clickhappy
Reuters Have Stolen My Picture - Now What?
Fri Sep 16, 2011 3:48 pm
Reuters
http://www.flickr.com/photos/royalscottking/6103871004/
If you resize my photo to match, and rotate .15 left it is a perfect match. I know this photo is mine, the shadows on the ground, from the flags, were only there for a couple of minutes, before they started tearing the podium down.
Any idea who to contact at Reuters?
Many thanks in advance.
kiffy
Crew
RE: Reuters Have Stolen My Picture - Now What?
Fri Sep 16, 2011 4:48 pm
Hmm seems interestingly similar but the 'Reuters' version seems to have a shadow in the bottom corner and yours does not..
Reuters: http://farm7.static.flickr.com/6085/6152886161_c579b1f011_b.jpg
Yours: http://farm7.static.flickr.com/6188/6103871004_8186e7a16c_o.jpg
I hope this can help,
-Chris
Jez
Fri Sep 16, 2011 5:05 pm
The highlights on the fan blades also look different. To my eye the distance from the pitot under the nose to the top of the barrier also appears different as if the Reuters shot was taken from a slightly lower angle?
[Edited 2011-09-16 10:12:31]
clickhappy
Fri Sep 16, 2011 5:23 pm
Great find Chris - I guess lightning does strike twice. Hard to believe...
ptrjong
Fri Sep 16, 2011 5:48 pm
I didn't buy it at first, but yes, there seem to be some differences.
Look at the two aerials or bulges below the rear fuselage. The pointed shadow below the left one seems to be substantially farther to the left in the Reuters picture.
The shadow in the corner is just visible in Royal's photo too I think, so the one in the Reuters photo is probably real. Also, in addition to shadow in the corner, the leftmost shadow from the flags seems to be longer in the Reuters picture. So at least the Reuters photo wasn't simply cropped from Royal's photo.
Maybe very subtle, willful Photoshop manipulation to create differences, but I'm inclined to say a different photo from very nearly the same angle.
Peter
unattendedbag
Fri Sep 16, 2011 6:00 pm
Quoting clickhappy (Thread starter):
Were you alone when you took that photo? Right next to the number 1 engine, there appears to be a tree behind the blast fence. If you look close enough, the tree is in slightly different positions in each photo. The photographer must have been standing right next to you Royal.
Also, for added clarity, a link to the reuters photo.
http://www.smh.com.au/photogallery/t...20090501-aq01.html?selectedImage=0
[Edited 2011-09-16 11:04:33]
Slower traffic, keep right
clickhappy
Fri Sep 16, 2011 6:02 pm
Yeah, whats weird is there was no one else there, and I wasn't standing, I was sitting on the ground.
Silver1SWA
Fri Sep 16, 2011 6:10 pm
Quoting clickhappy (Reply 6):
Judging from the slight shadow differences, the Reuters shot must have been taken just a few minutes before or after. The angle is remarkably similar though...crazy stuff!
Jez
Fri Sep 16, 2011 6:13 pm
Maybe the title of the thread needs to be changed as Reuters have seemingly been wrongly accused?
cargolex
Fri Sep 16, 2011 6:30 pm
Since I have a Reuters account as a photo buyer, I looked this other photographer up (I also figured logging on, which I almost never do, might give me a lead as to where to send you). He was definitely there, and his photos of the event are extensive.
My next instinct was to see if anybody had bought the photo and displayed it on the web at a larger size, and indeed, somebody has:
http://www.boston.com/partners/gread.../ipad/images/27boeing__960x600.jpg
This detail can't be from another image just because I can see what he's got up on the Reuters site.
They were probably taken within minutes or even seconds of each other from almost the exact same spot at almost the exact same angle at the exact same time. At first glance, they're indistinguishable from one another - but on closer inspection as the others noticed, they're not the same. The thing that tipped me off was the height of the blast wall relative to the nose gear door and the "chin" of the aircraft. His lens has more curvature than yours, for sure, the edge of the randome on his is much more warped.
alevik
Crew
Fri Sep 16, 2011 6:36 pm
If you go sportsshooter.com you can see his profile and there is a contact form.
http://www.sportsshooter.com/members.html?id=1680
Improvise, adapt, overcome.
ptrjong
Fri Sep 16, 2011 6:38 pm
Maybe he saw you and thought, that looks like a good idea.
clickhappy
Fri Sep 16, 2011 6:43 pm
Haha or maybe I ripped him off
You guys should be on CSI, thanks for all the effort
Rotate
Fri Sep 16, 2011 6:48 pm
WOW ...
this was solved very fast. Would have been a big blow, if they stole the picture.
ABC
spencer
Fri Sep 16, 2011 8:24 pm
Hey Royal, get those eyes checked mate, your screening might come a cropper!
Spence
unattendedbag
Fri Sep 16, 2011 8:40 pm
No watermarks there Head Screener? I know they would have been wrong to steal your photo, but there are measures you can take to protect yourself.
dvincent
Sat Sep 17, 2011 3:23 pm
Watermarks are easily defeatable if you pay for a first class membership.
From the Mind of Minolta
unattendedbag
Sun Sep 18, 2011 9:48 am
Quoting dvincent (Reply 16):
The photo referenced above was on flickr.
gabik001
Sun Sep 18, 2011 1:58 pm
It does not look like the same photo . Look at left main gear.
Canon 50D gripped + Canon 70D + 17-40 L + 24-105 L IS + 50 f/1.8 STM + 100-400L IS USM + Minolta X300 w/ 35-70 f/3.5
photopilot
Sun Sep 18, 2011 2:55 pm
These are clearly NOT the same image as a close look at both shows many differences.
As a side note, Reuters is a well respected professional news organization and while many little publications might stoop to stealing an image, Reuters is not one of those. IMHO, it does a great disservice to Reuters to suggest this.
The title of this thread should be changed immediately, because as it has been clearly demonstrated to be wrong, letting it remain titled as written is nothing but smearing Reuter's name.
clickhappy
Sun Sep 18, 2011 4:59 pm
I'm locking this thread as it has been answered. Thanks to those that offered help.
