dlowwa
Update To Motive Rules For Obstruction
Tue Jul 17, 2012 7:43 am
Hi everyone,
After a lengthy discussion, we have decided to update and clarify the motive rules for obstruction. This will hopefully serve two functions: 1) clarify the rules to all, and 2) relax some areas to make some shots easier to get accepted (especially ramp shots). We've tried to cover everything below in regards to obstruction, but if you think something has been missed, please let us know by posting here. As always, we retain the right to apply the rules as we see fit, and make exceptions when deemed necessary.
Dana
Motive Rules for Obstruction
RAMP VEHICLES (including tugs, loaders, baggage carts, etc...) are allowed to block part of the aircraft as long as they are:
    [1] not blocking engines or wheels (exception: tugs are allowed to block engines/wheels if towing aircraft, and ground crew are allowed to block any part if not too prominent, which is at our discretion)
    [2] below the window line
    [3] part of active operations (this amendment is meant to exclude any aircraft parked with equipment in front of it. 'Active operations' is meant to include those aircraft actively loading or unloading.)
As was previously the case, for preserved subjects there is much more leeway when the obstruction is unavoidable, such as permanently affixed stairs, or fences.
Integral stairs on biz jets (and some larger aircraft such as 737s) are allowed to obstruct. Smaller crew ladders affixed to the sides of military aircraft are generally allowed, even on static subjects.
JETWAYS
Jet ways are not allowed if blocking any part of the side of the aircraft facing the photographer.
For head-on shots, they are not allowed to block the engine/gear or a significant portion of aircraft if a wider view. Small blockage of the wing will be allowed for tighter crops.
FENCES
Fences should not block any part of the aircraft. Fences taking up more than one-third of the frame can also be considered motive rejections even if not blocking part of the aircraft.
GRASS/RUNWAY
The terrain is allowed to block no more than 50% of the wheel. This does not apply to runway/taxiway markers, for which there is no allowable blockage as they are easily avoidable. For vegetation that is evenly spread out (i.e. not just one big clump of grass that could have been avoided, similar to a taxiway marker), there can be some tolerance past 50%, but this will be at our discretion.
CONES/COVERS
Cones are ok if unavoidable (i.e. by shooting from different angle) and not obstructing too much. How much is 'too much' will again be at our discretion.
Shots with covers over a significant part of the aircraft will only be allowed if the aircraft is not on the db already. If we already have an image of it uncovered, then we will not accept it covered. This does not include engine/pitot covers. For partial/canopy covers, this again will be at our discretion.
aerlingus320
RE: Update To Motive Rules For Obstruction
Tue Jul 17, 2012 11:34 am
Wow..you guys are pretty serious about taking good Photographs of Aircraft...And I am 100% agreeing with you! . I take vids and pics with my iPod.
powwwiii
Crew
Tue Jul 17, 2012 2:12 pm
Thanks Dana for clarifying this. Just a quick question about grass. I have many pictures of aricrafts that have been sitting for a long time at some grassy airfields, when they cut the grass they can only cur around the aircraft so that leaves tall grass which block the wheels and even some lower part of the fuselage, I guess that is ok, especially for those aircrafts are not in DB, correct?
dlowwa
Tue Jul 17, 2012 3:26 pm
Quoting powwwiii (Reply 2):
As stated above, some discretion will be applied in cases where it is more than 50% of the wheels, but appears to be unavoidable.
Rimantas
Tue Jul 17, 2012 4:00 pm
One more question regarding security tapes, like this:
http://www.airliners.net/photo/Euroc...d=1f2f3dd71a8023ae53f6bec90ec4558b
They are common in static displays of air shows. Should we treat them as fences or as cones ?
I have photo of CASA S-295 with around 30% front wheel obstructed by such tape and I'm am not sure whether it's acceptable for database.
vir380
Tue Jul 17, 2012 4:46 pm
Quoting Rimantas (Reply 4):
Hi , that picture you show is not a problem , the tape is not much of a distraction as its a single tape & less than a third of the image is distracted , cant really treat them as a fence as such BUT all will be judged individually based on the tape and image itself...
