swadeep
Canon Camera Upgrade
Wed Feb 29, 2012 3:14 am
Hey there, I am thinking of upgrading my camera and would really appreciate your help. Anyway here's my current equipment.
Canon 550D with 18-55mm lens
Normal canon lens 55-250mm
Canon 100-400 L IS
I also use battery grip.
Last 2 weeks i just purchased 24mm F1.4 L II USM lens and now I was planning to upgrade body to 5dmk2 . Then i was told by a friend to wait because 5dmk3 is going to launch. Now the launch is this friday but after seeing the price and specs i am not sure anymore. I live in bangkok and getting 5dmk3 would be twice more expensive than getting mk2. I just purchased 24mm f1/4 also which was quite expensive so dont want to spend a lot more in not needed to really. anyway here are my questions.
1. Should i just get 5dmk2 then? Is it worth paying double for mk3?
2. The battery grip that i use for my 550d, will it be compatible with mk2/3 also?
Would really appreciate your assistance.
Swadeep
Swadeep Chansrichavala (BKK | VTBS)
vikkyvik
RE: Canon Camera Upgrade
Wed Feb 29, 2012 3:16 am
Quoting swadeep (Thread starter):
Are you sure he didn't mean: "Wait till the Mk3 comes out, because the Mk2 will go down in price"?
I don't know if that's what will happen, but it would make sense....
swadeep
Wed Feb 29, 2012 3:25 am
what he meant was wait for mk3 incase i wanted to buy mk3 (at that time i was about to buy mk2....i had no idea about mk3) but now that i know the estimated price i am having second thoughts. i wont mind buying mk2 if it's not worth the money jumping to mk3
thanks
swadeep
Wed Feb 29, 2012 5:09 am
Quoting swadeep (Reply 2):
Well sure.. Unless you think that you really don't want the mk3. But the price of the mk2 could drop, depending on what stocks are like and how long they keep the line open for. You need to think about whether it'd be worth it going for the mk3. By looking at your lenses, you'll need to replace the 18-55 unless you don't use it at all as that won't work on any 5D. The 5DII is a great camera - many here have it and they produce fantastic shots with it.
And no - the battery grip of the 550D is not going to fit a 5D. The 5D is huge in comparison to the 550D and it requires different batteries.
swadeep
Wed Feb 29, 2012 5:50 am
hi. thanks for your input. i will still keep 550d so i will use 18-55 lens still for general shooting. i guess i will see if the price will drop or not..looks like maybe have to end up getting mk2 then unless mk3 offers significant improvements to justify the price...
thanks
swadeep
Wed Feb 29, 2012 9:09 am
Quoting swadeep (Reply 4):
IMO your money would be better spent on good quality glass than a 5DII unless you're so keen on getting a full frame body. You could buy a 7D and also a good lens to replace the 18-55 such as possibly the 17-40, 24-70, 24-105 or the 17-55 for a crop body which would come to around as much as what the 5DII would cost.
shufflemoomin
Wed Feb 29, 2012 9:37 am
I will add a second vote for the 7D. It's a fantastic camera and a valid upgrade from the 550D. If you go full frame, you're not going to fill the frame with your lenses the way you're used to. Your lenses will behave the same on the 7D and you'll get a better overall camera. Plus you'll save about 50% of the cost of a 5DmII.
notnam
Wed Feb 29, 2012 11:50 am
Just to balance the discussion a little, I followed as similar path to the OP and went from a 450D to a 5D2 and could not be happier. I did consider the 7D but was keen on the low light capability of the 5D.
I have come to really appreciate the full frame sensor and the crops you can achieve more than make up for the loss of focal length.
Good luck with your decision.
ckw
Wed Feb 29, 2012 12:56 pm
I guess it depends what you think you need - having paid for the 24mm 1.4, I assume the full frame and low light performance are of interest, in which case the 7D is not the best answer (effectively turning your 24mm into a an approximately 35mm lens).
Whether its worth waiting for the 5D3 is anyones guess until the specs and price are officially announced. Frankly, even a 5d mk 1 will give you full frame and better image quality than your 550 - and you may be able to find one real cheap. The Mk II increased the pixel count and added video, and that's about it - the AF and metering were pretty much unchanged. Unless you really need video and/or 22mp files, then the old mk.1 will do the job.
What I think most people are hoping for with the Mk.3 is primarily a updated AF (similar to the 7D or 1DX) - no one seems to be expecting anything too radical, though certainly improved low light performance is pretty much a given, and maybe some clever support for wireless flash. But, Canon has pulled some surprises out of the hat before!
So it depends what you need. One thing for sure, the release of the Mk.3 is not going to cause the Mk.2 to get more expensive ... but I wouldn't expect it to get a lot cheaper either - if as expected, the Mk3 is going to be $1000 more expensive I don't think dealers are going to need to do much discounting to shift Mk.2 stock - it will still be a very desirable camera, esp. for those into video.
Colin
Colin K. Work, Pixstel
shufflemoomin
Wed Feb 29, 2012 3:46 pm
Although I've read many opinions that the 5D performs better in low light than the 7D, I can say that I haven't seen it. A good friend and I are both concert photographers and he uses the 5DmII and I use the 7D and both perform exceptionally. Whether the 5D is worth the extra 50% in cost basically boils down to whether you want full frame or not. Even though the 7D is a crop sensor, it still shoots 2X as many frames per second and AF performance is greatly superior. Both good things to consider if you're going to be doing aviation photography. The 7D is superior for video too if that's of any interest to you. The 5DmIII is almost certainly going to top the 7D in those areas, but at a rumoured price of $3500, you'd have to have deep pockets to consider it.
swadeep
Wed Feb 29, 2012 5:01 pm
Thanks very much guys for your opinions. Really appreciate it. Many good points. While I am going to be using it for aviation photography, i will also use it for low light situations and taking videos too...i guess i really have to decide now which one to get. I may lean towards 5d more as I also want to get full frame censor but let's see. the question is now mk2 or mk3. I guess ill wait few more days till i know the exact specs and price.
thanks again so much everyone. i really appreciate your inputs
cheers
swadeep
ckw
Thu Mar 01, 2012 12:45 pm
Quoting shufflemoomin (Reply 9):
I'd basically agree with this - the 7D does a very good job at high ISO, as does the 5D. But in my opinion, the Achilles heel of the 7D is it's image quality at low ISO (100-200) - here the 7D shows noise where you simply would not get any with the 5D.
I suspect the bottom line is that the 5D sensor is inherently cleaner, but at higher ISOs Canon incorporates additional noise reduction technology which effectively levels the playing field.
Colin
