notaxonrotax
Absolute Beginner: How Much Do I Need To Edit My P
Fri Sep 09, 2011 12:40 am
So,
I am playing around with my Nikon D3100........at local crop-dusting bases and a few international airports and I get my photos rejected on several aviation picture sites.
Hopeless rejections, which is normal for a beginner; so I´ve been told.
I´m playing around with my shutter speed, aperture.........sometimes I just sit in front of a rotating prop and try different camera settings and the results are very interesting.
But here´s my question: somehow my pictures never come out as nice and bright as the pics I see on the net, so how much is generally achieved by "software-editing" the shots afterwards?
I use "Preview" within the Macintosh software to toy with contrast, sharpness etc.......but how essential is this?
Do the great photographers on this site rely a lot on these "tricks", or is a great pic, simply a great pic?
Any advice would be appreciated,
No Tax On Rotax
For anybody that happens to be wondering:"yes, owning your own aircraft is a 100% worth it!"
megatop412
RE: Absolute Beginner: How Much Do I Need To Edit My P
Fri Sep 09, 2011 1:37 am
You'd be surprised at the length to which folks go to get their photos accepted. Everyone has a 'workflow' and it is commonly observed that every shot needs some amount of sharpening. Sharpening itself has become one of the dark arts of aviation photography here as any unshsarp mask user will tell you.
Some of the common adjustments made to photos are contrast, sharpening, leveling, cropping, color/tone curve adjustment, brightness, maybe some noise reduction.
It helps to start with a high quality image, nothing from far away, nothing with distracting elements in it, nothing backlit, and nothing blurry. But, there seems to be an inverse relationship between the rarity of an aircraft and the quality required for acceptance.
Lighting is key. Some of the best shots here have very dramatic lighting, shots taken during the optimal hours of the day instead of the sun being directly overhead.
darreno1
Fri Sep 09, 2011 1:54 am
Well you have a great entry level body - the d3100. Most of my shots on here were taken with one. To get A.net quality pics you need to practice, be patient and yes you do need to learn and develop your editing skills. Getting 'perfect' (i.e by A.net standards) shots right out of the camera isn't easy. Occasionally I might take a pic that needs very little editing but the majority usually needs some tweaking to get accepted. So, the rejection guide is a must read and there are good tips in the Photoshop editing guide. Rejections are a part of life here and it's something you'll have to get used to. However as you develop your skills, your acceptance ratio will increase. Other factors that come into play:
1. Lens: Basically you get what you pay for. Cheap bottom of the barrel lenses will yield so-so results. Here is where it's usually wise to do some research before jumping on a 'bargain'.
2. Settings: Pretty obvious. You want the most accurate exposure possible and you want it in focus. Only time and practice can help here. I suggest using manual mode as much as possible to get a feel for what each setting does. If you want to get the most out of editing, shoot in RAW mode.
3.Weather: Also obvious. Great weather with good light will make life a lot easier.
4. Heat Haze: Try to avoid it as much as possible. It will reduce the quality of otherwise great shots. And it's not always easy to detect until you get home and start editing. Some people recommend shooting late in the day when the sun is about an hour or two from setting or early the morning. From my experience, it really does help. Early morning shots can have amazing clarity right out of the camera. For daytime high heat hours, finding a spot a little ways away from the airport can help as well.
Nikon D7000 / Nikkor 105mm AF f2.8 / Nikkor 35 f1.8G / Nikkor 50 f1.8D / Nikkor 85mm / Nikkor 300mm f4 AF
vikkyvik
Fri Sep 09, 2011 6:25 am
My typical editing workflow for A.net involves:
1.) RAW editing (which I usually do for all photos, whether they're going to be uploaded to A.net or not): exposure, contrast, noise reduction, sharpening, white balance/color tweaking, export to JPEG
2.) JPEG editing (which I usually only do for A.net photos): contrast again (because I never seem to get it quite correct in RAW), selective NR if necessary, resize, sharpening (for A.net).
Quoting darreno1 (Reply 2):
4. Heat Haze:
YES! Nothing is worse than uploading 200 freshly-taken photos, and realizing that 150 of them are badly heat-hazed.
Most importantly, get out there and practice shooting. When I look through my photos, I have a much higher percentage of keepers now than I did 1 year/10000 photos ago.
And yeah, you'll have to practice editing too to get shots on here, though it doesn't exactly sound as much fun. But to me, getting photos on A.net is a fun challenge, and editing is part of that.
