Itay747
Problems With Getting Photos Accepted On A.net
Fri Feb 15, 2013 12:32 pm
Hello,
A week ago I got all my photos on A.net queue rejected (mainly for dark, low contrast, quality, soft).
I think I am having a problem in editing properly. All photos before editing are great and well exposed.
Also, I am using CS5 photoshop and I have installed a noise reducing patch called: "Noise Ninja". It might be the problem as it's getting the photo less noisy, but soft too. Does anyone know of a good way to reduce noise?
Itay
ptrjong
RE: Problems With Getting Photos Accepted On A.net
Fri Feb 15, 2013 12:42 pm
You don't need noise reduction on a well exposed 100 ISO image.
Peter
dazbo5
Fri Feb 15, 2013 1:39 pm
Itay,
It might be worth posting a photo or two so we can take a look at give you some help? It's difficult to help without knowing where you are going wrong.
Darren
mjgbtv
Fri Feb 15, 2013 4:58 pm
Quoting Itay747 (Thread starter):
Airliners.net standards are high/specific, so it does not take much to get rejections for any of the above reasons. I (and no doubt others) have had photos that looked fine to me/us get rejected for one or more of these.
You said that you had rejections, so you can post links to them for people to take a look at. I believe that they will not be deleted for at least a couple of weeks. Please note that there is a separate forum intended for this.
Marty
spotterke
Fri Feb 15, 2013 8:52 pm
I always wondered why they are so picky here..a good picture does not necessarily have to be razor sharp and if a runway is a bit of level...what is so important about it..Nothing imo
baldwin471
Tue Feb 19, 2013 1:41 pm
Quoting spotterke (Reply 4):
The most frustrating thing is when i get a photo rejected then see photos that are way less detailed and have far less quality that are accepted. Very odd.
dlowwa
Wed Feb 20, 2013 1:19 am
Quoting baldwin471 (Reply 5):
Really? Please post one of your rejected images that you feel has far more quality than some comparable accepted images. I would be curious to see this, as I'm sure would others. I can post some of your recent ones if you would like.
FYODOR
Wed Feb 20, 2013 7:46 pm
Quoting dlowwa (Reply 6):
Could you post mine? Without border rejection indeed - it is obvious, my mistake.
Fyodor
dazbo5
Wed Feb 20, 2013 7:52 pm
baldwin471 isn't the only one who is seeing this regularly, it's something some of us have been banging on about for a while but it seems to be brushed under the carpet when raised. You've been cc'd in to emails recently when a few of us have raised questions about the quality of some acceptances and consistency in screening, some of which were screener photos but it seems these are being ignored. Does the silence speak volumes?
Darren
[Edited 2013-02-20 12:06:53]
JakTrax
Wed Feb 20, 2013 8:29 pm
I've been asked this very same question but, as Darren will testify, whenever I've linked below-par images (which incidently I never have to look hard for) I never hear anything back. Either that or I get told, "They're borderline", when clearly that's being polite.
I can't speak for Baldwin471's images but there are certainly many in the database inferior to ones I've had rejected lately. With all due respect it's pointless prompting the community to bring to light questionable images if no action is going to be taken.
I'm currently banned for re-uploading an image without changing it. Fact is there's an almost identical image in the database which suffers slightly more from the 'issue' mine supposedly suffers from. Despite explaining this in the 'comments' section - and even linking the other image - someone still decided to issue the ban. Who loses? Certainly not me. I'm still taking photos by the bucketload.
It's simple though: if people feel they cannot trust the screening process, re-uploading without changing will become more and more common. Truth be told I've done it several times lately, with a good rate of success, and I know many others have too. What does this say about the accuracy of the whole process? Can we 'ban' A.net from the www every time one that was previously rejected slips in second time around? Or does this system only work in one direction?
On a related topic, I have noticed quite a few heat-hazed images make it in lately. I'd have thought heat-haze was far more detrimental than a bit of noise/grain but clearly not.
Finally, it's not all bad, as there is still some very down-to-earth, common sense screening going on. I just think we need to see more of it more often.
Karl
dlowwa
Wed Feb 20, 2013 10:56 pm
Quoting FYODOR (Reply 7):
Are you unable to post the links yourself? If so, please start a thread in the Feedback forum, and I will be happy to link to any image you need.
Quoting dazbo5 (Reply 8):
I think you fail to see the point in this case. His images are quite below what would be considered acceptable, and is a good case to illustrate people being unable to look at their own images objectively.
