowwa
Thu Aug 04, 2011 4:51 pm
Quoting CargoLex (Reply 11):
I generally avoid going there during business hours, as if there is going to be a confrontation, that's when it is likely to happen. Anytime after 4-5pm you should be fine, as everyone has gone home (it's used primarily as an employee parking lot). Not really a big issue this time of year, as bad light and heat haze make it one of the less desirable spots during the day, and by the evening, the sun is already crossing to the other side of the runway. In fact, don't think I've been there for a month or two.
Let me know next time you're up here, I might swing by and say hi. Can also lend my ladder if I'm not using it.
Ryan h
Fri Aug 05, 2011 6:02 am
Most of my trips out to YVR have been when they are landing on 26. One day they were landing from the other end and found it hopeless. Does that happen much this time of year?
Want to try and get as much time around the airport before going home.
dlowwa
Fri Aug 05, 2011 6:47 am
Quoting ryan h (Reply 13):
As a rough guess, I'd say the 08s are in use 30-40% of the time. The weather is a good indicator (sunny skies mean 26s are more likely), but your best bet is to check the wind direction before you leave to know which runways are in use. From the west means 26s, from the east 08s. Of course you can also just pull up the live atc feed and listen to which runways are active, but looking at the forecast wind direction is usually a better indication of how it will be for the rest of the day.
airplanespotter
Sat Aug 06, 2011 6:16 pm
Does anyone by any chance know great spots for viewing landings/deperatures at YYZ for runways 33R/15L. There was a great spot for viewing arrivals near 15L but recently it has been closed for spotting.
KeKeKumba
Tue Aug 09, 2011 6:16 pm
The Avis parking lot at YVR was fantastic when I was there (3 different trips in the span of 4-5 days). No troubles with anyone, no one even looked at us besides airport employees driving around. I just stood up on the edge floor of the side door of our rental car and that was enough for me to see over the fence. 110mm-280mm worked good for me.
[Edited 2011-08-09 11:17:53]
Ryan h
Wed Aug 10, 2011 3:47 am
Found today at yvr there is a newly built platform over near the south terminal. Parking too long will get expensive though.
Great for take offs on 08 right and when I was there today, there were plenty of bizjets about today.
dlowwa
Wed Aug 10, 2011 3:56 am
Quoting ryan h (Reply 17):
Think I mentioned that already...
Quoting dlowwa (Reply 8):
Ryan h
Sun Aug 14, 2011 2:46 am
Quoting dlowwa (Reply 18):
Went to that spot today to find the deck is now closed off. A guy there said it was not finished, but looked finished to me.
Users browsing this forum: No registered users and 28 guests