SIA6696
Fri Sep 09, 2011 6:45 am
Good editing software helps a lot. Using a simple program such as preview will often not enable the user as much control over the image then photoshop.
If you have photoshop just follow this suggested workflow, its what i used and it works.
http://www.airliners.net/faq/editing_guide.php
Come fly away!
viv
Fri Sep 09, 2011 8:30 am
Post-processing, for me, takes about two minutes per shot.
My workflow is simple: Crop (if necessary), Resize, Equalise to check for dust spots, Clone Out any dust spots, Smart Sharpen.
That's it. If you need to do more than that, the original image was not good enough.
chris78cpr
Wed Sep 14, 2011 12:40 pm
Quoting viv (Reply 5):
I see when you purchased your M9 you took the option of purchasing the Leica snobbery also.
To the original poster...
Try not to play around too much with the processing functions as the term 'less is more' is very applicable here. I would recommend getting yourself a copy of photoshop elements and within that software use only the basic levels, contrast and colour tools to enhance the image. Every image will need to be sharpened and this is best left to the last step when the image has been resized to 1024/1200/1400x. The editing guide linked above is a good place to start reading.
Chris
5D2/7D/1D2(soon to be a 1Dx) 17-40L/24-105L/70-200F2.8L/100-400L/24F1.4LII/50F1.2L/85F1.2LII
Dehowie
Wed Sep 14, 2011 2:14 pm
If you are shooting nothing more than blue sky with contrasty background stuff that may be the case but for more demanding conditions PP is a fact of life.
Even my M9 stuff needs editing..but then i try to spend less time in blue skies and more time at night and in rain..
2EOS1DX,EF14.2.8LII,17TS,85/1.2,16-35L,24-70LII,24L,70-200F2.8LII,100-400,300/400/500/800L
dumbell2424
Wed Sep 14, 2011 3:00 pm
For editing-make sure you're working or saving in sRGB. Also, Google the Jid Webb workflow. There are videos on YouTube, it's amazing what it has done for some of my photos.
sovietjet
Wed Sep 14, 2011 3:07 pm
Simply not true.
I do agree with you.
However, be wary of using manual mode too much. Imagine photographing a plane moving left to right of your field of view. Chances are, the lighting is not the same on the left as it is on the right. So dialing in some manual settings for when the plane is on the left might result in under- or overexposure of that plane when it's in front of you and on the right. It's not very convenient to keep manually changing settings as the plane moves across your field of view. The best use of manual mode is for static photos, or if you plan on a particular motive of a moving plane using only a select part of your field of view.
As far as RAW, not always necessary as well. Photographing a plane against blue skies on a nice sunny day does not require RAW. But others will disagree.
2H4
Wed Sep 14, 2011 3:27 pm
Quoting megatop412 (Reply 1):
I learned this the hard way via this shot:
MyAviation.net photo:
Photo © Jason McDowell
It was rejected because the tip of that cone is blocking part of the fuselage. Now I make a very strong effort to look for anything and everything that might possibly be blocking even an antenna.
When I shoot in museums, I'll actually move parts of the display (usually with permission) to achieve a clear view of the aircraft. Notice how, in this shot, I unclipped one of the barricade ropes so the nosewheel wasn't blocked:
Intentionally Left Blank
HarryImp
Wed Sep 14, 2011 5:31 pm
I am also new to editing and was wondering what method i should use for sharpening??
I either make it grainy/soft and cant get it right.. And also how can i reduce noise in editing??
Harry
cliffak
Wed Sep 14, 2011 5:46 pm
I like Lightroom a lot, because it's designed with photographers in mind, with clear names for controls that mostly do what you expect them to do (ie adjusting the "exposure" slider will have the expected result). Also, I like the fact that it doesn't touch your original files and has neat things like the "virtual copy" feature. I seldom use PS nowadays but LR will integrate with it sohuld you need to do things LR can't.
For an example how not to design photo editing software, try GIMP.. IMO it shows that it was designed by software people without much input from photographers. Then again, usability usually isn't a priority for FOSS projects.. Unfortunately.
RonS
Wed Sep 14, 2011 7:12 pm
Quoting HarryImp (Reply 11):
If you have Photoshop, and I think CS2 and later, you should use Smart Sharpen on a seperate layer and you should mask out the sky beforehand.
Yes, but only a little because it removes alot of detail. I do alot of noise reduction in LR3. Before LR3 I would process RAW in Adobe Camera Raw and do some NR. Then when I save the TIFF and open in CS3, and if I still had noise, I would generally select ONLY the sky, and apply a little more NR in photoshop of the sky.
