ocean773
Advice On Nikon D5100 Setting For Taxiway
Sat Jan 14, 2012 2:03 am
Hey guys,
Just got my Nikon D5100 with 18-105mm VR lens. Need help in camera setting for taking photos of aircraft which is about 100metere away taxing past. ie, aperture setting, iso setting and shutter speed? or is it best to shoot in auto mode?
Any advice will be greatly appreciated...
Sam
comair25
RE: Advice On Nikon D5100 Setting For Taxiway
Sat Jan 14, 2012 2:23 am
Ive used ISO100, F8 on App Priority. Seems to work out quit well.
alevik
Crew
Sat Jan 14, 2012 2:28 am
f8, aperture priority, ISO as low as you can and keep shutter speed above above 1/250.
I would stay away from auto mode - much better to do some reading on basic photography and practice, practice, practice.
Improvise, adapt, overcome.
ocean773
Sat Jan 14, 2012 2:33 am
Quoting comair25 (Reply 1):
Quoting alevik (Reply 2):
Wow, fast response and thank you guys. So much to learn!!!
Sam
jadams67
Sat Jan 14, 2012 5:14 am
I totally agree with that. Been doing this with my D80 and I can still use more.
egondo
Fri Jan 20, 2012 12:17 pm
Will it apply for subjects longer than 100m as mentioned?
Edric
JakTrax
Fri Jan 20, 2012 12:57 pm
Quoting egondo (Reply 5):
The closer the subject, the steadier the hand can generally hold the camera - although this theory can also depend on the size of the subject. The more you zoom in, the greater impact movements of the camera/lens will have on the sharpness of the image.
Sometimes you have to make sacrifices and trade-offs to get a sharp image. Aperture f/8 is generally a good choice but if you can't get a sufficient shutter speed it's fine to drop it by a couple of stops to f/7.1 or 6.3; so long as the required depth-of-field can still be achieved (if it's relevant). Another trick is to increase the ISO (sensitivity), but this of course leads to increased noise in the image.
The final solution is to turn the optical stabilisation on - but of course you have to have this feature in the first place!
As a quick guide, I aim for the following shutter speeds (without stabilisation):
1) Taxiing or slow moving aircraft:
a) up to 200mm = at least 1/250th
b) over 200mm = at least 1/320th
c) over 300mm = at least 1/400th
2) Rotating/arriving aircraft:
a) up to 200mm = at least 1/400th
b) over 200mm = at least 1/500th
c) over 300mm = at least 1/640th
Hope this helps.
Karl
Silver1SWA
Fri Jan 20, 2012 6:57 pm
Quoting ocean773 (Thread starter):
I could tell you ISO 100, f/8 at 1/250th, but that does nothing to help you learn anything and it does absolutey no good if the conditions aren't ideal for those settings.
The answer to your question is entirely dependent on the conditions. Is the sun out? Is it cloudy? Where is the sun? In front of you? Behind you? Directly overhead? These are all important factors that will have an effect on the settings needed to properly capture the scene.
Learn the relationships among shutter speed, iso, aperture and focal length. You will benefit much more from learning the fundamentals than just having someone tell you settings to use.
[Edited 2012-01-20 10:58:43]
