G-CIVP
In Camera Sharpness
Sun Jul 21, 2013 11:18 am
Further to the previous question regarding picture styles for a Canon body, we have a follow up question.
Should a photographer ever adjust in camera sharpness (in picture styles) or set it to zero and adjust in post photo processing? I'm aware that if shooting RAW this is immaterial but for jpeg users this will be different.
I'm just interested to see what photographers' opinions are and whether there is a consensus.
yerbol
Crew
RE: In Camera Sharpness
Sun Jul 21, 2013 12:26 pm
I always keep my in-camera sharpness on default settings and do all post processing with sharpness afterwards.
With best regards from Almaty
viv
Sun Jul 21, 2013 1:18 pm
Turn it off.
Why? Because it will sharpen things that should not be sharpened, such as the sky.
dazbo5
Sun Jul 21, 2013 1:48 pm
Quoting G-CIVP (Thread starter):
I always keep it to the default setting. In my opinion, sharpening is better done in post rather than letting the camera do it. You can't reduce it once the camera has applied sharpening but you can sharpen as much or as little as you want in post, and most importantly, selectively.
Quoting viv (Reply 2):
I couldn't agree more.
Darren
RCoulter
Sun Jul 21, 2013 2:58 pm
I shoot RAW so I actually have mine set at the highest setting, I find it helps me weed out photos on the camera easier by showing blur better on the cameras LCD.
vikkyvik
Sun Jul 21, 2013 5:52 pm
On my Rebel XS, I left it at default (3). On my 50D, I have it set at 4.
Quoting dazbo5 (Reply 3):
But the default setting on the cameras I've used isn't zero....
I don't find the slight sharpening it may apply to the sky to be an issue, ever. I actually find the reduced sharpening I have to give it after resizing is more of a benefit.
Silver1SWA
Crew
Sun Jul 21, 2013 6:32 pm
Quoting RCoulter (Reply 4):
     THIS! For LCD viewing purposes, I crank in camera sharpening all the way up. Since I open photos in ACR, all in camera parameters don't apply anyway since ACR has it's own defaults, giving me a clean slate.
G-CIVP
Sun Jul 21, 2013 9:30 pm
Interesting discussion. One emerging issue is the definition of 'default'. As vikkyvik notes, the default setting on Canon cameras isn't necessarily '0' (zero) but set at '3' for standard picture style on a 60D, which has preciptated the question. So as Dazbo5 suggests, should this be dialled down to '0'?
For anyone wishes to contribute further I would be interested to read your thoughts, then I will share my conclusions.
vikkyvik
Sun Jul 21, 2013 9:35 pm
Quoting G-CIVP (Reply 7):
There's really no "this should" or "this shouldn't". It's whatever works for you. I found I had to dial up sharpness a bit when I got the 50D, so I did. Works for me.
ckw
Sun Jul 21, 2013 11:05 pm
Yes, the default sharpening is not 0 - partly, I suspect, to avoid people being put off by soft images on the LCD (and haven't read the manual).
I think there is some debate as to whether or not it is possible to turn sharpening completely off (ie. many claim even if set at 0, a small amount of sharpening occurs). Again this may be camera specific and possibly related to the strength of the anit-aliasing filter (which varies between models).
In general I'd advocate using the weakest setting on the principle that sharpening can be added, not removed. However, if the object is to avoid post-processing, then the default setting is probably better. With zooms which may be soft at the long end, increasing the strength may be worthwhile.
If post processing is not an issue, then I would ask why not shoot RAW?
Colin
Colin K. Work, Pixstel
dazbo5
Mon Jul 22, 2013 7:09 am
Quoting vikkyvik (Reply 8):
That's the real key, it's whatever works for you. I'm sure everyone here does things slightly different, but it's the end results that really matters. That's where experience comes in, play around with the settings and use what works best for your personal needs.
Darren
sulman
Mon Jul 22, 2013 7:44 pm
Funnily enough, a lot of newer workflow and 'digital asset management' (bleurgh) software is doing essentially the same thing these days; even ACR tries to sneak in a little sharpening; one has to remember to switch it off.
Canon DPP is interesting for this as you can effectively experiment with those same presets and see exactly what they do.
Silver1SWA
Crew
Mon Jul 22, 2013 8:31 pm
Quoting sulman (Reply 11):
For Canon, your in camera setting when shooting RAW are only relevant to your post process if you're starting your edit using Canon's DPP because it handles the file exactly as it was shot in camera. Otherwise programs apply their own base settings to your files unless set up otherwise.
coninpa
Wed Jul 24, 2013 9:40 am
Turn it off.
Perfectly agree. In addition, if a wing or stabilizer is oversharpened in-camera, it's very hard to impossible to recover in post-processing.
As a personal taste, I shoot only in RAW and sharpen in post processing.
Patrick De Coninck
G-CIVP
Fri Aug 02, 2013 2:02 pm
Just a short note to thank everyone for their contributions. The main conclusion is to turn off in camera sharpening and shoot in RAW if you don't mind post photo processing. The other issue which hasn't been mentioned is the quality of lens which may have a bearing on whether the final image is sharp.
Silver1SWA
Crew
Fri Aug 02, 2013 3:45 pm
Quoting G-CIVP (Reply 14):
   Shooting in RAW is plenty reason to turn ON in camera sharpening because it can be altered or removed in post!
vikkyvik
Fri Aug 02, 2013 4:08 pm
Quoting Silver1SWA (Reply 15):
Or turn it off because it can be added in post.