I have seen only a single email from you, and not received any correspondance from anyone else raising the topic. I'm sorry a couple of you are experiencing discontent about which images are accepted and which are not. Unfortunately, as has been stated numerous times, this is a human process where although we try our best, from time to time mistakes are made, be they actual mistakes, or as above, simply perceived as such.
FYODOR
Wed Feb 20, 2013 11:18 pm
Quoting dlowwa (Reply 10):
Sure I can. But it can be quite a long list - you know. In last autumn once I remember I got 19 rejections from 19 uploads. Could it be that experienced photog made 19 mistakes one by one? I might also kind of photogs whose images are quite below what would be considered acceptable. At least my almost 10 years experience here seems doesn't help me.   Thats why I've asked.
Fyodor
dazbo5
Thu Feb 21, 2013 12:12 am
I do see the point but was speaking more generally than about any particular photo. My acceptance ratio is normally quite high so it's not my photos I'm particualy concerned with, it's when looking at others and helping with other members where I see it.
That is accepted, I don't think any of us would disagree with you. However it's not an odd mistake we're seeing these days, there are numerous acceptances and even batches of photos, like the ones I pointed out and you yourself agreed were noisy in your email. Mistakes happen, that's accepted, but isn't the screening process supposed to minimise that by having more than one screener look at photos if there is any doubt? It's a tough job you all do and is very much appreciated, but there just seems some inconsistency creeping in.
Darren
dlowwa
Thu Feb 21, 2013 1:03 am
Quoting FYODOR (Reply 11):
I think the problem may be the fact that you are considering a rejection a mistake. An image is rejected simply because it has been judged not to meet one of the multiple criteria there is for this website. Again, I go back to my earlier point: if you are able to divorce yourself from your own images and look at things a little more objectively, you will see that most rejections were warranted, based on the aforementioned set of criteria.
Looking at your recent rejections, I see a few that if you had taken into account a.net's criteria, you would not at all have been surprised by their rejection. If you do have questions or concerns about a specific rejection, please feel free to make use of the Feedback forum.
Quoting dazbo5 (Reply 12):
Again, that goes back to my point. You seem to have a handle on what is acceptable for here, and are able to look at your own images objectively. Many others are not able to do this, and for that reason we sometimes hear complaints such as Alex has made above. If people were able to a) accept a.net has specific (yes, sometimes picky) requirements, and b) look at their own images objectively, the vast majority of resentment over rejections would likely disappear.
dendrobatid
Thu Feb 21, 2013 10:49 am
Quoting JakTrax (Reply 9):
Karl.
As you admit, you were banned for re-uploading that image and we do not ban the first time that someone does that. You were trying to make a point about the colour (which is admittedly similar to an already accepted Screener image) but you did not even attempt to correct the fact that it was unlevel. The Screener actually had his rejected for that the first time too but corrected and got it accepted at a second attempt. If you had corrected the level you would have been able to say exactly the same, your treatment would have been identical to that of the Screener. You are making it sound otherwise with a half-story.
Share the image (or give your permission for me to do so) and see who amongst your peers thinks it is level !
If you repeatedly re-upload you are simply wasting Screeners time, we are volunteers in the same way that you are, us by screening, you by uploading and if you are caught repeatedly re-uploading you can expect repeated and increasingly long bans!
Alex
I did not recognise your name but have looked and am happy to take a few of your rejections and discuss them here, with your permission, rather than the feedback forum and leave others to find ones that are worse that were accepted. I actually rejected the last one and am perfectly happy for my screening to be put to the test here if you are willing to share the image. Just say the word and I will share your last few rejections for open discussion.
All images fit into two categories the easy to screen and the more difficult to screen. Most of Karl and Darren's fit into the easy to screen, a high proportion are Instantly added and so far all of Alex's have been easy to screen too.
Alex, over to you......
Mick Bajcar
viv
Thu Feb 21, 2013 3:54 pm
Over the years many of my uploads have been rejected. All of these rejections were correctly rejected. This simply means that they failed to comply with one or more of the acceptance criteria. Some of them are among my favourite photos.
spotterke
Thu Feb 21, 2013 6:58 pm
Quoting viv (Reply 15):
Ok how can you say that these were rejected correctly..? Didn't you had pictures that you have thought of they were good/perfect and still got rejected.Be honest,who can say that a certain picture is good enough for the database...no one !
These are opinions that differ from everyone. I can think it is ok,someone else thinks it's not ok and a 3th person says again it's ok. material plays also a role here.A picture can be very good on my screen,but looks like sh*t on the screeners monitor. i had a lot of pictures rejected of what i thought they were good(sharp,level motive,etc) edited by the rules and still got rejected..Very frustrating.Who is the error then? I still think they are far too picky here...
