bricejohnson
Which Zoom To Buy?
Tue Dec 18, 2012 12:38 am
Hey Everyone!
I was wondering what zoom I should buy for my camera. I have a Nikon d3100, and am currently using a 55-200mm lense for my spotting. So which one should I purchase... the Nikon 55-300mm or Nikon 70-300mm? I also noticed that the 70-300mm is a more expensive model, why?
Thanks.
Calvin
DL747
RE: Which Zoom To Buy?
Tue Dec 18, 2012 2:28 am
Hello. I also have a D3100 and the 55-3000, but I would suggest the 70-300 for its superior build quality and faster AF, along with its better long end sharpness. The 55 is really soft beyond about 225. I have heard the 70 is less affected, but still soft, as many cheaper zooms are. My
Just like the shirt says, Boeing Builds It Better!
yerbol
Support
Tue Dec 18, 2012 3:08 am
Hi,
My vote for 70-300mm. Faster, accurate focusing, sharpness.
Have you checked Nikon 18-300mm lens? Perhaps you may like it for its versatility.
With best regards from Almaty
afterburner
Wed Dec 19, 2012 5:09 am
Quoting BriceJohnson (Thread starter):
Other than what DL747 and Yerbol have written above, the 70-300 is a lens designed for full frame sensor (FX) cameras whereas the 55-300 is only for cropped sensor (DX) cameras.
An alternative to Nikon 70-300 VR is Tamron 70-300 VC USD. It's cheaper but according to reviews I've read the quality is neck and neck compared to the Nikon.
DL747
Wed Dec 19, 2012 5:58 am
Quoting afterburner (Reply 3):
   Good point. To Brice: this lens will work fine with your camera. Any Nikon lens will work with any Nikon body, but put a DX on an FX camera, and you get the sensor crop even though you have a full frame body. FX will work fine on DX and FX, so if you are considering going full frame, then get the 70-300.
I have also heard that, but some say that is softer wide open and at the far end of the zoom.
Tomskii
Wed Dec 19, 2012 1:02 pm
Quoting DL747 (Reply 4):
Hi,
I own the Tamron 70-300mm for the Nikon and maybe I'm in luck but I have one that stays quite sharp till 270. Between 270 and 300mm it gets soft like most lenses. The only issue with the tamron is that in Aperture or shutter priority it might choose a setting which does not allow enough light on the sensor. Solution is to manually tell your camera to overexpose the picture (+/- sign) with 1 stop. I have not got this issue with my Tamron on the D90 but I tend to shoot manually these days so..
Most tests say the Tamron is a bit better than the Nikon for the price you pay. (More bang for your buck). So do read some of the tests and honestly I can recommend this lens when your looking for a good telezoom in the cheaper price range of lenses. (330 EUR isn't that much imho)
Nikon D90 + Nikkor f4.5-5.6 18-105mm + Tamron f4-5.6 70-300mm
