cjmoeser
Softness In Photos
Sat Jul 13, 2013 3:38 pm
Hi,
My photos are being rejected because they are too soft, and I understand how to fix it, but when does the sharpness look right so it's not too sharp, and also to soft?
dazbo5
RE: Softness In Photos
Sat Jul 13, 2013 4:35 pm
Quoting CJMoeser (Thread starter):
Are you trying to fix something that isn't fixable though? How soft is soft? It's difficult to comment without seeing examples. You get a feel of what is required for sharpness on this site, which is probably sharper than you would normally want your photos, but that's the way this site wants them. For uploading here, photos need to be sharp enough that all the details are visible without being looking soft or jaggied. The best way is to compare photos you've taken with ones already added to the database so you can compare them and get a feel for what is required.
Darren
derekf
Sat Jul 13, 2013 5:55 pm
Airliners.net likes photos to be over sharpened and it is the one thing that most of us have struggled with as it is very subjective and dependent on your monitor. As screeners apparently all have different monitors there is bound to be some inconsistency.
Whatever.......
southwest9
Sat Jul 13, 2013 8:06 pm
Quoting derekf (Reply 2):
Nope, you could not be more wrong, if the screeners wanted "over sharpened' images why would they put this in the rejection guide?
"Over-sharpened
Your photo(s) were sharpened too much.
In most cases this problem is due to over-sharpening of the photo during post-processing in image editing software. Try sharpening the picture less aggressively to get rid of the jagged edges. These jagged edges are usually very visible on titles, cheatlines, registrations, or other straight lines. Selective use of masks to avoid excessive sharpening or areas where jagged lines may occur is a difficult but very effective method to avoid jagged edges. A good Airliners.Net image should be sharpened to just before the point where the titles and edges of the aircraft start to turn jagged.
This rejection can also occur when an image is well sharpened overall but one or more parts of the image showed jagged lines. This problem is generally most evident on solid lines such as wing leading edges, particularly if several lines are close together, such as gaps between the wing and flaps, cheat lines spaced closely together, or the aircraft titles and registration."
As you can see, the specifically state that over-sharpening is a totally valid reason for rejection.
Considering you didn't know this, you probably didn't know that a rejection guide existed so here you go (take a few minutes to look at before you make false statements)
http://www.airliners.net/faq/rejection_reasons.php
Also, if you read the rejection guide, it is not subjective at all, allow me to re-quote a section of the guide,
"A good Airliners.Net image should be sharpened to just before the point where the titles and edges of the aircraft start to turn jagged."
So, if you are sharpening however much you feel like and not following the acceptance criteria, of course your pictures will be rejected.
derekf
Sat Jul 13, 2013 9:04 pm
Oh good. Another anonymous expert. How many photos do you have on airliners.net and how long have been uploading here?
A simple question.
Whatever.......
southwest9
Sat Jul 13, 2013 9:46 pm
Quoting derekf (Reply 4):
A simple question.
I'm not trying to start an argument with you, but I will answer your questions:
I was quoting the guide that was posted, not claiming to be an expert.
But, just because you have pictures uploaded, does not make you a screener, so, saying what screeners look for, is only for screeners to say. Again, I am simply quoting what the screnners look for via their rejection guide.
Being bitter does not make you correct, sir.
I have zero photos uploaded here, regardless, you are wrong.
derekf
Sat Jul 13, 2013 10:34 pm
What I suggest you do southwest9 is go away and read through some of the rejection reasons and some of the screener comments. It is generally accepted that airliners.net requires images to be sharpened more than might be thought normal.
Also , when you have at least ONE photo on here then I might listen to what you have to say. Until then I suggest that you don't accuse experienced photographers of not understanding the rejection reasons.
Whatever.......
dazbo5
Sat Jul 13, 2013 10:44 pm
Quoting southwest9 (Reply 3):
I think you are missing Derek's point. The site is well known for wanting sharp photos, refer to my post above.
Derek is more than aware of the acceptance criteria and rejection guide.
Unless you've missed all the topics on the forum relating to the acceptance criteria and quality standards required for here, you'll find it very much is, to a degree. There is no black or white with sharpening, it's a subtle shade of grey in between requiring judgement.
With nearly 6,000 photo in the database and an acceptance ration >90% (not just a handful), I'm well aware of the requirements thank you.
Quoting southwest9 (Reply 5):
We all have an opinion, rightly or wrongly based upon our experiences here. Screeners aren't always right!
