TupolevTu154
Photoshop Image Size Help
Mon Feb 20, 2012 5:03 pm
I recently had a photo usage request from someone who wants a print to hang up in their office.
He wants the photograph at a size of 60x90cm/23.6x35.4inch at a maximum. I've resized the photograph to 300dpi in photoshop to allow a print of this size, however it has given me a file size of over 9 gigabytes.
Obviously I can't attach a file size like that to an email (which is how we've been corresponding). I'm in need of a bit of help as to how big I should re-size this photo in photoshop and how I can send it to him via email. He's going to get it printed his end.
Many thanks in advance, and in case you were wondering, I haven't given it away for free!
vikkyvik
RE: Photoshop Image Size Help
Mon Feb 20, 2012 5:59 pm
Quoting TupolevTu154 (Thread starter):
Whaaa????
That seems WAAAYYY to big for the size you have. At 300dpi, 23.6 x 35.4 equals 7080 x 10620 pixels, or about 75 megapixels. I'd guess that should be well under 100 megabytes, never mind gigabytes!
Given that a typical 1200 x 800 photo of mine is probably around 600-900 kilobytes, I'd assume a 75 megapixel file would be around 50-70 megabytes.
This all assumes you're working with JPEGs. If not, then never mind.
captainstefan
Mon Feb 20, 2012 6:02 pm
With a file that size, your usual option would be to purchase file-sharing space on a site like dropbox.com . Or just mail him a USB drive containing the file. Those are the only ways I can think of.
Long Live the Tulip!
vikkyvik
Mon Feb 20, 2012 6:19 pm
Quoting captainstefan (Reply 2):
You could also FTP it, if the customer has that ability.
Or you could probably upload it to Google Documents or something similar.
LH526
Crew
Mon Feb 20, 2012 7:51 pm
if it's for poster size, 150dpi is totally sufficient! 300dpi is for magazines and print with normal reading distance ... poster is for wall art best viewed some steps back, so 150dpi is totally enough cutting down your file size to a quarter of it's 300dpi size.
Trittst im Morgenrot daher, seh ich dich im Strahlenmeer ...
ckw
Mon Feb 20, 2012 11:07 pm
Something very wrong there ... I just resized an image to the dimensions/resolution required - in 16bit - and produced a 431mb tif.
Changing that to an 8bit uncompressed jpg (which should be fine for most printing) results in 14.1 mb
So how you got 9gb is a bit odd - unless you have a large number of layers - if so flattening the image should do the trick.
The whole idea of up-sizing images to match a nominal target is a bit questionable. Firstly upsizing and printing at 300dpi is rather self defeating - you're not adding any detail, and probably introducing artifacts and smearing. I think most printing services with decent equipement will do a much better job of up-sizing the image as part of the print process
bottom line - a print at 150dpi will probably look better than one upressed to produce a nominal 300dpi at the same size. (for canvas prints or other 'special effects' you can get away with even lower resolutions).
The best idea, if possible, is to contact the printing company, and find out what they recommed to produce the required print.
Colin
Colin K. Work, Pixstel
TupolevTu154
Wed Feb 22, 2012 11:04 am
Quoting vikkyvik (Reply 1):
I am working with JPEG, yes.
Quoting lh526 (Reply 4):
Even putting in 150dpi still shows a ludicrous file size.
Clearly I'm missing something, here's a screenshot of what the figures are when asking for 150dpi.
http://img.photobucket.com/albums/v476/Toml/screenshot.jpg
I just need step by step instructions on how to change an image size to one acceptable for printing in the dimensions above and how I can send it to him (preferably via email). I've not had to do this before and it's proving far more complicated than I had hoped! Thanks!
dueckimages
Wed Feb 22, 2012 11:52 am
Here's my stab after looking at the screen shot. I think that 9.36G is stating the number of pixels in the up-sized picture. As with previous posts, I have never come across a picture file size being that large. If someone can confirm that the 9.36G is the amount of pixels in the photo to be correct much appreciated and I am also open for correction if this is an incorrect assumption.
Cheers and Best of Luck
ckw
Wed Feb 22, 2012 2:01 pm
LOL - the files size is correct - it's your dimensions that are wrong ... if you look again I think you'll find the numbers are 10x what you intended (spotted that immediately as I've made the same mistake myself!)
Colin
LH526
Crew
Wed Feb 22, 2012 2:05 pm
Quoting TupolevTu154 (Reply 6):
According to your screenshot the final poster would be 12m by 9m large, well enough to cover an entire facade!
