HarryImp
300 F4 + 1.4x Vs 100-400 @400
Wed May 15, 2013 3:22 pm
Hi all,
I was wondering if people could help me.
I was looking into new lenses and was wondering, which is sharper/better AF, out of the 300 f4 with a 1.4x Teleconvertor, or the 100-400 at 400mm?
Harry
oly720man
RE: 300 F4 + 1.4x Vs 100-400 @400
Wed May 15, 2013 3:52 pm
I presume you want the 300f4 rather than just going for the 400f5.6? (herein another debate)
Some users here say the 300+1.4 is sharper than the 100-400 @ 400, but the 400f5.6 will be sharper than the 300+1.4. The only downside is no IS. I expect that any differences may be obvious if you did large prints, but you'd otherwise need a magnifying glass to see any difference.
http://photo.net/canon-eos-digital-camera-forum/00ZbZv
HarryImp
Wed May 15, 2013 4:03 pm
Many thanks. I am really very interested in the 400 f/5.6 too, but I go to air bases a lot, and I think that being stuck at 400 all the time, may just be a little long, so the 300 with converter is more flexible?
What about the Autofocus?
Many thanks
Harry
oly720man
Wed May 15, 2013 4:44 pm
I've no experience so I can only go on what I've read.
From what I read the AF is slowed by the IS, but with the shutter speeds you're likely to be using you're unlikely to use IS.
For your purposes the most flexible will be the 100-400 rather than taking the t/c on and off, but the AF on the 300 alone will be faster than on the 100-400. Now, how many fractions of a second difference probably isn't a readily available number.
You may have to hire them and try them out before committing to one or the other.
ckw
Wed May 15, 2013 7:25 pm
I did a very careful comparison of this before selling my 100-400. The 300 with the 1.4 was certainly as good, arguably a little sharper. And that was with a Mk.1 convertor. Presumably with a mk 2 or 3 convertor it will be better.
AF is slowed down by the convertor a bit, BUT the 300 on its own focuses better than the 100-400, so I'd say there's not much in it when you attach the convertor.
Colin
Colin K. Work, Pixstel
vikkyvik
Wed May 15, 2013 7:54 pm
Quoting ckw (Reply 4):
I have the 300 F4 IS and 1.4x Mk3. The 300 on its own is great - very sharp. I'm not sure I'll actually be using it with the 1.4 ever. Seems that sharpness takes too large a hit - might be able to use the 300 alone and crop, and still end up with a better photo.
But to be fair, I haven't played around with the combo a whole lot yet, and it could simply be that I haven't learned to shoot well with it.
HarryImp
Thu May 16, 2013 5:56 pm
Thanks, its a tricky one, as I need one lens that can cover between 300 and 400 with good sharpness, for less than £1000. So basically, 300 sometimes too short, 400 sometimes too long, and the 100-400 lacks quality!!
Harry
vikkyvik
Thu May 16, 2013 6:42 pm
Quoting HarryImp (Reply 6):
Why would you say that? Tons of airplane photographers use the 100-400....
Consider also that you'll have to be swapping the 1.4 in and out. That gets to be a bit of an annoyance after awhile, if you have to do it frequently.
HarryImp
Thu May 16, 2013 6:49 pm
Compared to a prime, it does lack quality does it not?
