jetblue01
What Type Camera?
Tue Jun 25, 2013 6:47 pm
i have a cannon sx160IS .. it takes ok pictures but sometimes they come out blurry and they dont come in as clear when you zoom in. It has 16X zoom , what type camera is better.
FLPhoto
RE: What Type Camera?
Tue Jun 25, 2013 10:42 pm
What type of cameras were you comparing?
Canon 7D, 70-200mm f4 L, 10-18mm f3.5-4.5
jetblue01
Wed Jun 26, 2013 10:32 pm
i was wondering , what type camrea would shoot further and have a better image?
southwest9
Wed Jun 26, 2013 10:39 pm
Buy a DSLR camera instead of one with a fixed lens usually means that image quality will be better. They can be tricky at first and maybe even a little scary, but a Canon or Nikon DSLR camera is the way to go.
vikkyvik
Wed Jun 26, 2013 11:54 pm
Quoting jetblue01 (Reply 2):
A larger zoom and higher quality don't necessarily go hand-in-hand. There's a reason prime lenses are typically the best - they only have to work at one focal length. The larger the zoom range, the more compromises you'll have to make in image quality.
To which equipment you upgrade depends entirely on your photography goals.
Nicker
Fri Jun 28, 2013 8:27 am
I have the same problems with my cannon sx160IS, im thinking of buying a DSLR.
jetblue01
Sat Jul 06, 2013 4:21 am
how much is a DSLR and where can you get one??
southwest9
Sat Jul 06, 2013 4:42 am
Quoting jetblue01 (Reply 6):
how much is a DSLR
The price depends on how good the camera is.
Well you can start here...
http://www.usa.canon.com/cusa/consumer/products/cameras/slr_cameras
or
http://www.nikonusa.com/en/Nikon-Pro...cts/Digital-SLR-Cameras/index.page
trvyyz
Sat Jul 06, 2013 12:34 pm
Quoting jetblue01 (Thread starter):
What shutter speed were you using? It may not be camera's fault. You can get non blurry shots if you set it right.
YYZSpotter1991
Fri Jul 19, 2013 2:21 pm
Last I checked the Nikon D7000 SLR cost roughly CAD $1,000 if I remember correctly.
Toronto-based flyer since 1997
