theweatherman
Help With Canon 60D Settings
Wed Apr 10, 2013 7:32 pm
Hello,
I am brand new to the world of aviation photography. I have recently purchased a Canon 60D and went to IAH to do some shooting. I was very disappointed with thw results so I deleted them all. What settings are current 60D users using to get the best photo?
oly720man
RE: Help With Canon 60D Settings
Wed Apr 10, 2013 7:52 pm
Some will use Manual, some will use Av with the aperture at f8. Depending on the light the ISO will be pushed up to get a suitable shutter speed. The shutter speed, ideally, should be faster than the inverse of the focal length of the lens. Note the 60D is a APS-C camera with a 1.6 crop factor so the focal length at the sensor is 1.6x what the lens focal length is. 200mm => 320mm, etc. and a shutter speed of 1/250s or 1/500s at this focal length
Pity you trashed the photos, you should have kept them to do a CSI on them to see where you went wrong.
What lens were you using? What was the weather like? What time of day was it?
To start off, really, you're going to want a sunny day with the sun behind you, not midday and, perhaps, the plane not moving so you don't have to worry about following a plane or getting confusing exposure meter readings from the sky. Overcast days tend to give flat contrast and drab photos.
Set the focus point to the centre and use spot metering so you're getting the exposure from the aircraft itself.
Also, read the manual and get a photography book to learn the basics about aperture, shutter speed, ISO, exposure compensation, etc.
vikkyvik
Wed Apr 10, 2013 9:11 pm
Quoting oly720man (Reply 1):
My suggestion is to go out and shoot again, and post a few photos. That will enable us to get an idea of why you were disappointed with the results, and offer some pointers should they be necessary.
drewbelmore
Sat Apr 20, 2013 7:15 am
Nice information to started my journey. Thanks both
theweatherman
Sat May 04, 2013 9:38 pm
G-CIVP
Sun May 05, 2013 7:53 am
Three observations.
i) why did you strip the exif data from the images on flickr? If you want constructive feedback, this vital information would have helped!
ii) You've chopped the stabiliser off the Air France B777. Similarly, part of the tail of the LH A380 has been lost. This suggests you haven't fully mastered your equipment as yet.
iii) The main reason why the photos look slightly odd is probably due to the high sun. Conversely the LH A380 touching down (excellent photo though) is under-exposed or not edited correctly.
No doubt others will provide you with more advice. Best way to improve is to go out and keep on taking photos.
[Edited 2013-05-05 00:58:32]
theweatherman
Sun May 05, 2013 10:03 am
Thanks for the input. I can fix the croping issues. I still have the RAW files. I thought that the main part the screeners wanted to see was the fuselage. Also, I didn't realize the exif data was striped on flickr. I've changed the setting to where you can see it now.
dazbo5
Sun May 05, 2013 11:56 am
I think your main problem, as mentioned above, is the lighting. Most taken in very harsh lighting and are underexposed. I think a better understanding of exposure and the exposure triangle will help you get more from your camera and the reasons why these photos didn't turn out as you may have expected. What mode are you using on your 60D? Fully automatic, aperture priority, shutter priority, manual?
Darren
theweatherman
Sun May 05, 2013 1:47 pm
Darren,
I don't have much of a choice but to shoot around 1 pm in Houston to catch the heavies coming in   I was shooting in aperture priority mode yesterday. I had it set at ISO 200 and kept the aperture between 8 and 10.
[Edited 2013-05-05 06:52:57]
dazbo5
Sun May 05, 2013 2:05 pm
Did you have any exposure compensation dialled in? All are underexposed, a couple by a large amount. Metering on Canon DSLR's is normally pretty good and if anything, in bright sunlight, tends to overexpose slightly rather than underexpose. What metering are you using? Spot or evaluative? If you're using spot, that may account for the underexposure. I suggest using evaluative. If you don't have any options but to shoot at 1pm, then so be it but the lighting isn't great when the sun is that high.
Darren
theweatherman
Mon May 06, 2013 2:45 am
Darren,
I didn't have any exposure compensation dialed in. I had it on Av mode, ISO 200, and had the aperture set at between f8 and f10. That was giving me about 1/600 shutter speeds and faster, so I thought they would come out exposed correctly.
I also had it set on spot metering. I'll definitely switch it over to evaluative next time.
dazbo5
Mon May 06, 2013 7:48 am
Quoting theweatherman (Reply 10):
I also had it set to spot metering
Thats the cause of the underexpore then. Use evaluative and be aware when its bright, you may need to dial in -1/3 exposure compensation. You should see a big difference in your photos then.
Darren
theweatherman
Mon May 06, 2013 11:48 am
Thank you so much for the feedback. I'll definitely make those changes next time out.