Why not post the image you refer to on the feedback forum ?
regards
Moved away from this lost website to better things !
Rimantas
Tue Jul 17, 2012 5:55 pm
Quoting vir380 (Reply 5):
I've just done that. Thanks in advance for your opinion.
scbriml
Wed Jul 18, 2012 11:57 am
Quoting dlowwa (Reply 3):
Dana, presumably this is not much different to the situation previously, where photos such as these were accepted?
Photo © Steve Brimley
AlexC
Wed Jul 18, 2012 3:50 pm
How about wheels part covered by runway camber? I've generally not tried uploading any of these because I've rightly or wrongly expected them to be rejected.
dlowwa
Wed Jul 18, 2012 5:11 pm
Quoting scbriml (Reply 7):
Yes, this has not changed. The only real changes were with ramp vehicles and covers, the rest is just a clarification of how things were already being done.
Quoting AlexC (Reply 8):
Please see:
Quoting dlowwa (Thread starter):
RUNWAY
AlexC
Thu Jul 19, 2012 8:21 am
Oh, right. Sorry about that
geocan
Mon Jul 23, 2012 11:58 am
Dana,
thank you for the clarification.
In the above notes I could not find any references to signs in front of aircraft in museums.
What are the guidelines in such cases? A while back I had a couple of photos taken inside the museum at Hamilton ,ON which were rejected for motive because the sign was covering parts of the lower fuselage/trailing edge.
George
EZEIZA
Tue Jul 24, 2012 3:13 am
Hi,
after reading the thread, would the following shot be accepted now? It was rejected for motive only, and after appeal, the head screener mentioned that the fence was the cause of the rejection.
http://www.myaviation.net/search/photo_search.php?id=02184167
rgds
Carp aunque ganes o pierdas ...
Rimantas
Tue Jul 24, 2012 8:19 am
Quoting EZEIZA (Reply 12):
I believe it should't be rejected for motive, since fence neither block any part of the aircraft nor is taking up more than one-third of the frame in this photo.
airkas1
Crew
Tue Jul 24, 2012 9:11 am
That fence is still very distracting. Why don't you just clone it out?
Airliners.net Crew - Head Photo Screener
EZEIZA
Tue Jul 24, 2012 12:57 pm
Quoting Rimantas (Reply 13):
that's what I was thinking as well
Quoting airkas1 (Reply 14):
dlowwa
Tue Jul 24, 2012 4:11 pm
Quoting geocan (Reply 11):
Standards for museum/permanent displays have actually not changed. As mentioned above, we do give more leeway for obstruction in these cases when it seems unavoidable, and is not too intrusive. As always, it will be a case-by-case judgement call. For your specific case, I would probably need to see the image in question.
Hi,
No, this would still be rejected, as the out of focus foreground object is distracting and seems avoidable by simply shooting a few seconds earlier or changing your angle. It may not take up 1/3 of the frame, but as mentioned above, we reserve the right to make case-by-case judgment calls.
EZEIZA
Tue Jul 24, 2012 4:26 pm
Quoting dlowwa (Reply 16):
Thanks for replying, although I have to admit I disagree with the conclusion. Mainly becuase I possibly did not have a chance of shooting from another agle or a few seconds later. Also, unless I'm missing something, the screener descretion mentioned above is for ramp vehicles/ground crew, not for fences. In any case, no big issue, but I just don't agree in relation to the rules posted above.
best rgds
[Edited 2012-07-24 09:47:57]
Soaring1972
Tue Jul 31, 2012 10:56 am
Question regarding wheels and gras:
Does this also effect smal tailwheels, very smal light-type-wheels and glider wheels?
Thanks to all ONE-Star voters just to push a photograph down!!!
