jpmagero
Opinion On Image Quality (7D + 100-400L)
Mon Jul 30, 2012 12:41 am
Hi - I've been using the above setup (Canon 7D + 100-400L) setup for about a year now and have been quite pleased with the results in terms of basic photography (online/prints). Since trying to get shots prepped for databases such as this one, I've been struggling to get sharp images however, and have generally put it down to my technique / user error so have been trying different things on my own.
I'd mostly been shooting JPG, but now when trying out some RAW images and looking at them 1:1, I see a lot of noise in the image. I've heard that the 7D is generally noisy, but I would have thought that at ISO-100, shooting into a bright sky, I shouldn't see any noise, effectively. To my eye, this is the level of noise I'd expect going past 800 or so, not at 100.
Is that realistic and there is perhaps a defect in my sensor or body+lens combo or settings for that matter? Or I am expecting too much and this is either a) as good as it gets with this combo or b) poor technique and/or setup and I just need to "get better"? Thanks for the feedback. I would greatly appreciate some examples in the replies to compare to my samples below, if it wouldn't be too much trouble. Thanks in advance.
Samples (exif info in screen shot) - let me know if any more info is needed to properly respond. Images are 100% crop screen grabs from Lightroom with no adjustments at all. They were taken between aprox 6-7 PM, fairly brightly lit.
John M - Aussie expat in the US
aussie18
Crew
RE: Opinion On Image Quality (7D + 100-400L)
Mon Jul 30, 2012 1:07 am
Hi John,
I have been using the same set up for around the last 4 months,Ive found the quality with images are alot better than previous 40D canon body which I should've expected,I have noticed in some images even at around ISO160 that there is abit noise showing but I dont see it as a big issue as there are ways to fix this in photoshop and other editing programs.
I always shoot in JPEG and have taken some RAW images but havn't edited any of them.
Few shots taken with 7D,100-400L
Photo © Mark H
ISO 200/F8and only small amount of USM added.
Photo © Mark H
ISO 160/F8
Cheers Mark
jpmagero
Mon Jul 30, 2012 1:14 am
Thanks...I usually shoot in JPG too, and recently tried to see if going RAW first would help, and all I saw was all this noise to get rid of   .
I guess the downsizing from 18 MPX to less than 1, it could be argued that if not a lot of cropping is required, there should be enough detail in the jpg to work with. There are always exceptions of course.
vikkyvik
Mon Jul 30, 2012 1:59 am
Quoting jpmagero (Reply 2):
Well that makes sense, as RAW is the image without any processing.
Anyway, regarding your initial questions:
The amount of noise in the images doesn't look awful. A bit of NR on the RAW file ought to take care of most of it. But the airplanes in those 5 photos all look underexposed, which will create more noise, especially in a livery like Southwest's. ISO100 doesn't do much good if it makes you inadvertently underexpose. I'd take 200 and a good exposure over 100 and dark any day.
The other major thing I noticed is that the photos look pretty soft. This will make you have to use more sharpening (even on a resized image), which will exacerbate whatever noise there is. I'm guessing the softness is in large part caused by shooting pretty wide open (all the apertures are between 4 and 5.6). I haven't used a 100-400, but I've certainly heard that you need to stop down to get sharp results (and that tends to hold true for other lenses as well, though maybe not as much). Again, shooting at ISO100 is not helping you here. In good afternoon light, I tend to shoot at ISO200, F8, and 1/500 - 1/1000.
jpmagero
Mon Jul 30, 2012 2:11 am
Thanks...I just realized that in order to compare results between two lenses, I ended up showing examples from the 70-200 lens rather than the 100-400...
Silver1SWA
Crew
Mon Jul 30, 2012 2:44 am
The 7D is in fact quite noisy. I consider ISO 100 - 400 to be identical with regard to visible noise on a bright sunny day. Oddly enough, it's usually more visibile in bright blue skies. I shoot in RAW and my first step in post processing is to reduce some noise using Adobe Camera Raw (or Lightroom) on all photos I plan to upload here.
The 100-400 is tricky. Air quality and temp (heat haze) plays a huge role in quality and sharpness. Distance from the subject, amount of cropping, and aperture are important factors. I know many here will disagree, but when using this lens I boost in-camera sharpening all the way up to 7.
