LenFTM
Advice On New Nikon
Thu Aug 01, 2013 2:38 pm
In a few weeks time, i'm looking at trying to upgrade to a higher spec Nikon Body (currently using the D3100 with a 55-300mm Nikor lens) Just wondering what peoples thoughts and experiences with the D7100 are? Haven't seen to many shots with it, so just wondering how good the image clarity etc is?
viv
RE: Advice On New Nikon
Thu Aug 01, 2013 2:55 pm
Image quality depends mainly on the lens.
sovietjet
Thu Aug 01, 2013 4:10 pm
Quoting viv (Reply 1):
I guess then things like full frame vs crop frame, high ISO performance, resolution of the sensor and AF performance don't matter much.
baldwin8
Thu Aug 01, 2013 5:41 pm
Quoting sovietjet (Reply 2):
I don't think the D7100 is full frame, is it? The higher ISO performance may not be a factor if you your not shooting very low light level images.
viv
Thu Aug 01, 2013 7:07 pm
Not for this site, no. A Nikon D70 with a good lens will get photos uploaded here, in the hands of a good photographer.
megatop412
Fri Aug 02, 2013 2:41 am
Guys, WTF. He's asking about the D7100, not hear the old 'upgrade glass first' debate.
trvyyz
Fri Aug 02, 2013 3:28 am
Quoting megatop412 (Reply 5):
Same old replies, yes glass is more important than body, but body to body also makes difference(otherwise guys buying higher end bodies must be stupid as per some of the posters, who themselves may be using expensive cameras).
I don't buy cameras for this site, for this site even a point and shoot could work.
Coming to D7100,
the D7100 has the af motor, cls system, two control dials, far superior AF system, better sensor, AF fine tune compared to an entry level D3100, also better body construction and weather sealing.
LenFTM
Sat Aug 03, 2013 7:31 pm
Thanks for the (eventual) feedback guys. Seems like a good piece of kit. Debating on this or saving a bit more for the D600.
afterburner
Sun Aug 04, 2013 2:02 pm
Dylan, if you upgrade to D600, you'll need new lenses. And full frame lenses are not cheap (compared to cropped sensor DSLR lenses).
LenFTM
Sun Aug 04, 2013 8:10 pm
Quoting afterburner (Reply 8):
Ah, thanks for that afterburner, i didn't know that! So a Nikor 55-300 wouldn't be much use on a D600 then?
Dylan
TristarAtLCA
Mon Aug 05, 2013 3:19 pm
Quoting LenFTM (Reply 9):
You can use all AF-S lenses on a D600. Obviously, it will blank out the corners of your images in FX mode.
The D600 also has a crop sensor option to use your 55-300 as it was designed by using a reduced number of pixels on the sensor. Kind of defeats the object of buying a FF but it is an available option.
If you was right..................I'd agree with you
afterburner
Tue Aug 06, 2013 5:07 am
Nikon 55-300mm is a DX lens. It is designed for Nikon DX (cropped sensor) cameras like your D3100. D600 is an FX camera. It needs FX lenses like Nikon AF-S 70-300mm. yes we can use DX lenses on FX cameras. However, like TristarAtLCA said, the images produced will be dark around the corners.
LenFTM
Fri Aug 09, 2013 10:47 am
Thanks guys. Looks like I'll go for the D7100 and keep hold on the 55-300mm
Much appreciated
