NPeterman
Loss Of Saturation In CS5 Save For Web Function.
Sun Aug 07, 2011 2:11 pm
Hello All,
I am in the process of editing some photos from a day of shooting yesterday, and have noticed something that I have not seen before when saving my photos. I always use the save for web function, and today, I have noticed that the final image looks rather flat and unsaturated when compared to the original displayed above. Is there something that I am missing? My working space is srgb, as is my raw convertor. Do I simply need to over-saturate it a touch while working on it so that it looks "properly saturated" after saving?
Many Thanks!
NPeterman
dumbell2424
RE: Loss Of Saturation In CS5 Save For Web Function.
Mon Aug 08, 2011 2:37 pm
Under Edit-->Color Settings, Color Management Policies, RGB, does it say: "Convert to Working RGB"?
dvincent
Mon Aug 08, 2011 3:50 pm
When using Save For Web, there's a checkbox for "Convert to sRGB." Make sure it's checked.
From the Mind of Minolta
NPeterman
Mon Aug 08, 2011 4:17 pm
Thank you both. Unfortunately, I had already checked both of those settings, and canconfirm that I have done them both, yet the issue persists. Any other thoughts?
darreno1
Mon Aug 08, 2011 5:14 pm
What web browser are you using? If it's Chrome that may be your issue. Chrome still has limited color profile support. Try browsing the site with IE or Firefox.
Nikon D7000 / Nikkor 105mm AF f2.8 / Nikkor 35 f1.8G / Nikkor 50 f1.8D / Nikkor 85mm / Nikkor 300mm f4 AF
NPeterman
Mon Aug 08, 2011 8:22 pm
I'm sorry if I wasn't clear above. The loss of saturation is visible even in the save for web window, where it shows the original, and the file that is about to be saved. That loss of saturation then carries through to when the image is viewed on Internet Explorer, Windows Media viewer, etc
stevemchey
Mon Aug 08, 2011 8:43 pm
Quoting NPeterman (Reply 5):
That is usually a sign that the color profile of the working copy (original) is different then the one that is about to be saved. But as you stated, your working color space is already sRGB... so that's odd...
Just as a sanity check, I would open the original, then manually change the color space through "Edit > Convert to Profile..." and choose sRGB as the Destination Space (at that point, also note the Source Space and see if it is the typical "sRGB IEC61966-2.1").
Good luck...
[Edited 2011-08-08 13:44:48]
dumbell2424
Tue Aug 09, 2011 1:58 am
Also going on what Steve said, when you open the file, does it ask you to convert to SRGB?
NPeterman
Tue Aug 09, 2011 3:38 pm
It does not ask me to convert to SRGB, no.
dumbell2424
Tue Aug 09, 2011 3:42 pm
Alright. On Edit->Color Settings, you said you had Convert to Working RGB in the box, do you also have Profile Mismatches: Checked on Ask When Opening and Missing Profiles: Checked on Ask When Opening?
stevemchey
Tue Aug 09, 2011 5:00 pm
Nick, did you try what I suggested in Reply 6? Did you see sRGB listed in the Source Space when you went to "Edit > Convert to Profile..."?
NPeterman
Tue Aug 09, 2011 5:36 pm
Dumbell, I did not have the mismatch boxes checked. I do now. Steve, I did try what you suggested in reply 6, and the source was listed as SRGB. I will ask, just in case I am doing something stupid and missing something obvious that I just wasn't aware of, could the fact that this is a RAW file that I am saving as a jpeg have anything to do with this? are RAW files just inherently "more"saturated, and lose this when saving as a jpeg?
dumbell2424
Tue Aug 09, 2011 5:59 pm
Quoting NPeterman (Reply 11):
Try starting over from RAW now. When you do your RAW adjustments then open in PS, it should ask you a question like would you like to convert to SRGB? or something like that. Click continue/yes (sorry not on a PS cpu atm) and you should be fine.
vikkyvik
Tue Aug 09, 2011 6:43 pm
With RAW, you should be able to set the saturation before you export to JPG.
I find that the images I get from my camera are a bit undersaturated, so I've gotten in the habit of adding a bit of saturation in RAW before exporting.
Related question - in ACR in CS5, how do you set it to export JPGs in SRGB? It seems to default to AdobeRGB, which then means that I get the prompt to convert to SRGB when I open the JPGs in Photoshop. I haven't been able to find a menu which allows you to change the RAW export settings (if it exists!).
NPeterman
Sat Aug 13, 2011 4:09 pm
Quoting vikkyvik (Reply 13):
if you open ACR, down below the image pane, there should be some blue writing which shows your color space, etc. Click on that and it will bring up a dialogue box where you can change color space, depth, etc. There is no way to click save for these settings, ACR just seems to "remember" them and always pulls them up. I've never had to do it again.
Oh, and for the resolution to my other question, it appears that although the image is high de-saturated when viewed in the save for web pane, pulling it up after uploading it to Airliners.net or Flickr reveals perfectly normal saturation now. Something has changed, although it still appears de-saturated in the save for web pane. I'll just chalk it up to another CS5 mystery...
vikkyvik
Sun Aug 14, 2011 4:32 am
Quoting NPeterman (Reply 14):
Thank you so much! I've been trying to figure that out for a long time, but it never occurred to me that the blue writing was something you could click on to change settings!
