Garyck
Crew
Focal Lenghts
Mon Aug 15, 2011 7:01 am
I'd like to say thanks to the slowly growing number of photographers that are adding focal lenghts in the comments box of the pictures.
I can see it being a benifit to all of us and very useful especially if visiting an airport or airfield that you have never been to before. I went through a patch of thinking I will need a 100-400mm for my up comining trip to Florida, but that has all but vanished. 100-400 may be useful, but its just extra weight to carry about.
I will try to remember in future to put them on, I did a few then forgot since. Oops
Andrea Fietz - AMS - 44mm. I assume this is from the Spotting deck
Photo © Andreas Fietz
Andrea Fietz - MIA - 50mm. Landing RWY12
Fred Seggie - OPF - 30mm. Maybe an Airside shot
Photo © Fred Seggie - WorldAirImages
Gary King - MAN - 50mm. Line up shot 23L
Photo © Gary Claridge-king
Keep your Ladders close, but your camera closer
RE: Focal Lenghts
Mon Aug 15, 2011 8:04 am
Don't forget about the crop factor - ie what body was used. This can also throw the question of what lens was used out the window. A fellow A.Net photographer and I went to the airport on Friday: he had a 5DII and 100-400 and I had a 40D and 100-400. From the same place, he could fit a 77W in portrait with his 100mm whereas I ended up chopping the front and back of the plane off if I tried doing a portrait shot.
Garyck
Crew
RE: Focal Lenghts
Mon Aug 15, 2011 8:10 am
Quoting NZ107 (Reply 1):
I forgot about that.
My images always include the body and lens in the comments box anyway. I know that the an image taken with my 450 will be different to that of a XXD or XD series, but what and how I forget, its something to with 'full frame', I'm sure someone will explain this better.
viv
RE: Focal Lenghts
Mon Aug 15, 2011 2:43 pm
Focal length used will actually tell you very little, unless you also know the size od the sensor (crop factor) and to what extent the original image was cropped in post-processing.
alevik
Crew
RE: Focal Lenghts
Thu Aug 18, 2011 11:52 pm
Quoting viv (Reply 3):
Except that a nice image taken with a 50mm lens or listed focal length tells you to get that shot if you have a 55-300 or 24-70 you should be okay. A nice image means that the amount of post processing cropping is not that bad, and if the camera is listed you know (or can determine) the crop factor. Sometimes that is part of the point - "if I go to visit that airport I can shoot from that spot and bring only my 70-200". So I would say focal length can tell you quite a bit, depending on what you are hoping it will tell you. I have searched the DB for images with camera/lens info for this very reason.
Improvise, adapt, overcome.
Users browsing this forum: CV990A, FAST Enterprise [Crawler] and 1 guest
