airkas1
Crew
Some Questions About The 5DMkII
Mon Oct 24, 2011 11:39 am
Hi all,
I'm looking to upgrade my camera from a Canon 40D to either a 5DMkII or 7D. I've made myself acquainted with the pro's and cons of each camera, by reading reviews on the internet, advice that was given to me by a few other photographers and a couple of threads on this board (that are now archived).
I've more or less decided that I want to try and get a 5D, but still have some questions about it. As for the rest; I plan to keep the 40D as second body. My photography subjects are mostly aviation, but also holidays, nature, basically anything tbh... Main lenses are 10-22, 70-200 F4 and 100-400 currently.
I know the 5D beats the 7D in image quality, which is of course a big plus. Regarding it being a full-frame camera, I think with my zoom lenses and the fact that I can always crop later, range won't be a big problem. But while reading reviews it was mentioned at some point that the 10-22mm doesn't work on the 5D? That's a major bummer, but I couldn't find why exactly they don't fit. So how come the 10-22 doesn't work combined with the 5D? Which lens would you recommend for very wide-angle photography on the 5D? The other lenses will work fine on it, right?
I also realize that the low FPS/'slower' AF of the 5D will not be a problem with the majority of subjects that I photograph, with the exception for aviation. Have any of you had any 'problems' with the fact that the 5D has low FPS/'slower AF' (when it comes to aviation)? I often get static (parked) aircraft in front of my lens, so my only concern is shooting moving subjects. It would require less "spray and pray", but that can only be a good thing
Any tips/tricks/things to keep in mind are more than welcome!
-Kas
[Edited 2011-10-24 04:43:12]
Airliners.net Crew - Head Photo Screener
lgw340
RE: Some Questions About The 5DMkII
Mon Oct 24, 2011 11:54 am
Quoting airkas1 (Thread starter):
Because it has a Canon EF-S lens mount. The 5D/5D II/1D Series cameras only take EF lens mounts. If you have the money, the Canon 16-35mm or 17-40 are great options.
Chris Goodwin
Live life from the window seat...
RonS
Mon Oct 24, 2011 12:21 pm
You could also rent and try the 8-15 f/4 fisheye, I can see you getting some really nice wide angle wing shots that you like to get, and also some interior corporate shots. It is expensive though and a couple people have described it as more of a novelty lens. I would love the 16-35 2.8 if money was not an issue. Also, I have never used it, but research the Sigma 12-24. 12MM on a FF would be very interesting. http://www.sigmaphoto.com/shop/12-24mm-f45-56-dg-hsm-ii1
I have always been impressed with the photos I see from the 17-40 f/4 and also the build of it is very nice, better than the 24-105! It's also relatively inexpensive when compared to the 16-35 and 8-15, making it an excellent value. You would only be losing 1MM of range, not a big deal!
Lately I've been looking at Ander Aguirre's photos with 5d2 and 17-40 and he has MANY jaw dropping photos of non aviation subjecs. His photos are enough to convince me that the 17-40 on a 5D2 is the way to go.
Canale in Venezia by AnderAguirre, on Flickr
Notre dame by AnderAguirre, on Flickr
[Edited 2011-10-24 05:30:40]
All opinions expressed by me are my own opinions & do not represent the opinions in any way of my employers.
ANITIX87
Mon Oct 24, 2011 1:18 pm
Canon has two types of lens mounts. The "EF" lenses work with any Canon EOS dSLR and are ideal for cameras with full-frame sensors. There there are the "EF-S" lenses, which have smaller image circles and are made for APS-C crop factor cameras (XXD and XXXD series). Since they project a smaller image circle, they can be smaller and lighter than their EF counterparts. The 10-22 is an EF-S lens, so it won't work on the 5D. You may ask, "Well, can't I just put it on and crop the black circle that will happen around my image?" The answer is: NO*. The EF-S lenses have a rubber piece that projects into the camera body, and some move the rear-most element into that area on focusing or zooming. The mirror on the 5D and 1D cameras is too large, and will hit the rubber or the rear element and shatter.
*Third-party crop factor lenses (like Sigma's DC lenses) can sometimes be used on the 5D and 1D series with no physical drawbacks (though you will still get the black circle around the outside where the image circle doesn't fall on the sensor). That's because the physical mount is the same, the rubber piece isn't there, and there's no projection into the body on focusing or zooming.
