FLPhoto
Nikon D300s
Tue Jun 11, 2013 3:52 pm
Hi guys and girls,
I am lookin to upgrade my D3100. I currently have 3 lenses, the 18-55, 55-200, and 35mm f1.8. I have beeen lookin at theNikon 70-200f/4 but because I'm 13, my budget is low (around $1300). I also have been looking at a new body, and I have come down to the D7000 and the D300s. Is the D300s too old? Should I upgrade to the 70-200 and stay with my current D3100?
FLPhoto
Canon 7D, 70-200mm f4 L, 10-18mm f3.5-4.5
trvyyz
RE: Nikon D300s
Tue Jun 11, 2013 5:50 pm
The D300s has better and faster AF system, more burst rate. Better fro action than a D7000. The sensor of D7000 is better IMO. I have D300 and D7000, I prefer D7000 more for non-av, but both of them are good for aviation.
FLPhoto
RE: Nikon D300s
Tue Jun 11, 2013 9:57 pm
What lenses do you use?
FLPhoto
trvyyz
RE: Nikon D300s
Wed Jun 12, 2013 1:51 am
Nikkor AFS 18-105mm VR
Nikkor AFS 35mm f1.8 dx
Nikkor AFS 50mmf1.8
Nikkor AFS 55-300mm VR
Nikkor AF 80-200mm f2.8D
Sigma 18-50mm F2.8 EX
I think the tele f4 lens you mentioned would be a good choice for you.
FLPhoto
RE: Nikon D300s
Wed Jun 12, 2013 3:47 am
Would you recccomend the lens iver the body?
yerbol
Crew
RE: Nikon D300s
Wed Jun 12, 2013 5:00 am
Get yourself a good lens. As per reviews Nikon 70-200mm F4 is a sharp, new gen VR system.
Nikon D3100 will serve you well with this lens. 70-200 is not so heavy so it will fit D3100 nicely.
Photos below were made with Nikon D3100[note the information about lens].
With new 70-200mm F4 VR lens you should get even better result.
http://www.airliners.net/photo/Virgi...d=a8d3b14c1872f03e3a3d85c8ec0ee555
http://www.airliners.net/photo/Indon...d=a8d3b14c1872f03e3a3d85c8ec0ee555
With best regards from Almaty
clickhappy
RE: Nikon D300s
Wed Jun 12, 2013 5:19 pm
Bodies come and go, glass is forever. I think the 70-200 f/4 AF-S would be a good fit with the D3100. Find a local store that stocks it and try it out. You will pay a few dollars more buying local (usually) but supporting your local makes it easier to try new stuff...
FLPhoto
RE: Nikon D300s
Wed Jun 12, 2013 6:28 pm
I will look into the lens. Thanks for the help!
FLPhoto
megatop412
RE: Nikon D300s
Wed Jun 12, 2013 8:09 pm
Perhaps it is too late to be asking this question, but what about your D3100 and 55-200mm is not meeting your needs? Your upgrade path is largely determined by where your current setup is failing you. With the D7000 you would be upgrading your AF and fps(but do you need that?). Beyond that, paying an extra several hundred dollars for slightly better AF, slightly better fps, and significantly better build with the D300s is questionable unless you beat your gear up. And to be honest no one needs pro build except for folks earning a living with their cameras. Problem is, the D7000 sensor IQ is roughly equivalent to your D3100 so I wouldn't change the body unless you need more advanced AF and higher fps.
Lens wise, I went with the 70-300mmVR when upgrading from the 55-200 because I needed the extra 100mm WAY more than I needed f/4. It's become my most trusted aviation lens.
FLPhoto
RE: Nikon D300s
Wed Jun 12, 2013 8:57 pm
Megatop,
I will look morebinto the comparison of both the lenses. I do like the 70-200 f/4, but its is spendy. I could rent one, but I would sort have like the extra 100mm that the 70-300 has. Is the 70-300 sharp? I looked at it but then assumed that it wasn't a good lens. What do you think of it?
FLPhoto
mlevert
RE: Nikon D300s
Wed Jun 12, 2013 11:02 pm
I agree with megatop, you should assess what your current set up is unable to do that you want it to do. I have not used the 70-200 f4 but it is regarded as one of Nikon top end lenses. I consider the 70-300 f4.5-5.6 (the older model the new one is f4-f5.6) to be my primary lens and for me I have never found it not to be sharp or slow which are two of the criticisms you see online of the lens. If you are (or intend to be) a professional photographer, the 70-300 might not be enough and the 70-200 is worth the investment in the long run or if you are an enthusiast the 70-300 is still a great lens that takes great pictures that are worthy of this site. I have used the D5000 + 70-300 combo for all but two of my pictures on this site.