Hey Viv, I've seen you write that about 50 times. For me it takes a while. But like Darren said above for sunny skies, ok a few quick minutes, I can see that. I barely even shoot in the daytime. Sunrise and sunset, High ISO shots, it's going to take a bit longer for me. Heck, sometimes I can't even get the WB right in 2 minutes!
But for the begginers to make it around here, I think saying two minutes is unrealistic for them. I remember it taking me 15 minutes just to adjust the level after multiple rejections.
All opinions expressed by me are my own opinions & do not represent the opinions in any way of my employers.
sovietjet
Wed Sep 14, 2011 8:24 pm
No matter how good a photographer you are, and how correct your settings, in many lighting situations the camera simply cannot perfectly represent the scene (due to dynamic range, etc..). Therefore some adjustments in contrast are required, sometimes even just a slight adjustment. The balloon shot, of course will have perfect contrast, you are shooting a brightly lit subject against a black background, what would you expect?
viv - I see most of your photos are of subjects during a bright sunny day with nice clean blue skies. I would love for you to show us how to take a photo in conditions like these without doing any post processing
Photo © Alex Beltyukov - RuSpotters Team
vikkyvik
Wed Sep 14, 2011 8:51 pm
Quoting RonS (Reply 15):
Just to offer a different method - I don't use Smart Sharpen; I use Unsharp Mask.
Never tried Smart Sharpen, to be fair.
ACR for PS5 has freaking great NR. It reduces detail quite a bit less than other NR I've used.
Once I export the JPEG, I'll only use NR selectively on areas that need it.
Same here. Editing can generally take anywhere from 5 to 15 minutes per shot. Sometimes I think I'm too anal when it comes to editing for A.net, but hey, it's worth it in my opinion, and I actually kind of like the whole process.
And it doesn't change the fact that you need a good capture to start out with.
Quoting chris78cpr (Reply 16):
I applaud anyone who takes the time to get the shot the best they can in camera, in fact it's a quality that i recommend to other people all the time. What i am not overly keen on is this attitude that everyone else is inferior because they may choose to use levels, curves and other processing techniques.
Pretty much. Post processing is a major option in the digital imaging world, and I don't see any reason not to take advantage of it. Yes, I like to get my exposures, etc. correct, but it's a learning curve that I'm still climbing.
[Edited 2011-09-14 16:32:52 by srbmod]
alevik
Crew
Wed Sep 14, 2011 11:17 pm
I agree that some difficult conditions require some processing than your basic side on sunny sky images. I guess I tend to agree with Viv that although some shots might take more than a couple minutes, generally for a site like anet or jpnet if you are spending more than 4 or 5 minutes editing one image, I can't imagine what could take that much time.
Even the image that sovietjet linked to from Alex B - still a 5 minute job. I'm just trying to paint a picture of effort for a new guy - you won't need to spend an hour on one image to edit it - I think we can all agree on that. The min to max must be in the 2 to 10 minute range?
I just shot a few days ago some dusk/evening stuff. This one took only three or four minutes:
This one also took three or four minutes, but I need to find a noise reduction program to run it through (never had had the need for one):
PS - if someone has a recommendation for the noise reduction - let me know. I use Elements 9 on a Mac
Pete
Improvise, adapt, overcome.
RonS
Wed Sep 14, 2011 11:20 pm
Quoting vikkyvik (Reply 20):
Try it, let me know. It was recommended to me by Dan V and he's quite knowledgeable about editing, so generally I listen to him and I have success.
Yes, most def. It has the same NR as LR3 does...which is very good.
sovietjet
Wed Sep 14, 2011 11:23 pm
alevik - Try Neat Image. I just ran your photo through it and got pretty good results.
darreno1
Thu Sep 15, 2011 1:18 am
IMO, how long it takes to edit depends on several factors. Initial quality is obviously one and that is influenced by weather conditions, equipment, and photographer skill. Another is picture size. The bigger the picture, the more care has to be taken during editing as flaws tend to be easier to see. I often upload in the 1400-1600 pixel range (which seems to be the frowned up range for obvious reasons) and can easily spend 10 minutes on one photo. For a beginner, I'd recommend getting as intimate as possible with the software side of things and research and practice different work flows. The more you know about the various settings, the easier it will be to fine tune the work flow for efficiency and desired results. As time progresses, your skill will increase which will in turn lead to better initial quality and less / quicker post-processing.
viv
Thu Sep 15, 2011 9:25 am
My original post (quoted below) seems to have ruffled some feathers here. This was not my intention.