TIS
IL76
Mon Oct 24, 2011 2:25 pm
17mm on a full frame is already super wide:
Pen-y-fan/Corn-Du, Wales. 5DmkII + 17-40L f4
sovietjet
Mon Oct 24, 2011 4:14 pm
Hi Kas, let me say that I did this EXACT same upgrade. With the exception of the 70-200 I had all the same glass and a 40D. I ended up going with the 5D instead of the 7D. Really, the 5D has the same autofocus as the 40D which I was already happy with. Since I was planning to keep the 40D as a second camera, I would already have a "spray and pray" body if I really needed it, so FPS didn't matter much. But the 5D's superb image quality combined with low noise at higher ISO really did it for me. After upgrading to the 5D, I don't think I've ever used an ISO lower than 500 (besides for propellers). There's no need to "spray and pray" with this camera, since almost every photo comes out with exceptional quality. You can crop a RIDICULOUS amount and still get good results. Can't say the same about the 7D (I have used it before to try it out). Don't get me wrong, the 7D is a great camera still.
Yes, the 7D will offer a bit more "zoom" because of its large megapixel count and 1.6x crop frame. But on the other hand, this large megapixel count doesn't mean you can crop as hard as you can on the 5D, because the 5D has better image quality and everything just looks "cleaner". Therefore my personal opinion is that the 7D only has a slight "zoom" advantage.
As far as the wide angle. Yes, I had a 10-22 as well. It didn't work on the 5D. You basically have two choices.
1) Keep the 10-22 and use it on your 40D while putting the long lens on the 5D. With two bodies, it's so easy to take photos of static aircraft at an event while keeping the zoom lens on the other body in case there is something in the air you want to shoot right away.
2) Sell the 10-22 and buy a 17-40. They are priced the same. This is what I did. Since the 40D is a 1.6x crop frame, a 10-22 really is equal to a 16-35 on a full frame. So the 17-40 on a 5D is pretty much the same as a 10-22 on a 40D. On occasion if I really need the telephoto I will keep it on the 40D just in case, while I shoot wide angle with the 5D.
If you have questions let me know
airkas1
Crew
Mon Oct 24, 2011 4:23 pm
Thanks for all the detailed info and example photos guys!! It's much much appreciated and I've gotten to understand everything more clear now. I've been looking around for good deals and the cheapest I found so far is a 5D body + Grip + 17-40 for 2600 Euro. It's lots of money, but I'm sure well spent on the above. Not sure if I will sell my 10-22, but I can think about that later. I'll let the idea soak in my head for a few days before making the decision what I will do
[Edited 2011-10-24 09:24:09]
jforbes
Mon Oct 24, 2011 4:49 pm
You're probably fine selling the 10-22 - it's pretty much the same range as the 17-40 if you use it on the 5D, and given the 5Ds size, you're not going to be bringing the 40D for shooting that stuff - you'll be best off shooting the 17-40 on the 5D and the 70-200 or 100-400 on the 40D if you have two bodies with you. And if you're all telephoto, probably the 100-400 on the 40D and 70-200 on the 5D for closer stuff.
andrew50
Mon Oct 24, 2011 5:03 pm
I will stick with my 2 40D's. The image quality with the L glass on a 40D is superb! From shots I have seen on a.net where the photographer lists the 5D or even Nikon full frame cameras, I sure can't see that the image quality is any better! In my opinion the the quality upgrade if any, isn't worth that kind of money. Strictly talking aviation photography.
Silver1SWA
Mon Oct 24, 2011 6:50 pm
Quoting andrew50 (Reply 8):
Well if we're strictly talking aviation photography, I can't really think of many reasons to get a 5Dmk2. The benefits are mostly seen in other types of photography.
The full frame advantages that appeal to me are landscapes and better DoF control. For the 5D specifically, low light photography and the ability to retain details in shadows are big pluses.
I have the 7D and I love it's speed. Haven't had any issues with image quality.
javibi
Mon Oct 24, 2011 8:50 pm
Unless aviation photography in low light is your thing... In that situation the 5DII is clearly better than the 40D, IMHO.
j
sovietjet
Tue Oct 25, 2011 1:13 am
Just to go along with what I talked about above, here's how much you can crop with the 5D. Here's the original uncropped unedited image (only resized so it is a normal on the forum). One thing I forgot to mention was the vignetting you get on the 5D with the 100-400 lens. You can see it in the photo below
And here's the result
Photo © Ivan Voukadinov - BGspotters
NPeterman
Tue Oct 25, 2011 1:41 am
Good Lord Ivan! When you told me that you could crop with the 5D, I didn't realize that you meant that you could lop away half the freakin' photo! Thats unreal
RonS
Tue Oct 25, 2011 1:48 am
Quoting NPeterman (Reply 12):
Half, that's like 75%!