Darren
[Edited 2013-07-13 16:45:55]
ckw
Sat Jul 13, 2013 11:54 pm
IMHO, both Derek and SouthWest are correct.
Yes, there are rules which clearly explain what is "sharp", and yes I think this criteria results in oversharpened images by most non anet standards.
The problem is there is no one "correct" level of sharpness - depends on how the image is going to be viewed, nature of the subject and personal preference.
The Anet view seems to be, essentially, make it as sharp as you can without creating jaggies. This does have the advantage of providing a criteria by which images can be objectively assessed, and I guess that is important on a site where screening criteria are such an important and contentious issue.
But it does, to my eye, result in pictures which can look a bit unnatural or aggressive.
However as a simple answer to the OP's question - sharpen to the point where jaggies appear, then back off a bit and you won't be far off A.net requirements. Of course there are more subtle and complex variations to that answer!
Colin
Colin K. Work, Pixstel
EGCC777LR
Sun Jul 14, 2013 6:13 am
Hi Coln, post some examples here
http://www.airliners.net/aviation-forums/photography_feedback/
There are many guys both in the crew and not who are great at helping you understand the criteria here and using your own shots in the above forum is the best way to learn, that and look at your images next to others from the same airport or of the same aircraft, it won't guarantee anything but it will get you on your way
Jason
Flown On B704,722,732/3/4/7/8/9,744,752,762/3/4,772,77W,A319,A320,A321,A330,A388,L1011,F-50,BAE146,CRJ100, Dash-8. Left
viv
Tue Jul 16, 2013 2:22 pm
One pass of Smart Sharpen at 75 per cent, radius 0.3.
Job done.
trvyyz
Tue Jul 16, 2013 2:32 pm
You have zero credibility, people here express their opinion based on their years of experience with this site with lots of photos accepted and rejected. the posters above are correct in saying, that photos accepted here should be sharper than normal, but not extremely sharp.
[Edited 2013-07-16 07:33:33]
cjmoeser
Tue Jul 16, 2013 2:50 pm
Thank you for all the replies that have helped me. I didn't want an argument to start on this page, thats for a different time and place.
southwest9
Tue Jul 16, 2013 9:27 pm
Quoting trvyyz (Reply 11):
No one else was continuing to argue this until you brought it up again. I think Colin addressed this already. Thanks for your opinion anyways.
Quoting ckw (Reply 8):
Colin
trvyyz
Tue Jul 16, 2013 9:58 pm
Quoting southwest9 (Reply 13):
Sorry that I brought it up again, but I couldn't help but write when I saw your comments just writing off photographers who have over 2000 photos in the DB. Even the jaggies change from monitor to monitor, depending on it's quality and the resolution of the screen at which it is set. There is a very narrow margin on anet between soft and oversharpned, especially if one is not constantly uploading to this site. Anyway these mean nothing in real world photography IMO outside anet.
[Edited 2013-07-16 14:58:59]
ptrjong
Tue Jul 16, 2013 10:07 pm
Quoting viv (Reply 10):
Viv and others,
With Smart Sharpening, do you still manually deselect the background even if it's only sky? Or isn't that helpful?
Peter
ckw
Tue Jul 16, 2013 11:25 pm
Quoting ptrjong (Reply 15):
The whole point of Smart Sharpening is that it is supposed to be able to detect what is detail and what isn't. Advanced options also let you control strength in shadows and highlight.
Normally I'm pretty disparaging with tools labeled "smart" or "auto", but actually I think Smart Sharpen works really well most of the time. The new cloud release of PS has an improved version, but I haven't tried it yet.
Whether Smart Sharpen is suitable for A.net sharpen is another matter - I do think it can be a bit prone to halos when pushed too hard.
In my experience the apropriate amount of sharpening varies from lens to lens, and sensor to sensor. Viv's suggestion is a reasonable starting point - and may be ideal with a given setup - but I think some experimentation will be required for optimum results with your own camera and lenses.
Colin
ptrjong
Tue Jul 16, 2013 11:34 pm
Thanks as always Colin. Time to get rid of my old laborious technique I suppose.
viv
Wed Jul 17, 2013 5:59 am
No, there is no need to do that. Sharpen the entire image.
Quoting ckw (Reply 16):
Agreed. My setup is a Nikon D700 with in-camera sharpening set to 'off'; and the old Nikkor 80-400 lens. Aperture is usually in the range f/7.1 to f/11.
For static aircraft, I somtimes use a Fuji X Pro 1 with the Fuji 18-55 lens. Sharpening procedure is the same.
[Edited 2013-07-16 23:00:40]
