Bruce
Photos Missing From Database
Tue Dec 25, 2012 5:48 pm
Some photos that were accepted 2 days ago are now missing. I've got # 2204039, 2204040, and 2204041. Vanished!
Are they going to come back or should I resubmit them?
Has anyone else had this? If you had any accepted recently check your photos!
Bruce
dlednicer
Crew
RE: Photos Missing From Database
Tue Dec 25, 2012 6:16 pm
I just checked and see them. If you can't see them, try clearing the cache in your browser.
Photo © Bruce Leibowitz
MilanNN
Tue Dec 25, 2012 6:33 pm
I have the same problem. I can't find two photos. One of them OH-ATO was accepted some days ago.
Photographer's Corner show 3819 photos in DB, but actualy 3817.
Could you check it.
Bruce
Tue Dec 25, 2012 7:31 pm
Ok, they're there now - but I never had that problem with browser caching before. Quite odd. Whenever that has happened its been an airliners.net database backup issue.
Bruce
ilpavone2004
Wed Dec 26, 2012 12:09 am
I have the same problem here but unfortunately i don't have the photo id. I've cleared up the cache with ccleaner...right now there are 4 photos missing
dazbo5
Wed Dec 26, 2012 12:29 am
It's looking like a database issue again. I've got about 30 that aren't showing but they're slowly coming back so it looks like DM have it in hand.
Darren
dlowwa
Wed Dec 26, 2012 12:30 am
Hi all,
No images are missing, they are just failing to display properly when searching via your photographer name. If you type in the image id directly, as David has above for Bruce's images, they will appear. Mattia, if you are referring to any of your images added on the 21st, they are all there, for example.
Photo © Mattia Vichi
We do not need you to report any missing images, as the search bug will sort itself out soon. Thank you all for your patience.
ptrjong
Thu Dec 27, 2012 9:12 pm
Quoting dlowwa (Reply 6):
Only to reoccur at this moment, as it does so often. I know the pictures will come back, but I hope DM will fix this issue soon.
dlowwa
Fri Dec 28, 2012 1:44 am
Quoting ptrjong (Reply 7):
To repeat: no images are disappearing or missing, so there is nowhere to 'come back' from. They are simply not displaying correctly in the search.
ptrjong
Fri Dec 28, 2012 8:11 am
They need to come back from not being found.
