cjmoeser
General Tips
Tue Jun 25, 2013 4:44 pm
Hi all,
I am new to Airliners.net and I've been spotting at Boise Air Termanial/Gowen Feild (KBOI) for about a year now. I have some pretty decent spots, and it is diverse with the type of aircraft that flies in and out. When I go out there, there are always Alaska/Horizon Q400's landing and taking off, but I can never get the props spinning in the picture. I have a Pentax K-30, and use a 50-200MM lense. I would appreciate any tips on how to get better photos! And is there a better way to capture heat haze coming off the engines during take-off or landing?
Thanks a ton!
dazbo5
RE: General Tips
Tue Jun 25, 2013 8:05 pm
Quoting CJMoeser (Thread starter):
How much do you know about the exposure triangle? The trick to prop blur is using a slow shutter speed. Is something like this what you're trying to achieve?
Photo © Darren Wilson
You'll need to use a slow shutter speed, say 1/100th and pan the camera to match the speed of the aircraft to avoid motion blur. It's a technique that takes some practice, you'll not master it over night.
You can only capture what is present. Winter months is better for capturing that when it's more apparent.
Darren
clickhappy
RE: General Tips
Tue Jun 25, 2013 9:51 pm
If it is bright sunshine you will need to either stop the lens down, or use a neutral density filter.
The results are worth the effort
Photo © Royal S King
cjmoeser
RE: General Tips
Tue Jun 25, 2013 10:17 pm
Thanks for the replies, and Yes, that is what I am trying to achieve. I'll try it next time I'll go down there! Another question I have is how would I make the photo pop and have a lot of color in it like photos on here have? Do you use photoshop or is it a setting with the Camera?
Thanks a ton for the help so far!
dazbo5
RE: General Tips
Tue Jun 25, 2013 10:30 pm
Quoting CJMoeser (Reply 3):
It's all in the lighting. If you don't have the light, no matter what you do, you'll not get the results you're looking for. Always try and have the sun (light) behind you so it illuminates the subject properly. Avoid shooting towards the light (back lighting). This will result in the subject being dark or the background being blown out. It's all in the planning of a shot. Choose your location to give you the best lighting possible. This may change throughout the day.
Don't rely on Photoshop to save the day, get it right in camera as far as possible.
Darren
cjmoeser
RE: General Tips
Wed Jun 26, 2013 4:44 am
Ok Next time I go out to BOI, I'll try that! My friend is going to let me use one of his filters, so hopefully that will make a difference! Thanks so much!!
angad84
RE: General Tips
Fri Jun 28, 2013 10:58 am
PSA: stopping down makes dust/dirt on the sensor very apparent in your images, while shooting wide open all but eliminates their effect. Just something to keep in mind.
When I'm shooting for blur, the first thing I adjust is ISO. If I have my polarizer with me, I put that on next (it helps lose about 1.3 stops) and then only if I need it do I start stopping down.
Of course, it helps to have a lens that can produce sharp images when used wide open - I usually go out with a 70-200 f/4L IS.
As for heat haze, being close to the aircraft helps, because the further you are, the more the haze seems to "blend" with the background. The only time this isn't true is when shooting fighters and such, where they make so much heat that it almost always stands out, no matter what.
Users browsing this forum: Miguel1982 and 1 guest
