Screeners
Crew
Change In Motive Rejection Reasons
Tue Jul 16, 2013 7:26 am
To the airliners.net photographer community:
The screening team has been discussing the motive rejection reason over the last month and have decided to give a bit more leeway when it comes to minor obstructions, From now on we will look to accept images that may have a small portion of the landing gear or engine blocked by runway marker, light and airport signs as long as it is not too distracting from the overall image.Previously these types shots were regarded as an avoidable blockage and get rejected for motive but feel that is not always the case.
Below are a few examples of what is now acceptable.
Photo © Tim Easter
Photo © Jason Wood
Photo © Manny Gonzalez - Thrust Images
Photo © Lars Hentschel
Over the coming months Quality and Acceptance Criteria team will be reviewing more of our rejection reasons and whether any changes can be made, If changes are going to be made the screening team will discuss it and than inform the photographer community of these changes.
The Airliners.net Screening Team
derekf
RE: Change In Motive Rejection Reasons
Tue Jul 16, 2013 7:41 am
These changes are most welcome. It is amazing to think that the images above would have been rejected previously.
Whatever.......
mjgbtv
Tue Jul 16, 2013 10:36 am
What about cones blocking the engine or gear of a parked aircraft?
aussie18
Crew
Tue Jul 16, 2013 10:45 am
Quoting mjgbtv (Reply 3):
There has been no change in regards to static aircraft having cones blocking wheels, They are usually unavoidable and were acceptable and still are acceptable blockages.
Cheers Mark
Kiadprthd
Tue Jul 16, 2013 12:14 pm
Mark,
Thanks for sharing the update. I was curious if this new change will give any leeway to static aircraft at the gate that have a tug or ramp vehicle blocking a wheel or partially blocking the gear?
-Andrew
mjgbtv
Tue Jul 16, 2013 12:29 pm
Quoting aussie18 (Reply 4):
Okay, good to know. For what it's worth, I find that section in the rejection guide to be a bit confusing. The mention of cones seems to be under the category of "museum type shots", which I always took to mean a permanently parked aircraft, not one temporarily parked at a gate or on a ramp...
Marty
eskillawl
Tue Jul 16, 2013 12:38 pm
Really? I've recived a few rejections for cones blocking engines in the past months, where the screeners actually stated that the cone was the reason, on photo like this one.
http://i42.tinypic.com/2efiywi.jpg
Eskil
Photo equipment: Canon EOS 60D | Canon 70-200 F4L USM | Canon 18-55 3:5-5:6 |
ckw
Tue Jul 16, 2013 1:15 pm
Personally I've always found the "motive" rejection bizarre. I suspect becuase it was a poor translation of the concept the founder Johann was trying to express. I think it would be easier for everyone if the "bad motive" was broken down into clearly understandable reasons, for instance in the case of cones, barriers etc. "obstructions" or "clutter" might be more readily understood.
In my many years at A.net (as contributor, screener and viewer) "bad motive" has always generated the most confusion, upset and argument. Perhaps now would be a good time to unpack this catch all and make it clear what you mean.
Colin
Colin K. Work, Pixstel
Kiadprthd
Tue Jul 16, 2013 1:23 pm
I guess I will throw up the picture that I am curious about. I tried to avoid the vehicles and several different angles, but had no luck. Will there be any leeway in this situation?
http://www.airliners.net/addphotos/big/ready/p1373494966.6303sa.jpg
Andrew
derekf
Tue Jul 16, 2013 1:30 pm
Personally, I don't see anything wrong with the motive of your shot Andrew, it is an airliner doing what airliners do, but I suspect that it will still fall foul of a motive rejection.
Whatever.......
JakTrax
Tue Jul 16, 2013 1:32 pm
I must admit I'm not too keen on this relaxation. If the blockage was in any way avoidable, it shouldn't be tolerated unless the image depicts a very rare event or aircraft. That's just my opinion of course. I assume this move was set in motion by complaints and protests originating in the photographer community?
What's the current stance on grain? That's one of the issues heavily discussed; one which bothered an awful lot of people. I assume if we're seeing a relaxation such as the above the 'grainy' rejection will also be equally relaxed (within reason)?