On reflection, I should have worded my final sentence as follows: "That's it. If I need to do more, my original image was not good enough".
Hopefully all cause for offence is now removed.
Regarding workflow, of course each photographer here will go his own way. But I am amazed at the lengths people will go to in post-processing to bring an image up to scratch, when more care at the time of shooting would obviate the need for most of that work.
[Edited 2011-09-15 02:27:17]
spencer
Thu Sep 15, 2011 12:46 pm
I think that's a fair comment Viv. You said what you said and pretty much stuck to your guns. I, on the other hand, edit anywhere between 3 and 20 minutes per shot. A LOT of my stuff here has pushed boundaries within the acceptance criteria for A.net, had you seen the original file. I really like editing but I have to be in the right mood for those 20 minuters!
Spence
JakTrax
Thu Sep 15, 2011 1:11 pm
I disagree with this. Cheap lenses used within their limitations can produce wonderful images. Often, you'd be hard-pushed to tell the difference between a shot taken with a kit lens and an L (referring to Canon's line of course). Once resized, it's impossible.
Quoting chris78cpr (Reply 6):
I still use Elements 5.0 and it has more than enough features for me. I even do more advanced stuff with it. I agree that less is more - just because you have the latest version of CS doesn't mean your images will look any better. My workflow is EXTREMELY basic, consisting usually of cropping (if necessary), perhaps the odd colour/contrast tweak, resizing and sharpening. To a point I agree with Viv - the more work you have to do, the worse the original image tends to be (talking basic blue sky shots, etc.).
Karl
HarryImp
Thu Sep 15, 2011 4:15 pm
Many thanks for help.
If i go onto smart sharpen (CS5 i have) what settings do I want to get it right??
And how do i use the NR on ACR? I have been told setting luminance to 50 is this right, or is there better??
Many thanks
Harry
notaxonrotax
Thu Sep 15, 2011 4:49 pm
A pictures speaks a 1000 words!
Here´s 2 random examples of my editing work of late:
Original:
After the No Tax On Rotax-edting magic:
Cessna Husky
Here´s another picture I improved………or so I´d like to think:
MXP 800 Fantasy
Look:
HC-U0029
Please give me any feedback, where do I go wrong? Is there any hope at all?
Nikon D3100 lens, 18-55mm.
No Tax On Rotax
RonS
Thu Sep 15, 2011 5:15 pm
Quoting JakTrax (Reply 22):
To reach the Anet standards, for me it does. While my MBP was in the shop this week replacing the HD, I used my old gateway laptop which only has CS3 on it. The difference in quality of my final product on a number of sunrise / low light shots I edited is easily discernible from those I edited in the same day using LR3 and CS5. You can easily tell which was edited in which. Granted, the biggest differences are the advanced NR in the LR3 (and CS5) products. Blue sky shots, it would be hard to tell, but I didn't get LR3 for that...I got it to deal with higher ISO shots.
Quoting viv (Reply 20):
Viv, i agree, I do try take care during shooting, I'm working on it. I will say though, it is all relative about the "up to scratch" part. If we're talking the high standards at Anet, then yes. We have to take extra care while shooting and even more so while editing, it is the way of the world normally around here. If you're just talking photos in general, for other sites, yourself, publication, 2 minutes is enough...not here though (normally) for me!
vikkyvik
Thu Sep 15, 2011 5:49 pm
Quoting RonS (Reply 25):
gateway laptop
Damn! Haven't heard of Gateway in years! I remember when we had a Gateway 2000 (at the time) PC back in the 90s; it came in the cow-spotted box.
I agree. Though, I've had some shots where I wouldn't consider the original RAW file all that high-quality, that I've still managed to edit and get accepted here.
But yeah, like you Ron, I'm still working on this whole "photography" thing.
And my editing of shots for my own website or whatever really does only take about 1-2 minutes per shot.
Quoting HarryImp (Reply 23):
Experimentation is really the only way to figure it out. Took me awhile to figure out how much was enough and how much was too much. Now I have 3 different NR presets saved in ACR, and I'll pick whichever one the image needs. None of the 3 settings exceeds 40 on the slider, though....and I really try not to use my "heavy NR" preset that does use 40.
Users browsing this forum: JimDreamliner, solro and 11 guests