And don't start now with saying don't upload any pictures then..
vikkyvik
Thu Feb 21, 2013 7:48 pm
Quoting spotterke (Reply 16):
What do you mean, how can you say that? I can say that most of my rejections were correctly rejected as well. I look at my rejections, and for the most part, I can see why they were rejected.
It's a learning process - you learn how to edit on your screen so that they will pass A.net screening. It probably took 100+ acceptances before I felt I had a decent idea of how the images should look on my screen to pass screening.
OK, I won't say don't upload. But at the same time, I don't really understand why people get so pissed off over the screening here. There are plenty of other places to upload if you don't want to deal with the standards here. I'm not saying the screening standards are good or bad, but they are what they are. As others have said, it's the house style.
spotterke
Thu Feb 21, 2013 8:26 pm
Quoting vikkyvik (Reply 17):
Quoting spotterke (Reply 16):Ok how can you say that these were rejected correctly..?
Quoting spotterke (Reply 16):material plays also a role here.A picture can be very good on my screen,but looks like sh*t on the screeners monitor. i had a lot of pictures rejected of what i thought they were good(sharp,level motive,etc) edited by the rules and still got rejected..Very frustrating.Who is the error then?
Quoting spotterke (Reply 16):I still think they are far too picky here...
Quoting viv (Reply 15):This simply means that they failed to comply with one or more of the acceptance criteria. Some of them are among my favourite photos.
What i want to say is that i don't understand the need to be so picky. For example why/who bother(s) if a runway is a half degree off level...I mean who cares about such minor detais. When i look at pictures,it's about the planes to me and i realy don't care about the background of the picture.And there are a lot more of such needless rules.. It is a hobby for the most of us,so keep it a hobby and not a competition..
vikkyvik
Thu Feb 21, 2013 8:48 pm
Quoting spotterke (Reply 18):
Me. I much prefer seeing photos that look/feel level than ones that don't. Especially my own photos - I'm a huge critic of my own photographic skills. And while I certainly don't define myself as a photographer by A.net's standards, this website has certainly helped me quite a bit.
A good background can make or break a photo for me. If I see two standard side-on shots of, say, an AA 738, and one has a stunning background and one doesn't, I know which one I'll look at.
Why would you let a website dictate a hobby for you? That's your business, not A.net's. This is a hobby for me too, and part of that hobby is uploading here. Nothing really competitive about it.
dendrobatid
Thu Feb 21, 2013 8:59 pm
Well, I think that sometimes silence does speak volumes but it is good to see that you are CCing Baldwin741 as he has complained of worse images accepted than his rejected ones. I challenge anyone to find worse than these, four of his recent rejections - there are more of a similar standard. My caveat is taken in the last 10 years, accepted in the last five.
I have invited him to agree to the images being shown here but he has not replied either here or to the personal e-mail. However his comments are being taken at face value as criticism of the team and I am now sharing them for you to make your own minds up - his criticism should not be accepted at face value without us being able to respond effectively.
Mick Bajcar
spotterke
Thu Feb 21, 2013 9:06 pm
Quoting dendrobatid (Reply 20):
Quoting dazbo5 (Reply 8):baldwin471 isn't the only one who is seeing this regularly, it's something some of us have been banging on about for a while but it seems to be brushed under the carpet when raised. You've been cc'd in to emails recently when a few of us have raised questions about the quality of some acceptances and consistency in screening, some of which were screener photos but it seems these are being ignored. Does the silence speak volumes?
Wow these look like they were taken with a cell phone...and that's accepted?? Well it looks like there is a lot of nepotism done to me
dendrobatid
Thu Feb 21, 2013 9:11 pm
Quoting spotterke (Reply 21):
No, none of those were accepted. They are rejections but he said that worse quality ones had been accepted. Of course, that is not the case but his allegation could not be left unchallenged which is why they have been posted, a rare decision to do so.
Mick.
ckw
Thu Feb 21, 2013 9:27 pm
What a lot of people don't understand is that looking at pictures requires practice and skill just as taking pictures does.
You need to look carefully at thousands of pics before you really begin to understand what makes or breaks a picture. I really believe that many people who complain about pics being rejected which are "just as good" as those in the database simply don't see the difference - they haven't developed that 'critical faculty'.
To make an analogy, there are very few people who "get" modern jazz at first listen - you need to educate your ear. To look at photos critically, you need to educate your eyes.