FLPhoto
RE: Nikon D300s
Wed Jun 12, 2013 11:29 pm
Hey,
Thanks for the info. I am very far from a pro, because I am only 13. I will have to look into both of the lenses and look at my capabilities.
FLPhoto
RE: Nikon D300s
Thu Jun 13, 2013 2:16 am
Hey,
trvyyz
RE: Nikon D300s
Thu Jun 13, 2013 3:56 am
Quoting megatop412 (Reply 8):
not really
http://snapsort.com/compare/Nikon_D3100-vs-Nikon_D7000
Advantages of the Nikon D7000
More dynamic range 13.9 EV vs 11.3 EV
2.6 f-stops more dynamic range
Significantly better image quality 80.0 vs 67.0
Around 20% better image quality
Lower noise at high ISO 1,167 ISO vs 919 ISO
The D7000 has a slight edge (0.3 f-stops) in low noise, high ISO performance
If you are basing on A.net photos, i.e., aviation shots at ISO 100 shouldn't make a difference as you don't need the DR, or noise performance, you'd be right , but to say their sensors are similar would be a stretch imo.
[Edited 2013-06-12 21:00:22]
vikkyvik
RE: Nikon D300s
Thu Jun 13, 2013 4:30 am
I don't mean to be a dick, but in two threads now you haven't really provided much info as to what exactly is wrong with your current setup. People are asking so they can help you, not to give you crap about it. It may well be that you just need to practice, or adjust something about how you shoot, and then you can save yourself the hassle (and money!).
I'd suggest (again) that you post a couple shots to show what issue(s) you're trying to solve. There are plenty of free hosting sites around.
People here can be an invaluable resource if you supply them with enough details.
trvyyz
RE: Nikon D300s
Thu Jun 13, 2013 2:00 pm
Since, everybody is favoring the lens upgrade, they are absolutely right on that one.
I would like to give input why a body upgrade is needed, I could never stand the one dial and two step menu process of the entry level nikons, I had a D5100 along with my D7000.
On IQ level they are similar, but the handling and ease of use of D7000 is superior not to mention the lens motor, CLS and AF fine tune. I ended up selling off the D5100, I could not go to the menu at the display and keep changing stuff, where in the D7000 I can just push a button and use two dials. The LCD info panel on top is something I need and I hate how the D5100 display stays on all the time.
So, there are definite advantages for upgrading the body, the things for D7000 also applies to D300s as it is a more advanced body. If you have the money, the body upgrade would be good or else upgrade the lens as it will serve you a longer time and will retain more value.
Now coming to Vik's point, there is some issue with your photography style, since your complaints were not directly related to your body or lens, but your choice of settings because with similar setting you should get similar photos(although not L quality) to you friend's 60D or 7D unless they were using a faster aperture than the lens you have.
megatop412
RE: Nikon D300s
Fri Jun 14, 2013 3:37 pm
Quoting FLPhoto (Reply 9):
Stepped down to f/8, it is sharp enough to be a nice compromise between cost and IQ. The 70-200mm lenses are incredible, but you have to look at whether you're willing to pay that much more for incredible performance as opposed to Very Good. Plenty of folks have gotten images accepted here with that lens. I always thought I would 'move up' to a 70-200mm, but after 5+ years, I've found the more versatile focal range is much more useful.
megatop412
RE: Nikon D300s
Fri Jun 14, 2013 5:25 pm
Quoting trvyyz (Reply 13):
You are correct from a technical standpoint. From the stanpoint of a 13-year-old who is just starting out in this hobby(the perspective I think matters more in this case) those sensors are in fact close enough to be considered similar to one another. All those specs you listed, while accurate, translate into minute differences in the real world. More importantly, those differences are entirely too small to upgrade a body on and would cause him to miss the proverbial forest for the trees.
Sites like 'snapsort' and DxO obscure real world differences with their proclaimed scientific objectivity, which is why many people should take their numbers with a grain of salt instead of saying 'well the D7000 has an 80 in image quality while the D3100 has only a 67 in image quality, so it's a better camera.' What does that really mean? Who gave those grades? What qualifies them to give those grades? Are those 'qualifications' valid enough to lead people to base purchasing decisions on those assessments?
If you want to stand over his shoulder while comparing images between the two cameras on a large IPS monitor @ 100% and point out the subtle differences in shadow and highlight detail, only then will he(and many others) notice
trvyyz
RE: Nikon D300s
Fri Jun 14, 2013 6:17 pm
True that the op maynot see the difference, shooting at f8 , airplanes on a bright day at iso100.
