xtransx
Remark Added?
Wed Jan 09, 2013 1:23 pm
I had the following photo added last night. http://www.airliners.net/photo/USA--...ockheed-EC-121H-Warning/2211760/L/
I didn't add the remark regarding spares from this aircraft being used to keep another aircraft flying. Could the screener have added the comment during the screening process or is this a glitch and I should get it corrected? I certainly haven't had this happen before.
Thanks, David
ptrjong
RE: Remark Added?
Wed Jan 09, 2013 3:51 pm
Sometimes other users request such 'changes' I think, and they're sometimes approved. I find that a litttle strange as well, especially when it's not a correction of an error.
Peter
xtransx
RE: Remark Added?
Wed Jan 09, 2013 11:39 pm
Thanks Peter.
The photo had only been accepted 5 hours prior to me seeing the remark so it never occurred to me that someone may have used the correction functionality to update the remark. Absent of any other reason, I have to assume this is what happened.
I have no idea if the comment is even legit, so if it isn't it looks like I made a wrong statement. Oh well, not sure if I should do anything about it.
David
dlowwa
RE: Remark Added?
Thu Jan 10, 2013 12:56 am
Quoting xtransx (Thread starter):
I'm not aware of an instance where we've ever added a comment. Remarks are at times removed or edited (i.e. grammar corrected), but it is certainly not standard practice to add remarks. Must have been another member requesting the change, as Peter suggests.
vikkyvik
RE: Remark Added?
Thu Jan 10, 2013 2:19 am
Quoting dlowwa (Reply 3):
I'm a little surprised that the editors would actually add a remark to a photo based on a member's request. Is that standard practice?
dlowwa
RE: Remark Added?
Thu Jan 10, 2013 9:25 am
Quoting vikkyvik (Reply 4):
If that's the case, you'd have to ask them, but again, that was only a guess, not any sort of fact.
Tameteora
RE: Remark Added?
Thu Jan 10, 2013 10:36 am
This is certainly not standard practice if the request did not come from the photographer.
We normally do not allow changes to remarks by other users, although we may make an exception if the original remark is factually incorrect. In such cases, and if it's a major change, we will usually contact the photographer first.
Quoting xtransx (Reply 2):
If I may ask, did you add a remark when you uploaded the photo, and if so, do you remember what it was?
Please let me know what you want me to do. I can remove the remark for you, or replace it with something else. To put your mind at ease, the current remark is factually correct. There are also plans to move the forward fuselage to Australia for static display.
Aad.
xtransx
RE: Remark Added?
Thu Jan 10, 2013 1:46 pm
I can't remember, but I doubt I put anything in the remarks. If I did, it would have just been something about the condition of the aircraft and not its status.
I am fine with leaving the remark since you say it is factually correct.
Thanks for looking into this,
David