Of course, at the other extreme, for people who look at 100s or 1000s of images a day, even the smallest imperfections stick out like a sore thumb (like a bum note to an experienced musician).
Is A.net too critical? Well that's another matter - I personally don't agree with some of their acceptance criteria and therefore lose some interesting shots. But it is what it is - if you want to play here, then that comes with the territory.
And of course there's a sort of paradox - people want to upload here rather than elsewhere, and complain it's too hard, completely missing the point that it's these very standards (like them or not) which has made A.net the first choice for many contributors.
The examples Mick has posted are good examples - I'm sorry, these are snapshots, not photographs. And the best photographers in the world start here. What makes a photographer is a willingness to find the flaws in the picture, learn from that and then apply what you learned next time you go out. It never ends. I'm still learning after over 30 years of shooting ... in fact, the whole "next time ..." thing has probably been what has kept me so engrossed in photography all these years.
Colin
Colin K. Work, Pixstel
dazbo5
Fri Feb 22, 2013 8:17 am
Mick,
Baldwin741 hasn't been part of our discussions, it's Dana that has been cc'd, not other members. I agreed with Baldwin741's statement above, I wasn't agreeing anything about his photos as none have been shared until you provided them. Apologies if you got that impression, but it's a few of the MAN photographers that have been discussing things and raising issues with Dana as we seem to be seeing more and more inconsistent application of the acceptance criteria and some puzzling acceptance when you consider some that have been rejected with less noise or lower contrast for example. Since Dana asked for examples, we've provided some. Many of us have emailed the general screening address and rarely, if ever receive a reply. We appreciate the work load you guys have and that it's done in your spare time and odd mistakes are bound to happen, but when you don't get a reply to anything and you see more than just the odd acdeptance or rejection that is puzzling, it starts to make you wonder. Dana is very helpful in that way and is why a lot of discussion goes his way, simply because he's open to discussion. I've said my peace behind the scenes and thank Dana for taking the time for an open and frank discussion about it.
Darren
[Edited 2013-02-22 00:26:42]
viv
Fri Feb 22, 2013 10:05 am
Nope. But then, I have never shot a photo that I considered to be perfect.
derekf
Fri Feb 22, 2013 2:34 pm
So then, you've uploaded photos that you knew would be rejected?
I would have thought that most of us upload thinking they are all good enough - if you knew they were going to be rejected why would you upload them?.
Whatever.......
dazbo5
Fri Feb 22, 2013 2:39 pm
Mick,
Can I just add to my post previously as I was limited by time this morning, work always gets in the way! Having seen examples of Baldwin741's photos, while I agree with the statement made initially, I have to disagree when its applied to these photos. Quite clearly, these photos don't make the grade for here as they fail to meet the required quality on many fronts. It wasn't Baldwin741's photos I was alluding to specifically given that none were available, it was purely the statement being made I was agreeing with. It was specific examples I mention in my previous post and in emails to Dana that I was alluding to. Can I just say for the record, I have never been in contact with Baldwin741 or cc'd him in to any emails. Apologies if there was any confusion.
Darren
[Edited 2013-02-22 06:46:50]
JakTrax
Fri Feb 22, 2013 3:30 pm
I was sure to include this line, and I'm glad I did! Alex, please don't take offence when I say this but if you view your images as equal to or better than anything accepted here (even those images added at the site's conception many moons ago) then you really do need to acknowledge exactly what makes a good photograph.
Quoting viv (Reply 25):
Interesting stance. While I agree that no photograph can ever be perfect, this is simply because as individuals we look for different things in an image. If I go out to my local seeking a shot of a rare visitor, I'll normally try and get the aircraft as side-on as I can, and as close to my lens as the authorities will allow. If the sun shines and everything comes together, I have what I consider the perfect shot. Contrary to this, however, is the notion that I could possibly get a better shot some time in the future - but only due to circumstances rather than technical ability (e.g. I may photograph the same aircraft again but be rewarded with a stunning mountain backdrop or impressive cloudscape).
One man's 'perfect' photo will always have drawbacks in the eyes of others. Many people might consider the majority of my images boring, and thus label them 'imperfect'. Much like beauty, perfection is in the eye of the beholder.
Karl
ckw
Fri Feb 22, 2013 4:20 pm
Quoting JakTrax (Reply 28):
Well for me the perfect photo (not that I've taken one!) is a picture which cannot be changed in any way without diminishing it. To use Karl's example, if a cloudscape would make for a better pic, then something was missing from the original. If you look at the acknowledged masterpieces of the last 100 years, you'll see this is the case - download a copy into photoshop and try and improve it.