Ivan, can you tell us what the pixel dimension were before crop and after please?
That really is incredible. Don't make me add another THING to my wish list.
sovietjet
Tue Oct 25, 2011 4:51 am
So original image resolution was 5616x3744. After crop it was approximately 1485x990. Then edited and resized to 1024 pixels wide and uploaded here. Not sure how people calculate crop percentage, but if it is by area (logical), then that is about 93%? (1 - (1485*990)/(5616*3744)) = 0.93 I hope my math is right
Granted it's not my best quality upload on a.net, and it was rejected once before it got accepted (for contrast if I remember correctly). But the quality still is there, even with the obvious non-ideal shooting conditions. Also, I was a forgetful idiot and shot this in JPG (not RAW)       . 1/1250, f9.0, ISO500. With some work, it is possible to crop heavy and get images on here. Hope this helps.
clickhappy
Tue Oct 25, 2011 5:26 am
Wow - if that accepted photo is a crop of that image you have killed digital photography for me.
I guess it really is about post-processing. Wow.
Tue Oct 25, 2011 5:41 am
Thats unreal
Absolutely insane! Well you've sure got me thinking about the 5DIII over the 7DII, that's for sure (on the assumption that these bodies are released as the next version of their respective bodies a few years down the line).
comairguycvg
Tue Oct 25, 2011 6:29 am
I have a 5DII and one thing I have noticed is that in clear sky conditions, rings appear in the photo. In the example I have attached below, I brought out the rings by simply reducing highlights all the way as far as the slider would go. I have a 100-400L lens that I use. I didn't do anything else to this image as far as sharpening or crop, just re-sized to upload here on this post. It's just about impossible to notice the rings in the original unedited JPEG image, but in some of my shots you can start to notice them as you make adjustments to the contrast and highlights, ect. I'm not sure if this is a trait of all DSLR cameras, but I'm still learning how to use it.
Worked at: CV62, RJTA, KNLC, CV63, KNFL, OKAJ, KTRI, CV67, KMGE, KNQX, KVPS, KPIT, KCVG, KTYS, KATL
jforbes
Tue Oct 25, 2011 7:52 am
comairguy:
The rings are there because you're taking the data that was in the original image and, say, spreading it out as you adjust exposure and contrast. If you're shooting JPEG images, you will encounter this more frequently than if you shoot in RAW. It is generally a sign that you're doing too much to the image - and it looks like you've been playing around with that one a bit too much :P
It could also be if you're dealing with lower quality JPEG files - they retain less color data, and what you're really seeing is what was originally a very smooth gradiation of color, being compressed from being thousands of shades to being hundreds of shades, to being tens of shades of the same color. As there is less color, the rings will become more prominent.
It could *also* be due to the software you're using. Not all software is created equal.
sovietjet:
Yes, you cropped away 93% of the image. Only 7% of it was there. It wasn't 1/2 or 1/4... more like 1/14th! A 7D shooter wouldn't need to crop nearly as much off because it is already cropped by about half - but that you cropped so much of the image off, down to a 1.5MP image and got a result so good is very impressive. I'd feel comfortable lopping off half or more of an 18MP 7D image, but 7%, or, say, 12% if you want to factor in the inherent crop would really be pushing it!
ckw
Tue Oct 25, 2011 8:22 am
Quoting clickhappy (Reply 15):
How so? No one has cropped a negative before? I think the point here is while with some cameras we can use size reduction to improve apparent sharpness and/or minimise noise, output from the 5D (old or new) is very good straight out the camera. I'd say images from my 5D need the least post-processing of any DSLR I've owned.
