yerbol
Crew
AF-S Nikkor 28-300mm F/3.5-5.6G ED VR Lens
Sat Nov 10, 2012 12:21 am
Dear All,
Sometimes we do want to travel light. Sometimes we do not have much time to swap lenses.
What are your thoughts about this lens?
Is it going to be faster than 70-300mm VR on Nikon D90?
What about its optical performance/clarity/sharpness/contrast?
Please advise if you had any experience with this lens.
Thanks in advance.
Brgds, Yerbol
With best regards from Almaty
alevik
Crew
RE: AF-S Nikkor 28-300mm F/3.5-5.6G ED VR Lens
Sat Nov 10, 2012 1:03 am
Yerbol;
I picked up this lens earlier this year and have done some aviation photography with it. The quality of images is quite good, and I use it just as you say to be able to travel light, having a wide to a tele in one lens.
If you look up some of my images I indicate the lens I used (Photographer Alevik) in the remarks.
Peter
Improvise, adapt, overcome.
yerbol
Crew
Sat Nov 10, 2012 3:00 pm
Peter,
I saw your air-to-air photos. They look very good. I think that for air-to-air photos you need a fast focusing lens.
It is fast in focusing?
alevik
Crew
Sat Nov 10, 2012 5:18 pm
Yerbol -
Yes the lens is quite quick to capture focus.
Peter
yerbol
Crew
Sat Nov 10, 2012 5:50 pm
Thanks for advise Peter. I'll look into this lens closer.
andyhunt
Crew
Sat Nov 10, 2012 10:32 pm
I also use this lens......it works very well. I echo what Peter has said.
Andrew
Full frame always beats post processing
yerbol
Crew
Sun Nov 11, 2012 1:58 am
Thanks Andrew!
If two head screeners said "OK", this lens is definitely worth attention
Users browsing this forum: Bing [Bot] and 1 guest
