Gasman
Advice Needed For Cockpit Shoot
Fri Mar 09, 2012 10:27 pm
Hi there
I've got seat 1A booked on a Thai A340-600, and I thought I'd ask to take a few shots in the cockpit prior to takeoff.
Never done this before, and I don't want to screw it up - so lots of advice would be appreciated. It will be daylight outside, I'll be using a Canon 30D with an EF-S 10-22mm lens. An external flash will be available if needed.
Many thanks in advance
Gas,
dumbell2424
RE: Advice Needed For Cockpit Shoot
Fri Mar 09, 2012 10:47 pm
Here's a little advice that I use. When I do it (by no means an expert), I try to meter aperture to match the outer light so I don't get results that are too blown out at the windows. As for an external flash, I remember reading that many people tilt it up and bounce off the ceiling. For me, I use my builtin flash and put a handkerchief in front.
unattendedbag
Fri Mar 09, 2012 10:51 pm
Quoting gasman (Thread starter):
I find it easier to ask to take pictures after the aircraft has landed. pre-flight is a busy time and once the passengers start boarding, everyone is focused on their task. I usually hang around until the last passenger has deplaned and ask then.
Slower traffic, keep right
Fri Mar 09, 2012 11:39 pm
Quoting dumbell2424 (Reply 1):
With the 10-22mm that he has, there will be a shadow caused by the low level of the inbuilt flash/the wide ability of the lens. So use of the external flash would be advised. Meter the outside and then keep those settings on for when you use flash to fill in the dark area of the cockpit dashboards. Depending on what flash you do have, I'd suggest bouncing it somewhere instead of firing it straight. And you can probably leave ISO at a low value - 100 even.
Quoting unattendedbag (Reply 2):
Ditto here. And I'd presume that there'd be dual airbridges in BKK so that the F passengers use the front and just about everyone else uses 2L.
Gasman
Sat Mar 10, 2012 12:46 am
Thanks. Yes, I do have a bouncable flash.
So the picture i'm getting is
- wait till the end of the flight
- meter for the outside
- iso 100
- use fill flash - if bouncing, do I give it +2 of flash exp. compensation??
jid
Sat Mar 10, 2012 11:49 am
In addition to the above - shoot RAW so you can balance your exposure if you don't get it spot on out of the camera.
G7EPN is back after 15 years! Operating all Bands 80mtrs -> 70cms QRZ DX
dazbo5
Sat Mar 10, 2012 12:07 pm
gasman,
Have a look at the 3 links at the bottom of the page. The technique has been covered several times with lots of advice and tips on their.
Darren
Users browsing this forum: Yahoo [Bot] and 9 guests