Quoting dueckimages (Reply 7):
Check the bit depth of your photo and be aware that the size given in the image size box is the amount og Gig needed in the RAM to properly work with the file.
flood
Wed Feb 22, 2012 5:12 pm
The 9.36G refers to document size, ie a 9.36 GB TIFF
Quoting lh526 (Reply 9):
Indeed, from a modest 3.3 gigapixel image.
Going by the indicated ("was") document size of 26.7M, your original appears to be in the neighborhood of 3700px wide or a ~9mp image... that would roughly yield 100 pixels/inch.
As lh526 pointed out, 300 dpi is overkill for your needs. If you look up the various online printing houses, you'll find you exceed their minimum recommended resolution by quite a margin and the printer's software will upsize your image as needed anyway.
If you're wanting to do it yourself, I'd just double the dimensions using bicubic smoother (as selected method in the resize window) and send him the jpeg at max quality.
vikkyvik
Wed Feb 22, 2012 5:21 pm
From his screenshot, there are 3,348,654,736 pixels in the image (70868 x 47252), so around 3.35 gigapixels.
TupolevTu154
Thu Feb 23, 2012 12:17 pm
Quoting flood (Reply 10):
That's what I've done, and it gives me these figures, with the image being 17MB;
Is that satisfactory?
Thanks for your help everyone!
LH526
Crew
Thu Feb 23, 2012 1:23 pm
Quoting TupolevTu154 (Reply 12):
If you provide your printer with that file he will print you a 24x16m large poster (larger than a house) at 8dpi ... that's certainly not what you want. Simply ignore the pixels, set resolution to 15dpi and change the width to your desired size, and as a reminder: 1m equals 100cm, not 1.000cm!
shufflemoomin
Thu Feb 23, 2012 4:40 pm
I don't mean this comment to be offensive, but I recommend you read up on the very basics of image manipulation, especially if you plan on make a business of it.
If you're not actually printing the image for him, the dpi is completely irrelevant to you. Send him a max quality jpeg or TIFF if space allows at the images full resolution, leave the dpi at the default and let his printing service worry about dpi for his chosen print size. You don't need to do anything.
[Edited 2012-02-23 08:58:16]
ckw
Thu Feb 23, 2012 4:58 pm
Setting sizes can be confusing. Basically, the sizing box has two parts:
Top 2 values - there are pixel dimensions and are relevant to on screen sizes. If you want an image to be a given pixel dimension, you put the required values in here, and basically ignore the numbers which appear in the bottom 3 boxes - they're not relevant.
Bottom 3 values - these are the figures that determine the hard copy size and resolution. In your case, you would enter
60 cm
90 cm
and (suggested) 150 dpi
Don't worry about the numbers in the pixel boxes - PS will set these automatically to produce the print size/resolution you require. People get confused thinking they have to work with ALL the values. It's top section for screen, bottom section for print.
Colin
flood
Thu Feb 23, 2012 8:53 pm
Quoting lh526 (Reply 13):
That's silly. Walk into any store or upload a file for printing and the first thing you're asked is what size you need. Any physical dimension data contained within the image, be it document size in inches/cm or the corresponsing DPI, is ignored.
Yes. I'm just curious how you ended up with 7.9 pixels/inch as merely upsizing an image by changing pixel dimensions in PS shouldn't affect that number. Keep in mind that repeated up/down-sizing will affect image quality. That said, if you've been experimenting on the image throughout this thread, you may want to take the original and upsize just once by changing width in pixel dimensions, with all 3 boxes ticked and using bicubic smoother.
LH526
Crew
Fri Feb 24, 2012 12:49 am
Quoting flood (Reply 16):
For a normal photos lab that is true ... however a professional printer will always look for the physical dimensions of the TIFF or PDF file provided.
flood
Fri Feb 24, 2012 10:04 am
Quoting lh526 (Reply 17):
I've never encountered the issue with various professional photo printers in the US. However, should he happen to select a printer who only reads metadata, it would be rather obvious beforehand as they won't bother asking for dimensions. Provided a printer asks or he tells them, he'll end up with the required size.
LH526
Crew
Fri Feb 24, 2012 10:58 am
Quoting flood (Reply 18):
We are both correct: As I said ... photo printers / phot labs emphasize on the size you chose during order and ignore the metadata in the file ... professional offset printers and plotters however etc will mostly rely on the size given in the TIF or PDF file along with the dpi.
[Edited 2012-02-24 08:14:18]