If any changes are mainly down to general community reaction to the old criteria then I'm fine with that, irrespective of whether I agree or not. It at least shows someone has been listening. What I think is worrying a few people is the fact that there's the very real prospect of a general reduction in quality. I pointed out a few very dodgy recent acceptances to the heads and they told me they'd be discussed internally - which I assume means that they at least partly agree with my analyses.
As I said recently, I will reserve any real judgement until the new process is fully adopted. Any drastic change such as this will inevitably lead to initial errors until the system has had time to settle and adapt.
Karl
henkita217
Tue Jul 16, 2013 1:48 pm
I can definitely welcome this change.
Though, I just like to provide an example, just to make sure that we are on the right page.
Photo in question is below.
The airport is DPS (Bali).
Photo © Roberto Prawiro
As can be seen, there are thin wires placed which runs at the length of the taxiway, so theoretically, this is UNAVOIDABLE, beyond our control.
I have had a couple of photos rejected for motive, and the examples above were apparently accepted by mistake, as explained by an ex-head screener, which to me, it means the wires aren't distracting the photo/subject.
So, is it now OK to upload similar photos as per example above?
Please confirm.
HB
clickhappy
Tue Jul 16, 2013 2:54 pm
Quoting JakTrax (Reply 11):
Karl - we are discussing this as well. Not a 'relaxation' per say, but more of an effort to get all screeners to judge grain on a consistent basis.
My personal feeling is that we are way to strict with "grain" or "noise."
JakTrax
Tue Jul 16, 2013 3:03 pm
Royal,
Good to know. I suppose 'relaxation' was perhaps the wrong word to use as this suggests a lowering of the standards; in reality I think it just needs to be judged better, as you say.
I've always maintained that, of the numerous rejections reasons, 'grainy' is the least serious because it's the least noticeable and it's also not a true flaw (i.e. it's beyond the photographer's control and is a perfectly natural by-product of the photographic process).
I'm optimistic about these changes but one thing I will say.....
Please don't use this new system to encourage the acceptance of genuinely below-par images. I may have complained over the years but those complaints have only ever been about the application of the rules rather than the rules themselves. I think most would agree that the old system was in theory very fair. It demanded the highest quality; trouble was it was too open to interpretation.
As I've said repeatedly lately, any new system should make it EASIER (NOT EASY) to get a GOOD photo accepted, not just A photo.
Karl
dazbo5
Tue Jul 16, 2013 7:03 pm
Quoting screeners (Thread starter):
I think this is a move in the right direction as I often found the site a little anal when it come to minor blockages, especially if they were unavoidable. I hope avoidable, major blockages are still going to be rejected unless they add to the composition? We don't want to be taking too much of a backwards step here but an unavoidable cone or a little grass over the landing gear should not be rejected in my view.
Quoting clickhappy (Reply 13):
That's certainly another step in the right direction Royal. I certainly agree with Karl on this one that the site was becoming too obsessed with having no trace of noise when it was simply beyond what many cameras were cable of producing.
Quoting JakTrax (Reply 14):
I fully agree here too. While we all welcome the review of the acceptance criteria, there are certainly acceptances that I feel have gone a little too far the other way in terms of quality. While it'll take time to strike the new balance, standards need to be maintained high, but applied more consistently and without the pettiness we'd become accustomed to.
Spot on Karl, I wholeheartedly agree.
Darren
notaxonrotax
Tue Jul 16, 2013 10:07 pm
I noticed!
Photo © Sir Hofma
No Tax On Rotax
For anybody that happens to be wondering:"yes, owning your own aircraft is a 100% worth it!"
Kiadprthd
Tue Jul 16, 2013 10:34 pm
Thanks, derekf. After reading the post on here and looking at the posted examples, I'm going to leave it in the queue and see what happens. The worst thing that happens is it gets rejected.
aussie18
Crew
Wed Jul 17, 2013 3:14 am
Quoting ckw (Reply 8):
One thing that has been improved on these days is we give a lot of personals and usually motive rejections will receive a personal as to what the rejection for motive is "Unmotivated crop on stabilizer", Blocked nosegear"", Too much clutter" and so on.