The numbers 67 and 80 are the test results of DXO.
http://www.dxomark.com/index.php/Cam...Camera-Sensor-Database/Nikon/D7000
I am not sure who is more qualified, people over here or them.
Geezer
RE: Nikon D300s
Wed Jun 19, 2013 5:06 pm
One thing that no one has mentioned yet about the D-300s..........there are literally thousands of Nikon shooters waiting for Nikon to come out with a new D-400; the prices on the 300s are already way down from what they were when it first came out, and when the D-400 does come out, prices on the 300s will go even lower. I can tell you from owning one that the 300s is a superlative camera; I bought mine new just when the 7000 had been introduced, and actually got the thing for less than a 7000 would have cost. You just can't buy more camera for what you can pick one up for.
For the most detailed information possible about the 300s, you can get a copy of David Busch's great 300s manual for only about $10 U.S.D. (That guy knows more about Nikons than anyone I've ever seen yet.)
Stupidity: Doing the same thing over and over again and expecting a different result; Albert Einstein
clickhappy
RE: Nikon D300s
Wed Jun 19, 2013 6:04 pm
There is no such thing as a "D-400." There maybe in the future, but as of now it doesn't exist.
There will always be something new, just over the horizon. While you wait for the latest specs, true shooters are out taking pictures, with the tools they have.
D300 prices have fallen because it is a 5yo design. It is still a fabulous camera, and would be a great camera for 99% of the people reading this.
Nikon has labeled the D7100 their "flagship DX" camera, and I am enjoying the copy they have provided me, I just wish it felt as solid as my trusty D200's.
FLPhoto
RE: Nikon D300s
Thu Jun 20, 2013 4:02 am
Thanks for the replies. Because the D300s is an older camera, it is a low price because of the 7100. I need a new lense, but also a body. I have $1400. What should I do?
Geezer
RE: Nikon D300s
Thu Jun 20, 2013 10:12 am
Quoting FLPhoto (Reply 21):
What should I do?
No one can answer that question but you; It "all depends".......on a BUNCH of things. Here's the very best advice I can give you; You're 13 years old; from your posts, I would guess that you are already more knowledgeable about photography in general than about 99% of young fellows your age. Photography is a very technical subject; so are are modern digital cameras and lenses. Always remember one thing before you buy ANY digital SLR body; in a short time, there will be another camera that will come out "soon" that will have features that the one you just bought lacks. It's completely impossible for anyone to make a really good buying decision about which camera to buy, unless you have a thorough knowledge of many things; exactly what kind of pictures you want to be able to take, what kind of equipment you need to do that kind of work, what you intend to do with the pictures you take, and what your overall financial condition and income is likely to be in the near future. Only by taking all of these things into consideration can you make a really good buying decision.
The whole reason you are feeling frustration right now is because you lack the knowledge you need to make a really good choice about "what to do"; obviously, there are a lot of very knowledgeable people on this forum relative to photography, but then I'm guessing most of them didn't become that knowledgeable over night; the more you learn about the technical aspects of photography in general, the less you will need to depend on someone else's advice. I think the smartest thing you could possibley do right now, would be to read a lot, take a LOT of pictures with the equipment you already have, and concentrate on vastly increasing your skills; if you do that, and if your enthusiasm for photography continues, sometime in the near future you'll KNOW what new camera you need to buy to do what YOU want to do.
Right now, you are perilously close to falling into the age old "Canon or Nikon" trap; that's one decision I wouldn't want anyone to make for me ! They both are capable of taking great pictures, obviously. But there are reasons why some people prefer one, and why other people prefer the other. One of the hardest things for any camera manufacturer to do, is to year after year, keep improving their cameras while at the same time, keeping the newer cameras compatible with all of the pricey "gadgets" that people have accumulated for the cameras from that company that they have owned. Here's the best example I can think of to illustrate what I mean; not too awfull long ago, there were NO....I. digital cameras 2. autofocusing lenses 3. automatic diaphragms 4. automatic film advance ...........and a whole bunch of other things that people take for granted now; another thing......most of the light meters in most of the 35mm cameras left "much to be desired". About this point in time, I bought my first really good 35mm camera; a Canon F-1; the battery in the F-1 was about the size and shape as an aspirin tablet; and they lasted for a year or two; (no wonder, because all it did was furnish power for the light meter)
back then, almost everyone had a big hand held light meter. Canon had previously had a line of lenses, (which I don't recall right now the letter designation), but they came out with this really GREAT new line of lenses, with, IMO, the BEST lens mount on ANY 35 mm lens line, which they called "breach lock"; a VERY secure and positive locking mechanism; absolutely NO "play" or "slop"; the new line of lenses were designated as "FD" lenses; (I think the old ones were "FL" ?)