Some examples... 7D + 100-400L
ISO 800 f/8
Photo © Ryan Pastorino
ISO 200 f/8
[Edited 2012-07-29 19:49:46]
jrowson
Mon Jul 30, 2012 8:30 am
Quoting Silver1SWA (Reply 5):
This is something I agree with. I was really struggling with noise on my 7D when shooting jpg. Blue skies at iso 100 were ending up very noisy and a cause for rejection. I never used to shoot RAW but have taken the plunge now and the results are interesting. I now shoot raw, overexpose a little more than I used to. I then use the noise reduction in ACR, and only a little but the noise reduction is quite significant compared to jpg shooting. I also see less banding than I did when I was shooting jpg. I find using the noise reduction in ACR to be a much more acceptable result than say using noise ninja in photoshop itself.
James Rowson
ckw
Mon Jul 30, 2012 9:10 am
I agree that the 7D is disappointingly noisy in the blue channel (though all things are relative - I'm comparing to the 5D and 1D). Had the 7D not been outstanding in other respects, I would have given up on it! However its such a useful camera that I've perservered with it, and have found that
a) it is extremely intolerant of any under-exposure ... there is simply no room for error in the shadows (unlike, say, the 5D) so exposure need to adjusted accordingly.
b) the blue channel noise is probably partly due to the pixel density which just has to be lived with. However a very small amount of noise reduction applied in ACR does help a lot.
As to sharpness - well based on the Exif data you supply, I think those pics look a bit soft for that lens. It could be technique (these are crops - do they include the point of focus?) If you are using all focus points, the camera may not be focusing where you think it is! It could also be that the lens is front or back focusing slightly - it is worth doing some focus tests with the lens in controlled conditions and seeing if you need to use the mirco-adjust facility on the 7D. I had a similar sharpness issue with my 500 - a microadjustment was the solution.
Colin
Colin K. Work, Pixstel
jpmagero
Mon Jul 30, 2012 10:54 am
Quoting ckw (Reply 7):
no, these are mostly outside the focus point.
Quoting vikkyvik (Reply 3):
those pics look a bit soft for that lens...seeing if you need to use the mirco-adjust facility on the 7D
good point...I agree and will do some controlled tests with this body and some of the lenses I use often to see if the focus needs adjustment. I tried taking off all in-camera sharpening/contrast, etc as that seemed to "enhance" the noise in jpg mode, and a result was that all images looked soft and washed out. Depending on the shot, I'll add it back in some, but seems to be NR works better with out it, but as Ryan mentioned above, he sharpens all the way up to 7 with good results so further testing/adjustment needed there.
I realize those shots are mostly underexposed, the reason I left it at ISO-100 was to show the high level of noise in what was a bright sky. I thought that at such a low ISO, there should be next to no visible noise, but it seems like that's not the case.
vikkyvik
Mon Jul 30, 2012 2:40 pm
I find the same on my 50D. Although it's cleaner at ISO100 and 200 than my 1000D was (with proper exposure), it gets a whole lot noisier fast if you underexpose.
I also used the microadjust function on my 50D with my 70-200, as sharpness was a bit lacking when I first got the camera. Seemed to solve the issue.
Quoting jpmagero (Reply 8):
Understood, just be aware that more noise will be visible in an underexposed image.
ckw
Mon Jul 30, 2012 9:58 pm
As I understand it, there is no 'fixed' level of noise associated with a given ISO setting. Visible 'noise' is a result of the strength of the input signal in relation to the electronic noise caused by camera operation. If you underexpose at any ISO, noise will increase because the input signal is that bit weaker allowing the camera noise to become more visible.
Of course noise does increase with ISO as well due to the input signal being amplified. However it is quite possible for an underexposed image at 100 ISO to show as much noise as a correctly exposed image at 400 ISO.
Colin
jpmagero
Tue Jul 31, 2012 12:19 pm
Quoting ckw (Reply 10):
I see...I had thought (apparently incorrectly) that at a low enough ISO, there would be no noise. If the image was underexposed, it would simply be dark, not noisy, and that the noise would appear if I increased the exposure in post.