Quoting dazbo5 (Reply 15):
Major obstructions we still get rejected unless they are part of the composition.
This is a good recent example of what we mean:
Photo © Fabrizio Capenti - Malpensa Spotters Group
We will continue to accept high quality images, Standards for the quality will not drop, Part of the reason for change was we felt that some nice shots were being rejected for a minor obstruction which were not too distracting.
Quoting henkita217 (Reply 12):
Those 2 examples for me would be acceptable though the AirAsia A320 is borderline as the fence pole blocking the wheel makes its more noticeable, The Garuda 330 the fence blockage is not to noticeable. We will judge each image on its own as it comes down to how distracting the obstruction is from the overall image.
But as mentioned I have seen plenty of shots from here and it does look like a unavoidable obstruction.
Cheers Mark
vikkyvik
Wed Jul 17, 2013 3:28 am
Karl, your point has been noted (several times   ), and as has been explained, that's not the goal here.
I agree. I personally think we're generally too strict on noise, but I'm one opinion in the bunch. Anyway, we're doing a pretty good job of discussing things behind the scenes. It will take time, as we're all in different locations and primary contact is through email. But I will also note that there was a note on grain in the forum post about revised screening criteria:
- Grain and noise in low light situations with subjects that are not static will receive more leeway
Obviously that's for specific situations, but it's still a step in the right direction.
walter2222
Sat Jul 27, 2013 6:25 pm
Hi All,
Maybe a silly question (but I have been away on holidays) and in the mean time, I got a motiv rejection for "waiving pilots" (photo taken during the last flight of the Phantoms to Jever):
http://www.airliners.net/addphotos/r..._20130705_img_42710_wvb_1200px.jpg
I was not aware that this was reason for a motiv rejection. Is this new?
On the other hand, I was pleased to see that my shot of the Phantom, with all the JG71 crew on top, did get accepted while I was on holiday and somewhat later I noticed (on my mobile) that it even made it to Photographers' choice     . I believe this was a first for me and I would like to thank all photographers for their votes. I am sure that this had more to do with this special event than with the quality of the shot (because conditions were really poor)...
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
derekf
Sat Jul 27, 2013 7:05 pm
Having the photo rejected for that reasons seems particularly trivial. "Waving pilots" maybe
Seriously that seems very petty to me.
Whatever.......
eskillawl
Sat Jul 27, 2013 8:19 pm
Quoting walter2222 (Reply 19):
That rejection reason is stated in the rejection reasons guide. The screeners do not accept photos where waving pilots is in what they call "sole focus", who they are in your photo.
Eskil
acontador
Sat Jul 27, 2013 11:24 pm
Hi Walter.
From the rejection guide:
Close up cockpit shots with the only reason for the shot being showing pilots waving
Now, I did reject the picture, but you forgot to add the other rejection reason, double. Overall, since you already had a static shot same aircraft/day/side accepted that showed the complete side of the aircraft, including the cockpit, I felt that the rejected one was focused solely on the waiving pilots. In any case, if you do not agree please feel free to use the appeal function, that is the reason it exists  .
Keep the nice pictures coming, and hope the weather is better and more cooperative!
Andrés
Just sit back, relax and have a glass of Merlot...enjoy your life!
sulman
Sun Jul 28, 2013 5:26 am
The waving pilots thing came in (if I recall correctly) because certain photographers at AMS and one or two other places used to fill the queue with them, and caption them accordingly (for hits). I think people just got tired of it.
walter2222
Sun Jul 28, 2013 11:02 am
Hi All,
Thanks for your feedback!
@ sulman: I agree with the situation at AMS, as you explained, but here it is a caption of the "Phinal moment": the pilot greet the phorographers and their friends/families because it is theire final moment in the Phantom, before it will be dismantled and scrapped. That was my motive for capturing it.
@ Andrés: This shot (the 38+48) was solely rejected for "waving pilot" (not "waiving" as I put it first  ...). I had another one (the 37+22)rejected because I had already one in the database and for this one you mentioned double (but to me, as explained above, it is a clearly different motive...).
