FLPhoto
70-200mm Lenses
Fri Jun 14, 2013 2:08 am
Hi Guys and Girls,
What would the best 70-200mm lens be for aviation photography? The Tamron 70-200 f2.8, the Sigma 70-200 f2.8, or the Nikon 70-200 f4? I was also looking at the Nikon 70-300mm, what's that like?
FLPhoto
Canon 7D, 70-200mm f4 L, 10-18mm f3.5-4.5
FLPhoto
RE: 70-200mm Lenses
Sun Jun 16, 2013 10:26 pm
Nobody has any opinions?
southwest9
RE: 70-200mm Lenses
Mon Jun 17, 2013 2:50 am
Yes, I have the Tamron 70-200 2.8, and it gets the job done. I have a 7D, which has a crop sensor, so it's like actually 98-280mm and that really comes in handy for getting close shots when they are all the way down the runway on the opposite side. The focus can be spotty in dark light, and occasionally I will get one or two that are totally out of focus from a 10 shot burst. You can't beat that price for the quality. I like it and I don't have the money for a $2,500 lens.
afterburner
RE: 70-200mm Lenses
Mon Jun 17, 2013 5:57 am
Quoting southwest9 (Reply 2):
Canon crop sensor DSLR's are actually have crop factor of 1.6. So a 70-200mm lens on Canon 7D produces similar images to a full frame (35mm format) camera with 112-320mm lens.
eadster
RE: 70-200mm Lenses
Mon Jun 17, 2013 8:32 am
70-200mm is good for a lot of things! I personally don't like Tamron stuff, but that's me. Sigma is ok, but if you have Nikon, the the Nikon glass.
FLPhoto
RE: 70-200mm Lenses
Tue Jun 18, 2013 2:26 am
Hey,
Southwest9, you said you have the 7D. I was thinking of making the switch from Nikon to Canon, and getting the 60D or 7D. What do you think?
FLPhoto
eadster
RE: 70-200mm Lenses
Tue Jun 18, 2013 10:23 am
For what its worth, I wouldn't go with the 7D and wait and see if the rumours/specs of the 7D mk II are real. The 7D is not the best - its a bit too grainy....
I have one, and its good, but the image quality could be better....
FLPhoto
RE: 70-200mm Lenses
Wed Jun 19, 2013 3:00 am
Thanks for the info. I will check up on this. I might just get the 60D and 70-200 f/4. What do you recommend for a wide angle or standard zoom?
dazbo5
RE: 70-200mm Lenses
Wed Jun 19, 2013 6:02 am
Quoting FLPhoto (Reply 7):
It depends on budget and focal lengths, but the 24-105 F/4 L is pretty good although not all that wide on a crop body. For wide angle, the Sigma 10-20 is excellent as is Canon's 10-22. If that's a bit too wide, Canon's 17-40 L is excellent.
Darren
southwest9
RE: 70-200mm Lenses
Thu Jun 20, 2013 1:22 am
Although this matter is certainly debatable, I personally would go with the 7D instead of the 60D. The buttons on the 60D don't really feel like they have been pressed when you try to. It's almost like you might find yourself pressing a button twice more often than not. And, a big deal breaker for me was the fact that the 60D only shoots 5.3 frames per second, continuous, where as the 7D shoots 8 frames per second, continuous. Also regarding the "7D being too grainy" it depends the situation you are shooting in. Of course no camera is not going to be perfect with noise, especially at night, but personally, during the day time, I enjoy using it. Post-processing can usually smooth over some of that grain that might appear in darker photos. Try to read / watch some reviews because there are plenty out there. Enjoy which ever one you choose.
FLPhoto
RE: 70-200mm Lenses
Thu Jun 20, 2013 3:52 am
Yea, I could just stay with Nikon. I heard that the only good Canon glass is the L series. I am only 13, so the budget is under $1400.
vikkyvik
RE: 70-200mm Lenses
Thu Jun 20, 2013 4:19 am
Quoting FLPhoto (Reply 10):
The L-glass is generally the best, but certainly not the only good glass.
Learn how to use your current equipment to the best of your (and its) ability, and save the $1400 for college.
ckw
RE: 70-200mm Lenses
Thu Jun 20, 2013 8:36 am
A common belief. But not necessarily true. Note that the "L" simply denotes "luxury" and can refer not just to the glass but also the build, finish and whether or not accessories (eg. lens hoods) are included. It is true that Canon's best lenses (esp. their big telephotos) all tend to be L, but at the shorter end there is some very good non-L glass. I use the 50 1.8 and the 1.8 85mm along side my L glass and have no complaints.
Of course you have to compare like with like - ALL lenses are a compromise in designing out various optical issues. You pay your money and take your choice. All else being equal, a 70-200 should out perform a 70-300 simply because it's an easier lens to build. But some may be willing to sacrifice ultimate quality for greater range.
And remember, the majority of photographers - esp. pros - are not shooting for super critical sites such as A.net. For a photo-journalist, for example, getting the shot is more important than perfect quality. Some people are surprised when they find that their super fast (and very expensive) f1.4 and f1.2 lenses aren't pin sharp edge to edge - that's because in most low light shooting (think concerts or theatre) edge sharpness is not so vital, so this is compromised in favour of speed.
3rd party options can be good - Sigma, Tamron, Tokina have all produced great lenses - I have a Tokina 100mm macro as sharp as any of my Canons - BUT, you have to keep in mind that Canon does not provide mount or AF details to 3rd party manufacturers. In effect these lenses are reverse engineered - the most common result is that 3rd party lenses never seem to focus quite as quickly or as well in extreme situations as their Canon equivalents.
Finally, if you are on a budget, look at 2nd hand lenses - if it hasn't been damaged, there is no reason a used lens won't work as well as a new one. Buy from a reputable dealer and you'll get a 6 month warranty should you later find that the lens is defective in some way.
Colin
Colin K. Work, Pixstel
FLPhoto
RE: 70-200mm Lenses
Thu Jun 20, 2013 10:39 pm
Ckw,
Thanks for the help. I am a proud Nikon user, and could switch to Canon if I am persuaded enough. Currently, the plan for the next year is to stay with Nikon and Get the D300s. I will then upgrade lenses sometime later.
FLPhoto
ckw
RE: 70-200mm Lenses
Fri Jun 21, 2013 12:09 am
Quoting FLPhoto (Reply 13):
Very sensible - I don't think switching brands is a generally a good idea, unless there is some feature you absolutely must have that's not available in your brand. I firmly believe there is a lot to be gained by becoming very familiar with a particular range - learn the strengths and weaknesses and you're more likely to get the best out your equipment.
Colin
FLPhoto
RE: 70-200mm Lenses
Fri Jun 21, 2013 1:06 am
Hey thanks. I will stick to my camera now and then upgrade to the D7100 or D300s later.
FLPhoto