Colin
dendrobatid
Fri Feb 22, 2013 4:53 pm
Perfection in photography to me can be summed up in two words (nothing to do with aviation)
Ansel Adams
Though Stephen Dalton works well too
I have a photo on the database that is close to perefction for me, and whilst even my Wife likes it (a novelty for an aircraft one) it is not one of my more popular images.....
Darren, noted your comments, thanks.
Mick
ckw
Fri Feb 22, 2013 8:41 pm
Ansel Adams is a great example - and follows on from Karl's comment nicely (sorry Karl, not meaning to pic on you, but your comment fits so well). If Adams saw a scene, and the clouds weren't right he waited til they were. Or revisited the site time and time again until it all fell into place.
The thing is, Adams could see in his mind in exact detail the photo he wanted, and wasn't interested in anything else. This to me is the essence of photography, and in fact what separates 'photographs' from 'snapshot'.
This is why no matter how good the equipment, it is the brain behind it that really matters. The equipment makes capturing the pre-visualised image easier, but it can't compensate for the lack of thought.
Colin
JakTrax
Sat Feb 23, 2013 2:42 pm
Quoting ckw (Reply 31):
I'm certainly not going to compare my ability to that of Ansel Adams (whoever he is!) but this sounds a lot like myself. The other day I shot an aircraft in what little sun there was. I decided I could get a better shot as the sun got lower, but the sun's re-emergence was looking unlikely; still, I chose to wait. Well I waited. And waited. And waited. Finally, after two hours of waiting in the cold for the next gap of blue sky, I got the opportunity to nail it the way I wanted - even managing some dark, contrasty clouds in the background.
I have done this many times in the past, with people labelling me nuts! But if you have the time and patience, why not?
One of my most popular images here is this one:
Photo © Karl Nixon
A nice enough image, but for me far from perfect. The end result hides the imperfections quite well, but I was actually hoping for a particular set of circumstances to all come together. I spotted the aircraft and the sailboat, and also noticed the setting sun, but everything didn't move as I wanted and I couldn't get the sun in the frame. I had to settle for second-best, but the good thing is that no-one but me knows that this shot didn't quite work out as planned. Who says me not capturing the sun in the frame was deliberate? And who knows it wasn't?
There is a story behind most images. How aesthetic or perfect an image is in my mind depends on whether it illustrates the story the photographer was trying to tell. In my case there's a little piece of the story missing from the image, so it's unfortunately not perfect.
Karl
mjgbtv
Sat Feb 23, 2013 3:02 pm
A photo rejection thread 'degrading' into a positive discussion of artistry. What are things coming to??
Garyck
Crew
Sat Feb 23, 2013 4:35 pm
Quoting mjgbtv (Reply 33):
I was just thinking the same. Perhaps time to be locked, or get back on track.
Keep your Ladders close, but your camera closer
JakTrax
Sat Feb 23, 2013 4:59 pm
I think mjgbtv meant that it was actually a pleasant surprise. Nothing to gain by locking this one.
mjgbtv
Sat Feb 23, 2013 5:08 pm
Quoting JakTrax (Reply 35):
FYODOR
Sat Feb 23, 2013 9:20 pm
Quoting JakTrax (Reply 32):
Karl, you are too crtitcal to the one of the best shots from SXM in local collection
FYODOR
Sat Feb 23, 2013 9:53 pm
Quoting dlowwa (Reply 13):
Dana, we could a bit play with words indeed to be more polite, but if you do your job on standards and you are not fill the standards it mean you've made a mistake. Thats clear however there are many ways to call it on more positive way
As I mentioned before - I'm here for almost 10 years and not novice in Anet. I was not surprised until 2009. Since that time seems something wrong did happened. As you say 'objectively' - it should happened with me. I just can't find what is that exactly?
Quoting dendrobatid (Reply 30):
Ansel Adams
Great selection, Mick. It shows as a person with very good taste. My respect to you as he is one of my favorite as well. We even had learned his Zone System in photography school.
Well... I just thought... If Adams would be still alive, if he would like to make aviation photography, if he would came here... What acceptance ratio would he have?
bravosierra
Wed Feb 27, 2013 4:22 pm
What happened with the screening process if my colleagues suffering starting from mid 2011 from the fall in the acceptance rate from 95-90% to 30-40%??? I ask myself do they shot worse than in the 2009-2010??? No, in fact they improve their skills, bought new, more efficient equipment… So something wrong on the opposite side.
