dylanjgrant
Best Camera For A 13 Year Old Starter
Sun Apr 14, 2013 12:00 pm
Hi all,
first time posting for me,.
I just wondered what would be the best camera for a 13 year old beginner who can get near the runway at Southampton?
Thanks to all who answered
dazbo5
RE: Best Camera For A 13 Year Old Starter
Sun Apr 14, 2013 1:40 pm
Quoting dylanjgrant (Thread starter):
It depends on your budget really. How close can you get? What quality do you want / expect from the camera? Are you wanting to take photos of static aircraft, taxiing or fast moving / in the air?
If you have the budget, there's no question an entry level DSLR is the best option. A compact or bridge camera, while good, have their limitations. Don't be tempted by the amount of zoom they offer. While in some situations it's useful, they tend to offer poor quality the more you zoom in and can be tricky to use (keep steady). Shutter lag is also a consideration. For static and slow moving subjects, they are fine. For fast moving subject such as aircraft on approach, they simply aren't fast enough. A DSLR will get around most of these problems, but will cost more.
Darren
PHX787
Sun Apr 14, 2013 1:44 pm
I'm using a Nikon D3200, which is about as entry-level as it can get. They run between $400-700 depending on where you shop. I got mine for about $400 at a camera shop in Japan....cheapest possible route
Mine came with 2 lenses too, so shop wisely.
egondo
Sun Apr 14, 2013 2:20 pm
For motion shots, it is better to use SLRs for their fast autofocus. If you're in a budget, cheap SLRs costs $350 (Nikon D3000). IMO, this is a good body to start your SLR life because it has a 'guide' button to help you with bells and whistles in an SLR. If you want to upgrade, you can use the newest D3200 or D5200. In Canon, the cheapest SLR is the 1000-1100D, and you can also buy the newest 650D, which may be costly.
oly720man
Sun Apr 14, 2013 2:29 pm
Hi Dylan.
If you're hoping to, at some stage, have photos on here then you'll need a DSLR with a reasonable lens, so you're looking at Nikon, Canon, Sony and Pentax, all of which have a range of good cameras. There are perennial arguments about which of Canon or Nikon is best, but don't discount the others, they get good reviews and are aimed more at the amateur/consumer than the professional.
DSLRs and lenses can be expensive when you add it all up so a lot will depend on how much money you've got to spend.
For being reasonably close to the runway, with the planes that come to Southampton you'll need a lens, or lenses, with focal lengths covering the range from around 40mm or 50mm to 200mm.
You can check amazon for prices and see what's available.
For example there's the Nikon D3100 with 18-55 and 55-200 lenses that should be more than enough.
http://www.amazon.co.uk/Nikon-D3100-...oto&ie=UTF8&qid=1365949310&sr=1-27
There will be similar with the Canon 550D, perhaps and either a 18-135 lens or 18-55 and 55-250 lens
You'll also need some SD cards and maybe a spare battery.
For processing the pictures there's Photoshop (if you've lots of money) Photoshop Elements (which is enough for most editing purposes and you can buy from the Adobe website) or there's GIMP that's free and does much the same as Photoshop but without as much documentation.
If you just want to take photos then you can use a bridge camera or compact camera, but get one that has full control, i.e. not one that just has various scene modes. For this you won't want more than a x10 or so zoom. You need to be able to control the exposure rather than rely on the camera. Planes in the sky can confuse cameras because the sky is bright.
After all that, you'll spend a year or so getting to grips with the finer points of taking photos. It's not as easy as it looks and planes are challenging because (i) they move and (ii) the lighting can be difficult.
dylanjgrant
Sun Apr 14, 2013 3:31 pm
Okay thanks.
I am on a budget of about 200-250, so I shall have a look around.
Dylan
JakTrax
Sun Apr 14, 2013 3:54 pm
Dylan, Argos currently offer the Nikon D3000 for £249.99, with a kit lens. It's been discontinued I believe (hance the price reduction) but at 10.2 megapixels would be a great starter DSLR.
Karl
ckw
Sun Apr 14, 2013 4:04 pm
Hi Dylan,
If you're in Southampton you're lucky as we have some decent camera shops with good 2nd hand gear - City Photographic in Bedford Place and London Camera Exchange (x2) opposite the Civic and near the corner of Above Bar and East Street.
