Newark727
They Fixed It, But It Doesn't Work (Canon 24-105)
Tue Jan 08, 2013 1:15 am
As I described at the end of October, I received a Canon 24-105 L IS USM as a birthday present, and I wasn't satisfied with its functionality, it tended to give me soft images. I rented a copy of the same lens for a day and got much sharper images across the board, but particularly above 60mm of focal length. This was evidence enough for me to go back to the store and ask them for help with my version of the lens. They cited calibration and told me to take it to Canon, who fortunately have a repair shop near where I live. This was done; the Canon report cited an improperly assembled autofocus assembly. But the lens still isn't really where I want it. It is now solid up to about 70mm but above 80mm or so it still doesn't get a very crisp focus. So now I'm wondering how to bring the whole issue back up. Returning to the Canon shop would seem my best bet but when I first took it in, it sounded as if there were only certain types of repairs they were actually authorized to do, which is confusing and calls the camera store's suggestion of micro-calibration into question.
So I guess I'd like either advice or personal experience with this sort of affair. Many thanks in advance.
gabik001
RE: They Fixed It, But It Doesn't Work (Canon 24-105)
Tue Jan 08, 2013 3:37 am
Depends on what kind of body do you have try to do microcalibration. It will help a lot. Here is a link how to properly do that : http://www.northlight-images.co.uk/a...ameras/1ds3_af_micoadjustment.html
If it still does make you unsatisfied try to claim canon repair . Hope it gonna work for you.
Canon 50D gripped + Canon 70D + 17-40 L + 24-105 L IS + 50 f/1.8 STM + 100-400L IS USM + Minolta X300 w/ 35-70 f/3.5
dazbo5
Tue Jan 08, 2013 8:32 am
If you aren't happy with it, ask the shop to replace it for a new one? Although it might be a little late for that now. I know what you're going through though. One of my Sigma lenses has been in and out of the workshop since last October and I still don't have it back. If i'm not happy with it when it comes back, it will be sent straight back with a cover note. I'd do the same with your Canon until you're happy with it. It's not a cheap lens and there are known softness issues with some examples. I was happy with my 24-105 first time but I know others on here weren't and got replacements until they were.
Darren
shufflemoomin
Wed Jan 09, 2013 10:12 am
I presume the lens was bought as new when it was given to you as a present? It's unacceptable that it came from the factory with an incorrectly assembled AF mechanism. I wouldn't have accepted a repair on a new lens, I'd have insisted on a replacement, which is what I suggest you do now since they've looked at it once and you're still not happy. If you're certain that rented copy clearly performed better, get back to the shop it was bought from and tell them to replace the unit completely.
Newark727
Thu Jan 10, 2013 9:21 pm
Quoting shufflemoomin (Reply 3):
Actually, I have to clarify here, because in my OP I was recounting the Canon repair slip from memory and now I have it in front of me.
"Your product has been examined and it was found that the adjustment of the af assembly was incorrect causing the auto focus to operate improperly - Best focus and lens centering adjustments were carreied [sic] out on the af assembly. Product functions were confirmed."
I'll try gabik001's DIY suggestion first, at any rate.
JakTrax
Thu Jan 10, 2013 9:30 pm
First and foremost don't forget that YOU are the customer and the old adage of the customer always being right still stands. It's not good enough that you should be fobbed off with a repair on a new product that was clearly not fit for purpose. If such a fault is discovered typically within the first 28 days here in the UK the store must offer a replacement, a repair or a refund - whichever is most convenient for the customer.
Even outside the 'cool-off' period it's worth seeking a replacement, as a product describing itself as 'professional' should not fail in just a couple of months.
You really do have to stand up for yourself in situations like this, because the vendor will try and get away with as much as possible should you choose to be shy about the matter!
Karl