The images were taken in the early evening before sunset with a lot of direct sun-light, but I know that's not the brightest light, so will try some more at high-noon and see how those come out.
ckw
Tue Jul 31, 2012 2:34 pm
Quoting jpmagero (Reply 11):
No, there is always noise - just the heat of the camera internals can create some noise.
you are not wrong here - increasing the exposure will increase both the image data AND any noise. The only error you made is assuming that there is no noise at base ISO.
If it helps, think about audio - the same signal to noise rules apply - if you record a source with low levels, any noise generated by the recording system (hum, tape hiss etc.) becomes much more audible. Record at high levels, and the noise is effectively masked. Of course in both sound and vision, there is a limit to how high a level the recording medium can handle. In both cases, setting the optimum levels (exposure) is the key to the best possible quality.
Back to the original point - noise on the 7D - the problem is that the "recording system" seems to be inherently noisier than some cameras at low ISO - I think it is due to more densily packed pixel sites. However, relative to older cameras, I think noise performance improves at 800ISO and above, which I suspect is due to improvements in how the internal firmware handles noise when the input signal is amplified (or maybe the amplification process is cleaner).
Colin
jpmagero
Tue Jul 31, 2012 2:57 pm
Mark,
Quoting aussie18 (Reply 1):
Do you apply any in camera sharpening, or contrast correction with those shots? Or do you leave it all for post?
dazbo5
Tue Jul 31, 2012 4:08 pm
Quoting jpmagero (Reply 13):
On the 50D, I played around with in camera sharpening but quickly came to the conclusion it's better leaving things neutral and doing everything in post.
Darren
josuek6
Tue Jul 31, 2012 4:19 pm
Hello,
I've been using my 7D + 100-400 for more than a year now and personally I have no complaints. It is an excellent camera and paired with an L lens is just wonderful. The camera does have a different learning curve than others, at least in my opinion. I only shoot RAW as the control you have when editing your pictures is by far bigger than with JPG files.
As many have mentioned, the camera does have a bit of noise in low ISO's but I've found this not to be a problem when applying Noise Reduction in Camera RAW. When sharpening images in Photoshop, I usually do a "selective sharpen" leaving the sky or other background elements untouched so that only the main subject is sharpened. I've found this to be really helpful in reducing the amount of noise in my images.
I have noticed that your sample images are a bit soft, most likely they are a bit out of focus. For aviation photography, I shoot using AI SERVO and using 4 center autofocus points and found this to be the perfect match for my shooting style. I've noticed that using all autofocus points for aviation photography might lead to out of focus pictures, so I always avoid this. Also, I generally shoot between f/6.3 and f/8. In case I need to go lower than f/6.3, I prefer boosting the ISO and removing the extra noise later in Photoshop. The lens is great, but below f/6.3 it gets a bit soft in corners so I try to avoid that.
Here you can find some pictures I've taken with the 7D + 100-400 combo:
Photo © Josué Saavedra
Cheers, Josué.
Silver1SWA
Crew
Tue Jul 31, 2012 5:45 pm
Quoting ckw (Reply 12):
I agree.
Quoting dazbo5 (Reply 14):
When dealing with a somewhat soft lens lens, in camera sharpening helps get that original crisp and sharp. Back to my comment above, I turn in camera sharpening to 7 when using the 100-400 but that is mostly for preview purposes on the LCD. I shoot in RAW and in addition to noise reduction in my first step of post processing, I also adjust sharpness in that same ACR tab. This is all done to the original to get a crisp clean "tack sharp" image before sending it to PS. I use USM at the end only to the resized photo.
Quoting josuek6 (Reply 15):
Interesting. With that lens I can't shoot aviation at f/6.3 unless I'm extremely close and doing a tight composition. I generally have to be at or above f/8 for best results.
jpmagero
Tue Jul 31, 2012 11:59 pm
All - thanks heaps for the replies and advice.
Quoting vikkyvik (Reply 9):
I tried this and after some tests, found that my 100-400L needed a +13 adjustment. Not sure if it was always that bad and I just never noticed, or if this is something that changes over time. Either way, the results with that adjustment are noticeable in the LCD, and I'll soon post a couple examples from earlier this evening once I download.