Remember, the FD lenses were "manual everything"....manual focus, manual aperture ring, and so on; camera bodies were entirely mechanical at the time. But the F-1 was Canon's "top" (and only) "pro" camera for quite some time; if you were a sports photographer, you bought a very expensive motor drive; if you needed LOTS of shots, fast, you bought a high dollar bulk film gadget (that held about 50 feet of film, and was motorized; depending on what you were doing, there were something like 5 or 6 different penta prisms, (each one doing something different), another expensive gadget to measure extremely low light levels (which were all called ASA back then) instead of "ISO"; Oh, I almost forgot......there were like 9 different focusing screens made for the F-1; ( I only has about 3 or 4 of them) ( at $50 per screen) You could spend 15K on gadgets for the F-1 and you were just getting started !
After a few years, Canon came out with another "pro" camera, the "new F-1" ! ( never did understand why not just call it "F-2"?) Needless to say, very few (if any) of the "gadjets" for the now "old F-1" worked with the "new F-1". Hey.....no probeblemo......I loved that camera! It took GREAT slides! It was a great camera; finally, and before the new F-1 had been around all that long, you started hearing about "digital cameras" that didn't use film ! ( I strongly suspect that Canon was working on all of this new digital stuff for the last 3 or 4 years of film, ( while people were still spending tons and tons of bucks on new FD lenses )
Then it finally happened; Canon says, "we're coming out with a new line of lenses, called "EOS"; and everyone asked, "but what are we gonna do with all of our great FD lenses "? Canon's answer to that was......." they make great paperweights, door-stops, or you can sell them at auctions, ( for a penny on the $ )
Let me back up a year or so; while all of this digital revolution was getting started, Nikon came out with it's next to last killer film body, the F-5; the F-5 made everything before it look like something from the Flintstones ! Also, the F-5 uses Nikon's F-mount lenses; (which they had been making "for years"; you can't describe the F-5 without writing a book; anyway, for a few years there, every pro that shooits for Nat Geo, Outdoor Photography, etc etc etc was shooting Velvia with an F-5; and finally Nikon came out with the F-100, then the F-6; (I think the F-6 people got the shaft though, because Nikon was just starting to come out with digital bodies; and guess what ? Even though Nikon DID start designing all of their lenses to optimize with digital, you can STILL use every f-mount lens from the last "years and years" on your new D-whatever body !
To prove that point, I have two bird pictures on my Flickr page, both shot with the same 300 mm manual focus, f4 Nikkor lens, which was about 20 yrs old when I snagged it on eBay for about $125, about 10m years ago; I also used a Nikon 2X TC bringing the focal length up to 600mm, and with the 1.5X crop factor of my D 300s, bothe bird pictures were taken at an effective FL of 900mm, on my Gitzo 340 with Arca Swiss ball head. (VERY stable support)
While the Nikon F-5 was still the "go to" film body, I got a free 3 month trip to Oahu, and while I was there I had a new F-5 and six new lenses for it, (including a brand new 600 mm /f4 and a whole bunch of other "goodies" at my disposal to play with for the summer); I guarantee you, if you ever get a chance to go to a world class botanical gardens (like Foster Gardens in Honolulu), and you have a F-5 Nikon and a F-1 Canon both in your bag, you probably just oughta leave the F-1 at the Hotel Ilikai ! After returning from Hawaii, I bought my own F-5, and it's all I used for the next 3 or so years. Finally, I got kinda burnt out on photography, (mostly due to buying film) when you start shooting Fuji Velvia and you do very much 8 fps stuff, you can go seriously broke, just buying film, then you STILL have to pay to have it processed.
After a few years, I was down to only shooting a very few rolls of film every now and then; Canon and Nikon had both come out with a bunch of digital bodies before I even started thinking about getting into digital; when I finally did decide to give it a try, just like the OP, I had no idea what camera to buy; so I bought a $189 Fuji mega zoom (at WalMart), and started reading about digital photography and started using the Fuji to make up my mind if I wanted to bother buying a D SLR.
