stoney55
ATC & Lens
Sat Apr 06, 2013 10:09 pm
Hi guys im a big plane enthusiast and want to be able to listen to ATC convos aswell as taking close up pictures of planes. So with the ATC towers what device can i pick up for 50-100 quid which will allow me to do that and will it need to have the 8.33Mhz split feature as i read somewhere it will?
as for the lens what sort of lens is good for pics about 100-200 metres from the runway? i use an old sony SLR at current.
oly720man
RE: ATC & Lens
Mon Apr 08, 2013 10:56 pm
There is a wide selection of radios here, though some are discontinued.
http://www.javiation.co.uk/
Comments re: 8.33kHz (not MHz)
http://www.javiation.co.uk/833.html
As for the lens, what planes? Cessnas or A380s?
If your maths is up to scratch you can calculate the viewing angle for an aircraft at a distance.
tan (half view angle) = half length of aircraft/distance.
e.g. B737-800 at 100m, length is 40m -> tan(half angle) = 20/100 = 0.2.
View angle = 22.6deg.
http://en.wikipedia.org/wiki/Angle_of_view#Common_lens_angles_of_view
From the wiki page this horizontal view angle is for a lens just above 85mm.
For an A380 at 100m the angle would be 41deg, so a focal length just less than 50mm.
You won't want the aircraft to fill the viewfinder completely so the angle will be a bit bigger and the focal length a bit shorter.
You'll have to check what you can get for a Sony SLR to cover from perhaps 40mm to 200mm. This may mean 2 lenses. Sony bought out Minolta so you should be able to get Minolta Maxxum AF lenses for your camera or Sony A mount.
There are some 18-200mm lenses for the more recent digital cameras, e.g. Sigma and Tamron but you may need to try them out with a local camera shop to confirm they work with your camera.
Users browsing this forum: bombayduck and 1 guest