Sometimes its what you don't see that matters! But seriously, comparing cameras by looking at processed jpgs on the 'net can be very misleading. I think if you compared full out-of-the-camera images from your 40D against a 5D you'd come to a different conclusion
Colin
Colin K. Work, Pixstel
airkas1
Crew
Tue Oct 25, 2011 10:16 am
Quoting sovietjet (Reply 11):
Quoting sovietjet (Reply 14):
93%
HOLY SH*T!    That's a great example of what the camera it is capable of!
comairguycvg
Tue Oct 25, 2011 10:20 am
Here is another example I have found in some of my shots with the 5DmkII and the 100-400mm lens as far as shading is concerned with darker areas. This is a very cropped in sample of this shot to put on this post. You can see it's pretty blotchy in the darker areas. I'm sure that ISO and shutter speed settings could be adjusted for better results? This image is also a JPEG. You can click on this image to see a better resolution of the shot.
airkas1
Crew
Tue Oct 25, 2011 10:26 am
Quoting comairguycvg (Reply 17):
Quoting comairguycvg (Reply 21):
Thanks for the examples! In the first shot I failed to see the rings though, or did you mean arcs (like a rainbow) in the sky?
comairguycvg
Tue Oct 25, 2011 10:32 am
Quoting airkas1 (Reply 22):
Yes it's the rings/circles/rainbow in the blue part of the sky.
sovietjet
Tue Oct 25, 2011 12:52 pm
Why? DSLR technology improves every year. Cropping that much on a 20D 6 years ago would've been impossible but on today's cameras it certainly is. I see no reason not to take advantage of it. I'm in no way a post processing buff, I frequently need help with it and I did only the basic post processing to that photo. If the quality is there, why not use it?
eggohoek
Crew
Tue Oct 25, 2011 3:01 pm
I have 40D and 5Dmk2.
Quality difference of 5Dmk2 vs 40D = 40D vs compact digital cameras.
You can see the difference:
-in low light
-at full size
-40D with better lens like 5Dmk2
jspitfire
Tue Oct 25, 2011 4:10 pm
Right now I'm really happy with my setup: Canon 5D Mk II, 16-35 F2.8, 24-105, and 100-400. Personally I went with the 16-35 instead of the 17-40 just because I could get f2.8, which is a huge help when I'm taking my northern lights shots.
And I must admit, I'm a big fan of being able to crop as well!
Photo © Jason Pineau
flood
Thu Oct 27, 2011 1:12 am
I'll venture to guess it was shot underexposed and you were trying to extract detail from the shadows which just wasn't there.
chris78cpr
Thu Oct 27, 2011 12:34 pm
I own both the camera's in question and if i only had your lenses i'd get the 7D.
I will not use my 100-400 on the 5D2 as it vignettes very badly and really isn't quite good enough for a sensor of that size/quality. On the 7D it's a cracking lens and is my go to long range combo for aviation.
If you had a 70-200F2.8 then i'd say go 5D2. It's a great combo with a 1.4x and is my most used thing for shooting at LHR.
I bought my 5D2 primarily for uses outside aviation and bought the 7D for aviation. While i use both i know which i'd choose if aviation was my main subject and i had your lenses.
Chris
5D2/7D/1D2(soon to be a 1Dx) 17-40L/24-105L/70-200F2.8L/100-400L/24F1.4LII/50F1.2L/85F1.2LII
airkas1
Crew
Thu Oct 27, 2011 2:00 pm
Hmmm, I ordered it earlier this afternoon
I have enough uses for it outside of aviation though, especially with a few trips coming up.
comairguycvg
Fri Oct 28, 2011 8:07 am
Quoting chris78cpr (Reply 28):
What would be a good high power zoom lens for the 5D2?
comairguycvg
Fri Oct 28, 2011 8:25 am
Quoting JForbes (Reply 18):
I currently use Photoshop Elements 6. Should I look for another version for better results?
andrew50
Fri Oct 28, 2011 11:23 am
Quoting ckw (Reply 19):
Not sure how true that is since I don't own a 5D, but to me it's the final product that counts!
Quoting eggohoek (Reply 25):
Funny, you might need to check out my photos with that 40D!
chris78cpr
Fri Oct 28, 2011 2:17 pm
Quoting comairguycvg (Reply 30):
The only thing i'd put on the front of mine currently is a 70-200F2.8L with 1.4x or maybe the 2x (mkIII).
The 100-400 is a great lens but vignettes badly and soften's up at 350-400mm, mine is totally unusable on my 5D2. The 28-300 doesn't really do it for me from what i've seen of the results either.
I guess the newer 70-300L could be good but i've not seen any results when it's used with a 5D2 yet. Despite spending the last 12 days with a friend who owns one! lol.
I imagine the upcoming 200-400 will be a cracking long range zoom lens for the front of the 5D2 or upcoming 1Dx.
The 5D2 is a fantastic camera with one of the best sensors that has been put out by canon but it really does demand a lot from the lenses used on it. I've just bought 3 L primes for use when shooting weddings as the 24-105/17-40 just were not cutting it on the camera.
