KelvinCJ
Lens Micro-focus Adjustment?
Wed Mar 20, 2013 12:10 pm
Dear all,
I have thought that my L lens seems to suffer from some sort of front/back focus problem, and believe my theory may be correct.
I have attempted to test the focus by running a MFA test, though am not sure if I have done so correctly and hoped to post my test results here in case any of you kind people may have other recommendations, advice or tips.
I shot at 400mm, using f/6.3, iso of 500 and for all but the last (+10) image, 1/400 shutter speed.
The object was approximately 11m away from the camera (not quite the 50x focal length rule), and the area of focus was the barcode.
(no adjustment '0'):
http://www.flickr.com/photos/kelvincj/8573723591/
(+2adjustment):
http://www.flickr.com/photos/kelvincj/8574817454/
(+5 adjustment):
http://www.flickr.com/photos/kelvincj/8573723527/
(+7 adjustment):
http://www.flickr.com/photos/kelvincj/8573723477/
(+10 adjustment):
http://www.flickr.com/photos/kelvincj/8574817366/
Hopefully you will share my opinion that the first (no adjustment) and last (+10) are the worst of the examples presented.
From the examples given, I seem to lean to (+5) giving the best clarity of the barcode and text, though believe it is or it could be anywhere from (+2) to (+7)?
I appreciate with the noise and image distance it is perhaps not a great test, but would greatly appreciate any help and advice all the same.
EDIT: Added links to images as they do not appear to be embedded?
[Edited 2013-03-20 05:13:04]
[Edited 2013-03-20 05:20:52]
SNATH
RE: Lens Micro-focus Adjustment?
Wed Mar 20, 2013 12:18 pm
Hi,
I would strongly recommend that you get something like the Spyder LENSCAL:
http://spyder.datacolor.com/portfolio-view/spyderlenscal/
It's a small investment, compared to your camera + lenses, and it will make calibration much easier (the scale on the right makes it a bit clear whether the lens is front focusing, back focusing, etc.).
Tony
Nikon: we don't want more pixels, we want better pixels.
ilpavone2004
Wed Mar 20, 2013 12:33 pm
Another possible solution is Focal, a software from Reikan available at the following link
http://www.reikan.co.uk/focalweb/
You print the target and then let the software do what it's programmed to do
Keep in mind that the focus shift changes as the focusing distance changes and as the focal length changes(in case of zoom lenses). This can obviously lead to the point where you have positive correction on one side and negative on the other. It's up to you decide which correction to use.
Moreover for very long lenses this process can be really difficult, due to the focusing distance (that can be as much as 50-100 m )
ckw
Wed Mar 20, 2013 12:35 pm
You don't say, but was your camera on a solid tripod? 1/400th at 400mm is not going to ensure that micro-shake won't effect the results. You should also have IS turned off.
I'm also guessing you mean the 100-400. Unless you have a very recent body, then calibrating zooms is a bit tricky as you are (I think) allowed only one calibration per lens, and of course performance can vary through-out the zoom range.
A good target is a rule set at a 45 degree angle. If you focus (using spot mode if you have it) on the center of the ruler, then you can easily see how much your lens is front or back focusing.
Calibrating requires careful set up of the target and camera (so neither can move) and then a systematic process of shots at say 100, 200 and 400mm. You may find you have to compromise at one focal length to get best results at another. And of course remember.
Finally, I cannot stress enough how important the set up for the testing is. You must eliminate all possible "other causes" otherwise you are highly likely to misset your calibration.
Colin
Colin K. Work, Pixstel
KelvinCJ
Wed Mar 20, 2013 2:37 pm
Thank you all for the replies.
Tony - regarding the calibration equipment - I realise this is perhaps the best way to go - and agree that it is a small investment for (hopefully) worthwhile results, but I merely resent the fact that you are effectively paying for mounted paper and plastic - is there no way this can be done without spending a relative large sum of money on such a simple object?
- I have not used any calibration software / objects before - hence my reasoning for this topic, personally, is it worthwhile? At the moment I only have my (as Colin correctly guessed) 100-400mm L lens, so am not sure if it is a worthwhile investment when I have only one lens to utilise at this point?
ilpavone2004, thank you for the link - I was looking at that earlier - though do not think I can obtain it unfortunately as I do not have a Paypal account.
My apologies Colin - I was indeed using a tripod - but do share your view that it is perhaps not the most determinant of tests under such conditions.
I have read / heard of people using the Canon software - with their camera connected to the computer, and viewing the Live View image at 200x magnification - and adjusting it that way?
Though, I have often wondered / thought that the focussing method was slightly different between live view and merely using a viewfinder and may therefore produce slightly different results?
I apologise for all my questions and bothersome nature, though I do greatly appreciate all of your advice and input.
SNATH
Wed Mar 20, 2013 4:07 pm
Quoting KelvinCJ (Reply 4):
Here are some instructions on how to make a DIY version of it:
http://www.imaging-resource.com/news...tion-and-the-importance-of-backups
And I agree with you that LENSCAL is overpriced for what it is. On the other hand, I don't have much time for DIY these days.   So, I was happy to just pay for it.
You should not apologize, this is what this forum is for.
Tony
KelvinCJ
Wed Mar 20, 2013 4:49 pm
Thank you for the help.
I decided to give the EOS Utility a try - and it seemed to correlate with my earlier results - that the resolving power (image detail) is greatest at +5 MFA.
However - that does not necessarily mean that it fixes my focus 'issue' - but at 100mm and 400mm, it seems to offer the best resolving detail opportunities.
So - I will indeed look at getting a hold of one of those micro-focus kits, when funding permits! But for now, will perhaps leave it at +5 and see how that turns out.
I attempted the ruler idea that you kindly suggested Colin - and could see no major noticeable difference between 0, +2 or +5. Save, for +5 also making the surrounding text / detail much clearer.
Yet - on the few shots I have taken with my new configuration, when they are out of focus, they are really out of focus - but when in focus, the clarity is much better than what I was seeing before.
I imagine I also need to take a look at adjusting the autofocus settings, but that is another matter entirely!