I know that weather conditions were not ideal, but this was an event which will never happen again. Hence I also thought that a shot during taxi and a shot taken at the ramp (the final death row) were also different enough to avoid the double rejection, but this is apparently not the case ;-((
Walter
acontador
Sun Jul 28, 2013 3:52 pm
Hi Walter,
You are absolutely right, I did reject your 37+22 shot with the personal "Hi Walter, sorry but cockpit already visible on your other shot same day/side, and main motive are the waving pilots", while another colleague rejected your 38+48 one with the personal "waving pilots". Good to know that we are being consistent   !
I just wish I could have attended the F-4 Pharewell and the Phinal Mission, but at least I got to see a lot of pictures of it. Too bad for the weather, though.
Andres
walter2222
Sun Jul 28, 2013 7:37 pm
Quoting acontador (Reply 25):
Hi Andrés, that's a fact! But I wished it to be otherwise (this time)
Would you mind if I would try an appeal (for the one which was not double)?
You still have a chance to see a German Phantom, but you have to hurry! One of the WTD61 Phantom's (the 37+15) is flying from Manching to Jever on Monday (July 29th, 2013) and the other one (38+13) will most probably perform for the phinal time on Tuesday (July 30th, 2013) at Manching.
Walter
acontador
Sun Jul 28, 2013 10:01 pm
Hi Walter,
Quoting walter2222 (Reply 26):
Of course not, that's your right   .
Andrés
venemaje
Sun Aug 04, 2013 5:32 pm
Hi everyone:
Leaving the picture quality aside (sharpeness, resolution, etc.), what's the problem with "motive" in this picture? Just trying to understand so that I know better what to look out for:
[Edited 2013-08-04 11:03:27]
vikkyvik
Sun Aug 04, 2013 6:00 pm
Motive looks fine, unless there's some small blockage I can't see at that resolution.
Could use a tighter crop on the right, though.
unattendedbag
Mon Aug 05, 2013 10:57 pm
Quoting aussie18 (Reply 17):
Quoting vikkyvik (Reply 29):
Could this photo be used as a bench mark?
Photo © Szabo Gabor
Everyone is talking about "small" and "barely noticeable" blockages. Are inactive airstairs that block the entire nose gear acceptable?
Slower traffic, keep right
vikkyvik
Tue Aug 06, 2013 6:45 pm
Quoting unattendedbag (Reply 30):
After discussion among the Quality Team and Head Screeners, it was determined that the photo should have been rejected for Motive. It has been removed from the DB.
The basic consensus was that the combination of the airstairs, the pole blocking the main gear, and the gear being half cutoff by the tarmac were all too distracting.
So I guess the answer to your question is no, it shouldn't be used as a benchmark.   The photos posted at the beginning of this thread are more representative of what we're looking for.
Thanks for bringing it to our attention.
derekf
Tue Aug 06, 2013 7:25 pm
Quoting vikkyvik (Reply 31):
Boy, I bet that's made you popular with the photog!
Interesting that half the aircraft can be invisible behind clouds of vapour, or large parts cut out through framing and yet small portions hidden by steps or tarmac or grass are deemed unacceptable. Truly one of airliners.net's little foibles
Whatever.......
unattendedbag
Tue Aug 06, 2013 10:11 pm
Quoting derekf (Reply 32):
I don't know if you are talking to me or Vik, probably both. That being said, I love the shot. Any shot of an SP and I begin to drool, especially in that golden light. I hope Szabo has another chance to capture it as he has a beautiful collection of 747SP's already. But I had to question it seeing as we are all attempting to test the boundaries of this rule relaxation. I have a shot of an aircraft that has the center of the fuselage blocked by a set of airstairs. Now I know the motive would be unacceptable.
vikkyvik
Tue Aug 06, 2013 10:24 pm
Any attempt to enforce consistent screening will inevitably lead to some images being added, and others removed, after the fact (and has already resulted in such). I hope the photographer community will understand these actions, and be willing to work with us. That said, of course no one likes having an image removed after it's been added.
Quoting unattendedbag (Reply 33):
I'd suggest you post it in the Feedback Forum.