How good do pictures really need to be ? That depends entirely on a whole bunch of things; who's going to be seeing them? Are you going to print them ! Or just stick them in Flickr for "the world" to look at; in other words, pictures just need to be "good enough"; everyone has their own criteria about what THEY consider "good enough". Before I even half way got that little Fuji camera figured out, I had an opportunity to attend the open house of a brand new airport that was still being worked on, on opening day; the airport has a 10,000 ft runway, and on opening day, no airplane had ever been on it, much less make a landing or a take off; the pilot flying the B 737 that made the very first landing on that brand new runway had gone to high school in that town; so it was a "big event", the Governor was there, and a LOT of people; because of someone I know quite well, I got to take my pictures of the first plane ever to land on the new runway from a super vantage point; standing in the shade directly underneath the jetbridge; (which was great, because it was hotter than hell that day !) I managed to get some pretty decent pictures, when the 737 touched down (and went through a bunch of loose mud that construction vehicles had left on the brand new concrete). Are the pictures "good enough" ? I'll put it this way; they look pretty good for a $189 camera from WalMart; later, after I had made some 18 X 24 prints of them, and created some custom graphics of my own design and matted and framed them, there are a number of them hanging on some walls where very few people ever get their pictures displayed; so in this case, I guess they are "good enough"; (they were also good enough to get me interested enough to finally buy my D-300s, which I sure wish I'd had to take that picture of the first plane to land on a brand new 10,000 runway. ) If I ever get around to transferring all of my files from my old iMac that died, to my new iMac, I may put them on my Flickr page for everyone to look at so they can tell me if they're good enough.
I have no idea what you like to take pictures of; Myself, I do little bit of everything; here's one more example of "good enough"; my best friend decided to start a sign business; he had to buy some pretty "pricey" equipment that most people who are just "enthusiasts" never get to play with. About 2 years ago, way before I bought my D 300s, a local business had this all wooden billboard on a busy state highway near where I live in Indiana; the original billboard was a hand painted picture of a local covered bridge, and each side was painted on four sheets of 4ft X 8ft plywood; the framework of the bill board was still in good condition, but the ply wood with the picture ( each sided is 8ft high X 16ft wide ) was in bad shape; so we ripped all the old plywood off and disposed of it; I then took a picture of the real covered bridge that was painted on the bill board, with the same little $189 Fuji camera; at first, my friend had planned to print the photo on 8 sheets of 4ft X 8ft alumalite, (which is a sandwich of two .30 sheets of aluminum bonded to a 3/16" core of corregated plastic. My friends 48" commercial ink jet printer only prints on roll stock, so to do an alumalite sign, you print the picture and graphics on paper-backed vinyl film, then you apply the film to the new, bare aluminum; vinyl printed signs have an average life-span of maybe 3 or 4 years; plus, doing a 4 panel sign takes a LOT of "matching pictures up"; after thinking about it for a day or two, he decided to have a big commercial printing plant in Indianapolis do the print job; a bunch of advantages going this route; first, because they have huge flatbed printers, they print directly on the alumalite, which give a longer life span; secondly, they have a huge shop, with every thing needed, and if they make a mistake, they just do it over and it costs you nothing for the wasted material; alumalite is almost $200 a 4'x8' panel, vinyl isn't cheap, and ink tanks for my friends printer are about $125 apiece, X five. We made all the arrangements with the print shop on the phone, then sent them an email with a file attached from my little Fuji, and three days later drove up to Indianapolis and picked up all 8 printed panels, all crated up and wrapped up; It took us less than 6 hours to place all the panels on the billboard frame, shoot stainless steel screws through the
panels into the framing, did a little touch up painting on the framing and the screw heads, and ended up with a tidy $3,500 net after paying the $1800 printing bill. I you don't think you can blow a file from a dinky little $189 camera up to 8' ft X 16', I'm going to be putting a shot taken with my D SLR on my Flickr page so everyone can see it for themselves.
Is it "sharp" ? Obviously, if you view it from 3 feet away, it's not that sharp; but it's a highway billboard.......people see it from the road as they drive by; to them, it's nice and sharp; so again, that picture, for what it's used for, is "sharp enough";
(plus the customer who paid the bill is delighted with it.)
I hope all of this will give you a few ideas.
megatop412
RE: Nikon D300s
Thu Jun 20, 2013 5:19 pm
With my head now spinning I'll ignore the confusion introduced by the previous post by saying this: the OP still has not answered the question of what is it about his current gear that is failing him. And I'd be willing to bet that if it is, it is because of user error, not the body or the lens. You need to practice with what you have, a lot, just like the rest of us did. If you feel your work requires more than what you have, I invite you to post some shots that we can see. I have a feeling that, at age 13, you have not yet developed a level of competence that would make the most use out of semi-professional equipment.
Want my advice? Put the $1400 into a college fund. There's nothing wrong with the D3100 and the 55-200mm setup. If you absolutely MUST get something oe need more reach, get the 70-300mmVR and put the rest towards college. Notice my emphasis on saving for college.