I was using the single center focus point, but tried this and the results seem pretty good. Will post results soon. Cheers.
vikkyvik
Wed Aug 01, 2012 12:03 am
It's not the brightest, but it's much better light than midday! Better colors, much less harsh.
There's no reason you can't get a bright enough exposure in the late afternoon/evening. I'd say use ISO200, a narrower aperture, and post some new images. I doubt there's a whole lot of difference noise-wise between 100 and 200.
Quoting jpmagero (Reply 17):
Can certainly change over time.
I've always used the center point only. It is a hindrance sometimes, but haven't fooled around with different settings yet.
ckw
Wed Aug 01, 2012 9:09 am
Quoting vikkyvik (Reply 18):
Sadly I think there is in the case of the 7D - which is unfortunate because I'm find the extended highlight function available on some cameras (including the 7D) quite useful. However this is only available at ISO 200 and higher.
Don't get me wrong - I think the 7D is a great camera - so good that when I had to choose between trading in a 1D3 or the 7D to get a 5D3, I opted to trade in the 1D3. Bottom line was that in most situations, the 7D was simply more likely to get the picture I wanted than the 1D3. The tradeoff is a little more work in post to get the image up to (my) standard.
Ultimately all cameras make compromises, and in the case of the 7D its pixel count over image quality. Personally, on the crop sensor, I would have preferred 12mp instead of 18mp, but I'm probably in the minority.
Colin
scopedude
Thu Aug 02, 2012 12:39 am
I use 60D which has similar sensor to 7D. IMO, the highlight DR is also not very good, so I have to turn on HTP (highlight tone priority) which makes ISO200 the lowest. As expected, the noise is also more visible (either due to HTP or ISO200). BUT - with sharp lenses like 70-200 series or 70-300L, I could use less USM (USM also sharpens the noise, btw) and usually in ACR I only need to adjust the NR to 25. It won't remove the noise completely but enough if the image resized to 2000 px wide or less.
I'm thinking of getting the new 5D3, because even 5D2 exhibits quite some noise in the shadow - not much better than my 60D.
I had a D7000 for a brief period, and I'm impressed by the DR and noise of this camera. It's APS, but needs much less NR. problem is I still prefer the overall image from my 60D
5DSR, 6D, X-T1, 70-200 IS II, 70-300 L, 18-55, 55-200
ckw
Thu Aug 02, 2012 9:25 am
Quoting scopedude (Reply 20):
The 5D3 is an amazing camera, and there are many reasons for getting one, but in terms of image quality its not a huge leap from the 5D2 ... maybe 1/2 to 1 stop noise improvement in RAW. Shadow noise is still there if you need to pull shadow detail from the image in post. It is a bit better, but nothing like what can be acheived with the Nikon 800.
I look at the 5D3 as a 5D2 that just works really well!
Colin
Silver1SWA
Crew
Thu Aug 02, 2012 9:38 am
Quoting ckw (Reply 21):
Since image quality is most important to me with my desire to upgrade to full frame, that is the reason why I chose to go with the 5D2 right now instead of the 5D3. I keep hearing IQ that much better than the 5D2. It just means I need to keep my 7D around for speed, but having a second body is never a bad thing anyway!
And I've always felt the 5D2's ability to pull detail out of shadows is ridonkulous. Especially compared to the 7D...
[Edited 2012-08-02 02:49:18]
ckw
Thu Aug 02, 2012 11:14 am
Quoting Silver1SWA (Reply 22):
Which makes perfect sense - I figure you're getting pretty much the same image for a much lower price tag ... though I think at very high ISO you do begin to see a greater difference with the 5D3.
Basically the money for the 5D3 goes in to the "shell surrounding the sensor" - no question, its the best package you can get from a Canon short of a 1Dx - you're paying more for the ability to capture the image rather than the image quality. Depending on how you intend to use the camera, this may or may not be worth the extra - there are plenty who have opted not to upgrade ... some waiting (hoping) for a high MP (40mp) 5D.
Colin
Users browsing this forum: Ilyushin76 and 1 guest