Chris
spencer
Fri Oct 28, 2011 6:59 pm
Swap 5D2 with 1D4, then everything you said is how my gear is set up most the time! To tell the truth I don't think I've even set the 100-400 up on the 1D4 as of yet.
Spence
eggohoek
Crew
Fri Oct 28, 2011 9:38 pm
Quoting andrew50 (Reply 32):
I have both 40D and 5Dmk2 and I can check the difference at full size.
I like 40D, but it's only a toy camera
comairguycvg
Tue Nov 01, 2011 9:23 am
Quoting chris78cpr (Reply 33):
How about a 400m or 500mm with the 5D2? any experience with those types of lenses?
chris78cpr
Tue Nov 01, 2011 11:54 am
Quoting comairguycvg (Reply 36):
Shot with a 300F2.8LIS and 1.4x on the 5D2 and it was a fantastic combo. Not used a 400 or 500 prime on this camera but from what i gather all of the Canon IS primes, gen 1 or 2 will work very well on the 5D2.
I have no experience of using the 300F4 or 400F5.6 on the 5D2.
javibi
Fri Nov 04, 2011 11:58 am
Most of my shots are taken with the 5DII and EF 500mm f4 IS, often with a Canon 1.4x; great combo, no problems whatsoever IMHO.
j
FYODOR
Fri Nov 04, 2011 7:03 pm
5DMk2 is truly anither world of cameras in compare with cropped X0Ds. I have backup camers 40D and 30D, but since I've started to use 5D I try not to use anything else.
In addition to all points besides obvious benefits from full frame I'd agree with the point regarding high ISO. 1600 is fine enought and even 6400 is working.
Example of this:
10 mm fisheye is excellent wideangle with 5D:
Photo © Fyodor Borisov - Russian AviaPhoto Team
Low speed is a kind of problem, however if you come from films - you just need to remember your old skills and just to be more focused on result for each shot. It help you to save space on your HD as well  .
Fyodor
RonS
Tue Nov 08, 2011 2:45 am
That's a bold statement! Very hard to believe. But obviously you have pushed the 40D to the limits and are doing very well with the 5d2. Your older shots with the 40D are still stunners though, great ones in fact. I can't tell your older shots from the 5d2 at the Anet resolutions though. You almost make me want to try the 5d2.
Kaz, best of luck with your purchase.
airkas1
Crew
Tue Nov 08, 2011 2:29 pm
Thanks Ron!
I've had it for a week now and I love it! The image quality is just so amazingly good compared to my 40D (which still serves me well as second body!). The fact that it has low FPS hasn't bothered me yet and the first pics taken with the 5DMkII are up for screening soon
The 17-40 with the 5D is indeed a very good combo and I've been using it a lot this last week. We had another KLM B777 for a low approach last friday, weather was perfect and the abvoe combo proved excellent to capture it. Hopefully the photo will be in the DB soon
The only thing I didn't take into account was that I needed CS4 or higher to be able to process the RAW files that the 5D produces. That was quickly solved by acquiring CS5 though and everything works like a charm now
jforbes
Wed Nov 09, 2011 7:06 am
To the person with the 10-22 and a crop camera looking at a 5D: Replace the 10-22 with a 17-40L. They cost about the same, the image quality is fairly similar, the 17-40 is a nice ultrawide on a full sized sensor, but it's also a decent normal zoom on a crop camera, too.
Quoting comairguycvg (Reply 31):
If you're just shooting JPEGs Elements 6 is fine. If you're shooting RAW, Elements 6 uses an older version of Adobe Camera Raw, which has had a lot of improvement over the years. I would recommend you try Canon's own RAW conversion software first - it is free and makes good results, and if you like the results of a better RAW converter, give Lightroom a try. Lightroom isn't a direct replacement for Elements or Photoshop proper - you may still want to use Elements on the side (they will play together fine). You can get a 30 day trial from Adobe's site, and it goes on sale for $150 with some frequency. A newer version of Elements will probably also have a newer version of ACR - which would be worth looking in to. One good free RAW converter is Raw Therapee - it isn't as good as Canon's or Adobe's current offerings, but it may be better than what is in Elements 6.
Dehowie
Wed Nov 09, 2011 1:31 pm
Another option is to convert the files to DNG format then you won't have any RAW issues at all..
2EOS1DX,EF14.2.8LII,17TS,85/1.2,16-35L,24-70LII,24L,70-200F2.8LII,100-400,300/400/500/800L
Users browsing this forum: dvincent and 1 guest
