stevemchey
New Sharpening Method In PS CS5
Wed Sep 28, 2011 5:58 pm
Has anyone played with this new brush based sharpening method in PS CS5 yet? How does it apply to sharpening images for a.net? Could that mean the end of "Copy layer > sharpen > mask/erase parts of the new layer"?  Photoshop CS5 hidden gem: Brush-based sharpening
dvincent
RE: New Sharpening Method In PS CS5
Wed Sep 28, 2011 8:48 pm
Hmm, I haven't tried that. I'll have to give it a go. I recently upgraded to CS5 at home and work.
The benefit of the layer mask method is non-destructability - you can always paint in more or less sharpening between the two. This appears to be destructive, just as if you used the paintbrush or clone tool. Again, I'll look into it and give a report.
From the Mind of Minolta
darreno1
Thu Sep 29, 2011 12:34 am
Thanks for posting! I like many others didn't even know that existed. It will surely come in handy for selective sharpening.
Nikon D7000 / Nikkor 105mm AF f2.8 / Nikkor 35 f1.8G / Nikkor 50 f1.8D / Nikkor 85mm / Nikkor 300mm f4 AF
ckw
Thu Sep 29, 2011 8:28 am
Quoting dvincent (Reply 1):
But could be applied on a duplicate layer (or layers) giving you complete control after application.
Colin
Colin K. Work, Pixstel
hrtsfldhomeboy
Fri Sep 30, 2011 6:54 pm
Just gave this technique a quick try.. come to find out it was already on on my CS5 and didnt even know. Yah, it introduced less grain into the image, but.. for A.net standards, it still makes too much grain. Photoshop will have to do better to give us tools so we can please the screeners.
... or a.net can quit nitpicking?
Taca300C
Sun Oct 02, 2011 12:07 am
Quoting Hrtsfldhomeboy (Reply 4):
spencer
Sun Oct 02, 2011 7:52 am
This may well be a new feature but ever since CS2 I have used something similar by sharpening in Lab Colour. Same sort of deal, ie mark out the area with a brush and apply sharpness. I'll definitely give this a go though, seems easier.
Spence
Granite
Sun Oct 02, 2011 8:06 am
Hello
A lot of different sharpening methods, layers, masking, erasing etc. but I am still using the plain old Unsharp Mask in my old version of CS2 and works perfectly for me. Don't see the need to do anything else.
Gary Watt - Granite
Airliners.net Head Screener
www.airliners.net
http://twitter.com/airliners_net
teopilot
Sun Oct 02, 2011 9:34 am
Quoting granite (Reply 7):
Hello
Yeah... I agree with you! Definitely!
It's since about a year that I've started using this technique, and I have no complaints about it!
I've also tried several other techniques suggested by some friends of mine and, just like you, I had never felt the need to have a change, but I wanted to try... and, to be honest, the best results were with my "old" technique. Maybe I'm not good to use any other sharpening workflow, so... I'm still attached to my old one!
spencer
Sun Oct 02, 2011 3:14 pm
Fair comment. And if it's working for you I'd stick with it. I suppose I like to experiment more than others, so I've sharpened in Lab Colour, Smart Sharpen, USM and even in Noise Reduction. I'll use layers and masks when I can though and normally apply too much first then work it back. Right now I'm just using Smart Sharpen but I will give this hidden gem a tickle later.
Spence
Granite
Sun Oct 02, 2011 7:44 pm
Hi Spencer
Quoting spencer (Reply 9):
Yep, everyone will have something different so whatever works for them is good. I try to use the same technique on my colour negative scans too. A lot more work but a lot more satisfaction when you get a good result.
Gary Watt - Granite
www.airliners.net
stevemchey
Mon Oct 10, 2011 7:14 pm
While we are on the subject of sharpening... here is an interesting video from AdobeMax last week. They give a sneak peak of an Image Deblurring tool that may or may not make it into a future version of PS.
PS: The video itself is blurry, so the effect doesn't show perfectly. I hope to see a better video of this in the future.
NPeterman
Tue Oct 11, 2011 2:21 pm
I may give this a shot just to see how the end result works. To be honest, I've never even used unsharp mask for my sharpening (probably is vastly superior to what I do anyhow) but its always interesting to see new ways of tackling an old problem.
je89_w
Crew
Tue Oct 11, 2011 4:28 pm
Quoting stevemchey (Reply 11):
Wow, that is pretty cool. Yes, would like to see a better version of the video, but it seemed like everyone was blown away.
Dehowie
Thu Oct 13, 2011 12:43 am
One of the very cool things is it's pressurevsensitive to the stylus on my Intuous stylus.
Works beautifully little pressure giving very light sharpening to heavy pressure giving lots.
Nice addition to the tool set.
2EOS1DX,EF14.2.8LII,17TS,85/1.2,16-35L,24-70LII,24L,70-200F2.8LII,100-400,300/400/500/800L
