LH234
Travel And Spotting Lens
Sun Mar 18, 2012 10:56 am
Hey guys,
I'm currently spotting with my 100-400 lens but I happens way too often that 100mm are to much!
This is why I wanted to expand my equipment.
I was looking at three different lenses:
Canon 24-105L > is very expensive,but worth the money?
Canon 17-85 IS USM > I heard that this one has some problems at 17mm and the colors are not that good
Canon 18-200 IS > less expensive than the L , but a large range of zoom (loss of quality?)
I would use the lens on a 450D and a 60D.
Thanks in advance!
yerbol
Crew
RE: Travel And Spotting Lens
Sun Mar 18, 2012 11:28 am
Please take a look at Canon 15-85mm f3.5-5.6 IS USM lens. It is sharp and well build. Colors looks good too. It will give you good result paired with your 60D. I friend of mine got this combo and he is very pleased with the result. Take your 60D to the shop and try this lens on different focal length. Good luck!
With best regards from Almaty
martin54
Sun Apr 01, 2012 3:49 am
I shoot with Nikon nowadays but during my Canon years, the 17-85 IS must have been the worst lens I have ever owned. Horrible chromatic aberrations and unacceptable distortion levels at all focal lengths.
If I was still shooting Canon the 70-200 f/2.8 L IS would probably be my lens of choice.
Sun Apr 01, 2012 4:16 am
If you're ever looking to go full frame, I suggest the 24-105. Great quality lens which is EF mount unlike the 15-85mm. The 15-85 is the upgrade of the 17-85 (which is a horrible lens and I don't recommend it) and would do a good job if you didn't care too much about the full frame aspect.
dazbo5
Sun Apr 01, 2012 9:38 am
The only problem with the 24-105 is 24mm on a crop camera isn't all that wide for day to day use. I find I use my Sigma 10-22 nearly as much at the 24-105 in general photographer. It depends on your focal length needs really. The 24-105 will give excellent quality results, but you may favour the 15mm end of the 15-85 if that's what you need. Those extra few mm's make a big difference. If you don't need wider than 24mm, you won't be dissapointed with the 24-105, although it's not cheap for what it is.
Darren
Tonyholt777
Sun Apr 01, 2012 6:44 pm
I have a 60d and full frame 5dmkii. When you say your 100-400 L doesnt give you enough close range have you considered that at 100mm your 60d is actually working at 160mm FL? Hence the advice above re the 15-85 and 10-20 lenses because they are specific to the 60d crop sensor.
That said the 24-105mm L is a great lens and would complement your 100-400 L but remember its FL is 38-168mm on a 60d. A lot of people like the 35mm range for general photography and that might suit you, plus its a good investment if you ever get a full frame camera.
FWIW I often put my 17-40mm L on my 60d or 7D for general work and get great results. In all honesty I cant say that I use my 24-105mm L with either of those bodies although I do use them with my 100-400mm L from time to time.
Its a matter of personal preference - best of luck with your choice
tony
yerbol
Crew
Mon Apr 02, 2012 3:43 pm
From the beginning I sugested Canon 15-85mm lens. It is wide and quality is good. Any L-class lens, let's say 17-40mm will be x 1.6 so I do not see point of using one. Some of my photos from Aktobe were taken with 15-85mm. In my opinion it works great. This hobby need few lenses
dazbo5
Mon Apr 02, 2012 4:02 pm
Quoting yerbol (Reply 6):
I'm not quite sure what you mean there. The lens isn't 1.6x crop factor, the camera body (sensor) is. Regardless of the lens you attached to a crop body, it'll be 1.6x the focal length so it applies to the 15-85 just as much as a 17-40 or 24-105.
Darren
Silver1SWA
Crew
Tue Apr 03, 2012 4:34 pm
The 24-105L is a GREAT general use, all-around walk-around lens. If I can only bring one lens, that's the one I bring. And if you can get close enough, 105mm works for aviation as well.
Another consideration if you don't need something super wide is the Tamron 28-75 f/2.8. Its a KILLER lens and for $450 it's probably the best bang for the buck out there right now. I got one in December and I have only used my 24-105 ONCE since!
Both lenses are perfect for travel and general photography. The Tamron is lighter and smaller and half the price, so that's another consideration. Both require close access for aviation, although the 25-105 gives more in terms of reach (obviously).
Users browsing this forum: No registered users and 16 guests
