bricejohnson
Resizing In Photoshop
Fri Dec 14, 2012 1:05 am
Hey Everyone!
I was wondering what size to resize in photoshop to get pics accepted here, and when resizing, if I should use bicubic sharper or bicubic smoother?
Thanks.
Calvin
mjgbtv
RE: Resizing In Photoshop
Fri Dec 14, 2012 2:46 am
Hi,
I resize to 1024 or 1200 px wide with a 4:3 or 3:2 aspect ratio. 1000 x 667 is the minimum.
The conventional wisdom is that any flaws will be less apparent at a smaller size. However, I sometimes find that I get a less 'jaggy' image at 1200 than 1024/1000.
I do not use PS, but from a search of other threads the advice seemed to be about equally mixed in favor of bicubic sharper or 'normal bicubic'. I did not see bicubic smoother mentioned, so I do not know if that is a third option or if normal=smoother. I'd say try both and see what gives you better results.
vikkyvik
Fri Dec 14, 2012 6:46 am
Depending on the quality of the original image, I typically resize to 1100, 1200, 1280, or 1400 (very occasionally 1024 or 1600). As mjgbtv stated, the minimum size is 1000x667, and the maximum is 1600x1200. I generally use just normal Bicubic (neither Sharper nor Smoother) for A.net shots, as I prefer to do all the sharpening myself.
As for 3:2 versus 4:3 aspect ratio, it all depends on what looks best for the image. But don't change the aspect ratio while you're resizing; that will shrink or stretch the photo in one dimension. My very basic workflow goes:
1.) Level the photo.
2.) Crop.
3.) Adjust exposure/contrast/color.
4.) Noise reduction if necessary.
5.) Resize.
6.) Sharpening.
7.) Selective noise reduction if necessary.
Quoting mjgbtv (Reply 1):
I actually feel similar. I find I can accurately sharpen much easier at 1200, or even 1100, than I can at 1000/1024.
chriswade
Mon Dec 24, 2012 1:19 pm
I always resize to 1024 with a 3:2 or occasionally 4:3 depending on the photo. Just a lovely size i think
