LH234
550D+17-85 Vs. 60D
Fri Mar 02, 2012 5:07 pm
Hey guys,
I have some problems with my 450D (processing takes really long,"start-up" fails although it's fully loaded,the shutter-relase get's stucked while shooting)... I was already in contactwith Canon Germany but a reparation would be very expensive.
Now I wanted to ask you guys what's better: Buy a relatively cheap EOS 550D )and maybe spend the remaing amount on a 17-85 as I don't own a good lens in this category) or buy a 60D from the upper series?
We had a discussion here before about the 60D , and you guys told me that spending money on lenses is the more diplomatic way than investing in a expensive body.
I would use my Canon 100-400L lens on the bodies.
The 550D is similar to the 60D (18MP,movie-function ecc.) , so I am between this two cameras.
I really agonize about this decision and just wanted you to give me some support about it so that I know that I make the right decision!
Thanks in advance,
Marius
CaptainKramer
RE: 550D+17-85 Vs. 60D
Fri Mar 02, 2012 5:41 pm
Hi LH234,
I have a Canon 60D that came with a Canon EFS 17-85mm lens. I am happy with my 60D so long as I don't look at the results from a Canon 7D, even if it just by looking at the LCD display, WOW, but seriously IMHO a Canon 60D is very good for the price. However I have found in certain instances that the 17-85mm at full wide shows up chromatic aberation which often ruins the shot, that not even software can save. Just my 2cents/pence worth.
JWM
Fri Mar 02, 2012 5:43 pm
In that situation, get the 60D. I've got 550D, and it's not very "sporty" little camera. IQ is great for the price, but at 3,7fps and buffer of 6 raw:s it's not really a aviation photography tool. You win in speed and handling if you take the 60D, IQ is similar and so are the high-ISO:s.
Hope this helped
/JWM
afterburner
Sat Mar 03, 2012 2:33 pm
From what I've read in reviews and forums, Canon 17-85mm is not a good lens (the 15-85mm is a better lens). And the 60D is a class above 550D.
Users browsing this forum: Baidu [Spider] and 1 guest