FLPhoto
RE: Nikon D300s
Thu Jun 20, 2013 10:32 pm
Geezer, WOW!!! That's the longest post I've seen on the forums. Now on to your point Megatop. there is a blue haze on almost all of the pictures, and they are commonly out of focus. The minimum focus distance on the 55-200 and 18-55 is not at all good, and on the 35mm it is good at a f/1.8, but the focal length is too small. You are probably thinking "why is this kid talking about macro on an aviation forum"? Well I also like to shoot landscape and macro. So, on that note, here is what I am looking for. 1) A good camera that is past the consumer range. It does not need to get prints larger than 24 by 36, which is also a stretch. 2) I can't be too old. The D90 is a nice price, but it is discontinued. Yes, I know that cheap and pro rarely go together, and this is why I think the D300s would be good for me. At 12.3 megapixels, it is plenty large enough, and also is the same price as the D7100. Honestly, I have only held the D7100. I have never held the D300s, but I bet it feels more solid than the D7100. I have seen that many pros use a D300sfor a backup body, and I am worried that the fellas at Nikon are making every new DX camera "soccer mom friendly". I have only held the D7100 once at Costco, and it felt very dense with the attached 18-200mm. It is heavy, but in a good way. The D300s is larger, but I am not really that worried about it, because I usually shoot close to a car for not that long. I will also get the Lowepro 10L bag, and just use my Lowepro 20AW for hiking. Back to the camera, I really don't need it to be weather sealed, but it would be nice. I would like to keep my D3100, to use for Camping with my Boy Scout troop.
So, with all of this said, what would you say the camera for me is?
FLPhoto
FLPhoto
RE: Nikon D300s
Thu Jun 20, 2013 10:42 pm
One more thing- This is my "fun" money, and I have college money set aside elsewhere.
FLPhoto
vikkyvik
RE: Nikon D300s
Thu Jun 20, 2013 11:38 pm
Quoting FLPhoto (Reply 24):
Unless you post examples, it's rather difficult to diagnose these issues. Blue haze could be white balance, could be weather conditions (frequently happens in landscape shots over a significant distance), could be lighting, etc. Out of focus could be lens softness, could be calibration between lens and body, could be the wrong focus points are locking on, could be slight blur, etc.
I finally got around to looking at what I assume are some of your photos on Facebook, and I'm honestly not seeing the issue. Shots through glass and/or heat haze are going to look soft, and possibly be washed out or have color casts (for glass). Shots of backlit airplanes are going to look.....backlit, often with overexposed parts for the bits that are in sunlight. Upgrading equipment isn't going to change that.
Originally (in your first thread), you said your shots were overexposed and noisy at high ISO. Now it's out-of-focus and blue cast.
Not sure what the problem there is. My previous camera (Canon Rebel XS) is about as "soccer-mom-friendly" as they get, and I got shots out of it that I doubt 95% of soccer moms were getting (and in the hands of a better photographer, it could have produced shots well beyond my skills as well). You might be surprised by what a "soccer-mom-friendly" camera can do in the right hands. My camera body upgrade was drive more by features than image quality.
FLPhoto
RE: Nikon D300s
Fri Jun 21, 2013 12:08 am
Vikkyvik,
I have posted pictures but they are awaiting screening. Yes, I have a lot of problems. Noise, blurry ness, overexposed, many things. I feel like my camera now does not have the features I would like. So this is why I need and upgrade.
henkita217
RE: Nikon D300s
Fri Jun 21, 2013 12:24 am
I think we are all waiting for you to post some examples, so we can see and help you to advise on which areas are not working out for you, whether it be from human error or the camera itself.
Use the following code, it's easy especially as you say above, you have a photo currently in the queue;
[IMG]COPY AND PASTE THE WEB LINK HERE[/IMG]
HB
FLPhoto
RE: Nikon D300s
Fri Jun 21, 2013 1:01 am
The link did not work.... Can you resend the link or is there another way?
FLPhoto
Geezer
RE: Nikon D300s
Fri Jun 21, 2013 9:48 pm
FLPhoto;
If you're wondering what photos taken with a D 300 look like, take a good long look at Sam Chui's pics on the forum; I think every picture Sam put on here until he finally bought a D 800 was made with his trusty "old" D 300; you can also take a look at some of Agustin Anaya's fabulous F-22 Raptor shots.........all made with his D 300.