You say you can get "near" the runway at SOU - AFAIK unless you're thinking about shooting through fences, then either you mean the carpark (from which you'll get chucked out of pretty quick if you're spotted with a camera) or the hill running alongside the runway. For the hill you probably want around 300mm. If you're considering the approached at either end, then again 300 would be about right, though 200 would be probably be OK
To be honest 200-250 is not going to be enough for a DSLR body and lens, even used. So you'll have to decide whether you want something right now and risk getting frustrated by it in a short time, or wait until you can afford what you need.
If you are just doing this for your own records and enjoyment, then a compact or bridge camera might be fine. If you see this as a starting point for something more serious, then I'd suggest you wait.
One thing you might consider is buying a film camera in the short term which can be had real cheap. Some models will use lenses that you can later use with a DSLR.
Colin
Colin K. Work, Pixstel
dylanjgrant
Sun Apr 14, 2013 4:24 pm
Colin: Do you know where West End Park is? I go spotting there (as I'm 13 and not allowed to the airport) and you can read the reg off with 60x binoculars. A film camera seems a good idea actually! Shall look for one just until I can get a decent cam.
Dylan
dylanjgrant
Sun Apr 14, 2013 4:29 pm
Also just found the Canon EOS 300 / EOS Rebel 2000 135 mm Camera on amazon for 70 gbp,
is that good?
Dylan
dazbo5
Sun Apr 14, 2013 5:40 pm
Dylan,
For the type of photography you're wanting to do, I would stay clear of 35mm film cameras. You'll have the ongoing expense of purchasing and developing film (which is only really the demain of specialists these days) and unless you know the basics of how to use a camera and the exposure triangle, it'll not yield the results you're after. For your budget, a bridge style camera will probably meet your needs but bear in mind the disadvantages with these that I mention above. Ebay can be a good source of equipment, you may be able to pick up a used entry level DSLR and lens for your budget, but be careful to get one with a low shutter count if you can. Many start out with compact / bridge cameras and soon grow out of them as they realise the limitations they have with aviation photography quite quickly. That's were the DSLR's come in as performance is another step up. If you're using 60x binos, you're going to need a long lens to get photos of aircraft. That's were the expense of using a DSLR is, not in the camera body, the lens. A 70-300mm is about the least you'll need with the sounds of it.
Darren
ckw
Sun Apr 14, 2013 8:24 pm
Hi Dylan,
Yes I know West End park well - you can get some great views of aircraft landing/taking off there, but it is a fair distance from the airport. To get the equivalent view of your 60x binoculars you would need at least a 600mm lens.
I think the only way you will get close to this is with a digicam with a long zoom range.
As to film cameras - yes, getting film processed can be expensive ... but you can do it yourself for quite low cost. It really depends if you just want to "spot" aircraft or want to get involved with photography as a hobby in its own right.
You might also want to check if your school has a camera club (or might be interested in starting one). If a club existed, it may be prepared to buy a camera for loan to club members.
Colin
JakTrax
Mon Apr 15, 2013 9:58 am
Despite what's been said above I think the Argos deal on a brand new Nikon D3000 is your best bet. You might need to hurry though, as stocks will soon run low due to it being replaced by the D3100.
Karl
ckw
Mon Apr 15, 2013 11:17 am
Quoting JakTrax (Reply 12):
If the object is to acquire a DSLR, then yes it is a good deal.
But that 18-55mm lens is going to be useless for the scenario described by the OP. Essentially double the price to get the 300mm which is pretty much a minmum requirement.
Bottom line is that for the budget, there will need to be a compromise either on IQ and performance OR lens reach.
Colin
ckw
Mon Apr 15, 2013 1:07 pm
PS to last post.
I just got LCE Southampton's (Civic Centre) used equipment mailout. Amongst other things they have a used Canon 300D for £119 and a 75-300 for £99 which is in budget. Good people at LCE and you get a 6 month warranty.
Colin
epten
Tue Apr 16, 2013 10:52 am
I'd recommend any second hand DSLR.
