Newark727
Any Experience With Canon EF 28-135mm Is USM?
Fri Aug 31, 2012 5:04 pm
I got this lens at the end of 2009 along with my current camera (50D) and my first telephoto zoom, and it's served me pretty well. However I notice a strong tendency toward chromatic fringing, and a pretty shallow depth of field (for airplanes, most of the nose and fuselage will be in focus, but I will start to lose it around the tail.) Usually I have been shooting around f7.1 to f8.0 in manual exposure for that. Recently I tried changing that to f10 or f11 and it seems to help, though at the expense of a bit more grain as I had to increase the ISO to compensate. Anyway, I guess I'm asking if any of you all have used this lens for aviation photography, and if so, what settings work best for you. Also, if I was looking to "upgrade" from this lens in some way, is there anything out there that you find is much better?
Thanks for your advice!
dazbo5
RE: Any Experience With Canon EF 28-135mm Is USM?
Fri Aug 31, 2012 6:30 pm
Quoting Newark727 (Thread starter):
There are no 'best' settings as it depends on the light on the day and what you're trying to acheive. However, if you're using it between f/8-10 with a suitable ISO / shutter speed for the light and what you're trying achieve, it sounds like you've reached the limit of what the lens is capable of giving you.
Canon 24-105 F/4 L. CA is minimal and it's sharp and fast, but at a cost.
Darren
vikkyvik
Fri Aug 31, 2012 6:50 pm
Depth of field shouldn't be dependent on the lens. How far are you from the aircraft in question? At distances of a couple hundred feet, and apertures of F7 or F8, DOF shouldn't be too much of an issue. And even with a different lens, you should still come out with about the same DOF.
Using this:
http://www.dofmaster.com/dofjs.html
For a 50D, shooting a subject from 150 feet away at 100mm at F8, your DOF is 400 feet. Once the subject reaches 216 feet away, your DOF is infinite.
Are you sure it's not the lens getting soft toward the edges? When I used the 70-300 IS USM, at longer focal lengths, the noses and tails were often pretty soft, since they were toward the edges of the frame.
ckw
Fri Aug 31, 2012 8:29 pm
The 28-135 is a pretty old design and wide to telephoto is the most difficult lens to design - basically its an assembly of compromises!
The more recent 24-105 does a much better job of this, but doesn't quite have the reach.
If the telephoto end of things is of most interest, then a 70-200 would offer much better image quality - I'd suggest the 'old' non IS 70-200 which can be had 2nd hand at a good price. The IS on the 28-135 isn't up to much - I don't think you'd miss it.
If wide angle is more important then the 24-105 is a good purchase.
Colin
Colin K. Work, Pixstel
Newark727
Fri Aug 31, 2012 9:24 pm
Quoting vikkyvik (Reply 2):
Now that you mention it I think it's actually this, and I just didn't properly identify the problem. Though the edge softness problem extends toward very wide focal lengths as well.