The D 7000 is a great camera, no doubt about it; in fact, you can now buy a new one for exactly half what they originally sold for; The D 7100 is even better, and has a LOT more resolution......but you will be paying FULL price on it for several more years yet; if you really are determined to get a very well built, high end body, (at a fraction of what they went for in the beginning), you probably can't do any better than the 300s.
FLPhoto
RE: Nikon D300s
Fri Jun 21, 2013 10:15 pm
Geezer-
After doing some more research, the decision was a refurbished D300s or D7100. Since I am not a pro, I can't replace my bodies every other year and buy many lenses. I will most likely wait, and then sell my current setup for a D7100 and an all in one zoom. Are all in one zooms a bad choice?
FLPhoto
ckw
RE: Nikon D300s
Fri Jun 21, 2013 11:30 pm
Quoting FLPhoto (Reply 31):
In the short term, maybe not. In the long term yes. "All in one" will always be a compromise, and the longer the coverage, the greater the compromise. Specialist (ie telephoto or wide) zooms will be better and primes better still.
When I was young and short of cash, I bought lenses which seemed to promise much at a low price. As my skills and appreciation improved, I quickly realized their shortcomings and bought decent lenses. Money spent on the quick fix lenses was wasted.
My suggestion is always buy the best glass you can - it will last forever. If this means you are limited in what you can shoot, so be it. In fact this is not necessarily a bad thing - it will probably make you a better, more creative photographer. If all you have is a 50mm prime, you will work harder to find shots that work with that lens. In the long term, these shots will have more value than a bunch of mediocre quality "me too" shots taken with a budget "all in one" zoom.
At this point you need to decide whether you want to be a "photographer" or a spotter who takes pictures as a record of what they've seen. Both are completely valid uses of a camera, but the answer to that question will determine what your best lens choices will be.
Colin
Colin K. Work, Pixstel
FLPhoto
RE: Nikon D300s
Fri Jun 21, 2013 11:44 pm
Ckw-
I love primes. I only have one, the Nikon 35mm f/1.8. I really like it because I feel that it makes me be more creative, rather than just standing there and zooming in. The dream setup would be a 10.5mm fisheye, a 24-70 f/2.8, 200mm f/2. Also a 400mm would be nice. Well now it's time to stop dreaming and be realistic. My setup now definantly needs to be improved, and I have my eye on a few lenses. I do like the 85mm f/3.5 macro, and the 50mm f/1.8. I already have a 35mm, so a 50mm is not that necessary. This is not the greatest setup for aviation, and I need some help. What do you recommend?
FLPhoto
vikkyvik
RE: Nikon D300s
Sat Jun 22, 2013 12:39 am
Quoting FLPhoto (Reply 29):
Go to Photos --> Photographer's Corner --> My Upload Queue Photos
Then click on the large version of an image. Copy the URL, and paste it in your post like this (without the quotes):
"[img]paste your photo's url here[/img]"
Alternatively, just paste the link here, and we can open the image ourselves.
FLPhoto
RE: Nikon D300s
Sat Jun 22, 2013 2:37 am
Ok thanks. Didn't quite understand what you meant the first time... anyway the pictures I submitted were some of my best.
http://www.airliners.net/addphotos/b...ady/z1370991847.8805dsc_0915_8.jpg
http://www.airliners.net/addphotos/b...dy/y1370993808.6018dsc_0583_10.jpg
vikkyvik
RE: Nikon D300s
Sat Jun 22, 2013 5:08 am
Quoting FLPhoto (Reply 35):
OK, now we're talking and can offer some advice. First, both photos will be rejected. Don't be disheartened by that, it happens to a lot of first-time contributors, myself included. It takes awhile to understand what the site is looking for, and how to shoot/edit to meet that criteria, should you wish to.
Your first obstacle with the photos you submitted is that they're both heavily compressed, which is an immediate no-go. The first is flat and off-level as well. The second is also flat, a bit high in frame, and would suffer a motive rejection for the clipped tail. Looks like it might be affected by heat haze as well, but it's sort of tough to tell with the compression.
If I were you, I'd start out submitting at 1024 pixels, instead of 1500. It can be pretty difficult to get 1500 pixel images accepted, even after you have a bit of experience. Look through the database, and try to get a feel for how the photos look that are accepted. There's also an Editing Tutorial that covers the basics of editing for here. Lastly, make use of the Photo Feedback forum, so you can get feedback without having to wait for photos to be screened.
FLPhoto
RE: Nikon D300s
Sat Jun 22, 2013 5:28 am
Vikkyvik- Thanks for the feedback. I assumed they would be rejected, but I just thought that they were better than some of the pictures I have seen on here. Well I will keep on working at it and use the Feedback Forum. I almost always shoot at around 12mp, and had to reduce the size greatly. What exactly do you mean by "flat"? Is there any way I can avoid the heat haze?
Thanks for the help,
FLPhoto
FLPhoto
RE: Nikon D300s
Sat Jun 22, 2013 5:46 am
Hey Vikkyvik-
One other thing, do you think that there is a chance that these could be accepted? I posted them on MyAviation.net, but I was sure these wouldn't get accepted.
http://www.myaviation.net/search/photo_search.php?id=02331267
http://www.myaviation.net/search/photo_search.php?id=02331268
vikkyvik
RE: Nikon D300s
Sat Jun 22, 2013 6:08 am
Quoting FLPhoto (Reply 37):
As you should. A.net doesn't accept photos over 1600 pixels in the long dimension, or over 1 megabyte in size. But when you're resizing, you have to make sure you're saving at the highest quality possible.
Flat means low contrast.
You can minimize its effects by getting as close as possible to the subject, and shooting on days when heat haze isn't prevalent. Resizing to a smaller size can also help hide some heat haze, provided it isn't too bad in the first place.
Quoting FLPhoto (Reply 38):
Not as they currently stand, no.
FLPhoto
RE: Nikon D300s
Sat Jun 22, 2013 3:57 pm
Vikkyvik- thanks for all of your help. Currently, I am in Portland for a basketball tournament, and visited PDX yesterday. I did get a great spot but they probably won't get accepted. That being said, I will either head back to PDX, or go to a smaller GA airport. What would you suggest I do today to get my first photos accepted? Also, what would help me get my photos on here gear wise?
Thanks so much for all of your help,
FLPhoto
megatop412
RE: Nikon D300s
Sat Jun 22, 2013 4:07 pm
OK, now that we can see some photos your issues have context. I'm glad you have a screener responding to you, that will only help you.
Notice how his feedback has to do with your processing skills, as well as your choices involving composition and time of day. These are not correctible through gear upgrades, they are workflow and shot discipline adjustments you should make. Colin makes excellent points about glass selection, but I do not believe any of the shots you have provided links to would have turned out any better had you used any of the dream lenses you listed. If your main goal is to get shots accepted here, do the workflow changes first. However, you seem to be leaning towards investing in photography for the long term, so that may justify the expensive glass in the long run.
I don't upload here, so from a non-acceptance criteria perspective, your shots don't require too much editing in my mind. I like the one with the prop and the selective focus.
FLPhoto
RE: Nikon D300s
Sat Jun 22, 2013 4:18 pm
Megatop-
Thanks for your help. Actually, the one with the prop was the one I was sure wouldn't get accepted. Where do you post instead?
FLPhoto
FLPhoto
RE: Nikon D300s
Sat Jun 22, 2013 9:28 pm
Any advice for types of shots that will usually get accpted?
vikkyvik
RE: Nikon D300s
Sat Jun 22, 2013 10:12 pm
Quoting FLPhoto (Reply 40):
Practice shooting and editing. And all the stuff I already said:
Quoting vikkyvik (Reply 36):
I'm not sure why you're so reluctant to hear this, but as many have said, your gear is likely perfectly fine.
Quoting FLPhoto (Reply 43):
Again, see here:
FLPhoto
RE: Nikon D300s
Sat Jun 22, 2013 10:34 pm
I am at PDX right now and just wondered if there was a "money shot". I suppose Ilthe upgrade will have to wait.
megatop412
RE: Nikon D300s
Sun Jun 23, 2013 3:10 am
Quoting FLPhoto (Reply 42):
Megatop-
I have a dropshots page that I use as a cloud archive, and I also have a flickr pro account which is for my best work. Geting shots accepted here didn't work out for me, maybe it'll work for you. If you want to try, you need to trust what vikkyvik is saying and re-read his last reply over and over until you are doing those things.
FLPhoto
RE: Nikon D300s
Sun Jun 23, 2013 3:24 am
Megatop- what gear do you use?
Vikkyvik- I found a great deal on a Canon EOS 50D. I could get the body, grip, and a few lenses for probably about $1000. Do you like the 50D? Is it worth it?
FLPhoto
vikkyvik
RE: Nikon D300s
Sun Jun 23, 2013 4:05 am
Quoting FLPhoto (Reply 47):
Yes.
Is it worth it?
See here:
Quoting vikkyvik (Reply 44):
ckw
RE: Nikon D300s
Sun Jun 23, 2013 8:14 am
Quoting FLPhoto (Reply 33):
Afraid I can't help with Nikon lenses - but if you do switch to Canon ... let me know your available budget for lenses.
Colin
