epten
Average Accepted/rejected Ratio On Airliners.net
Wed Sep 04, 2013 6:04 pm
If this information is available elsewhere, or has been discussed before, I sincerely apologize.
What is the average accepted/rejected photos ratio on airliners.net?
angad84
RE: Average Accepted/rejected Ratio On Airliners.net
Wed Sep 04, 2013 8:54 pm
Does the site keep track? I don't know where to look except the photo upload page, which has me at 72% based on my most recent uploads.
Nice to realise that I've ditched my earlier trend of "daily rejections punctuated by the odd acceptance"
Angad
Kaphias
Thu Sep 05, 2013 3:14 am
78% here. Really surprised (and pleased) to see it that high!
Matthew
Thu Sep 05, 2013 4:15 am
The Screening Process, A Report Or Interview? (by axelesgg Feb 23 2012 in Aviation Photography)
Reply 30 points to an approximate 55% acceptance ratio. I assume the site itself doesn't keep track.
Newark727
Thu Sep 05, 2013 4:45 am
Quoting NZ107 (Reply 3):
You know what that means? I'm AVERAGE!
viv
Thu Sep 05, 2013 11:09 am
I would guess around 60 percent.
Could be a bit less.
derekf
Thu Sep 05, 2013 11:19 am
I'll soon drag that average down......
Whatever.......
scbriml
Thu Sep 05, 2013 11:51 am
The screeners have access to stats that show total screened, accepted and rejected for each screener, so it's a simple calculation to come up with an overall acceptance ratio for the site as a whole.
ThierryD
Head Support
Thu Sep 05, 2013 11:55 am
Looking at the acceptance/rejection stats of the last 2 months, I'd set the number at about 60% acceptance ratio, maybe slightly more.
Kind Regards,
Thierry
"Go ahead...make my day"
epten
Thu Sep 05, 2013 3:47 pm
It's me then  I suck.
Thank you all for your answers!
derekf
Thu Sep 05, 2013 8:53 pm
Quoting epten (Reply 9):
No you don't. I've been taking photos for 35 years and have a acceptance ratio of 40%. Not getting photos accepted here doesn't mean you suck at aviation photography.
Whatever.......
Carp12c
Thu Sep 05, 2013 10:38 pm
Well I'm definitely not doing things right. I've tried sending 4 photos in and all rejected. Though it might have something to do with me only using iPhoto as an editing material...
trevisan26
Fri Sep 06, 2013 1:31 am
Quoting Carp12c (Reply 11):
Try to use Pixelmator, its much better than iPhoto to edit, in my opinion. Pixelmator cost something like 20$ at app store.
Carp12c
Fri Sep 06, 2013 1:51 am
Quoting trevisan26 (Reply 12):
Thanks for the advice, I'll look into that.
baldwin8
Fri Sep 06, 2013 1:53 am
There definately is an eye needed for finding that sweet spot of editing. I as well have been photographing aircraft since at least 1980. Shot and traded countless aviation Kodachrome with many compliments on my work.
Today I had 2 rejections, the second actually made it past the first screener according to my email. Then rejected with about 6-7 reasons, contrast, common.... etc.. I guess the second screener thought the image was not unique enough. But c'est la vie.
For most of my images I follow my set approach to editing, but I just don't have the eye for what the screeners see. I am not doubting their judgement, just a bit frustrated in the process.
derekf
Fri Sep 06, 2013 5:27 am
Quoting baldwin8 (Reply 14):
That sounds like me as well.
Whatever.......
scbriml
Fri Sep 06, 2013 10:55 am
It has nothing to do with being unique or not. The 'common' rejection reason is often misunderstood - it basically means that there are already a lot of accepted images of that exact plane, so your image needs to be near perfect in quality terms in order to be accepted. It could be a "boring" side-on shot, but as long as the quality is good enough, it will be accepted.
You would actually get a lot more leeway for a shot of a plane that's not already in the database.
From the rejection reasons page:
http://www.airliners.net/faq/rejection_reasons.php
The aircraft depicted in your photos was very common in the Airliners.net database, with many photos of this aircraft already present on the website.
In this case the standards for acceptance are higher than for aircraft of which we have fewer or no photographs on the database, and only photos of exceptional quality will be accepted.
Please understand that this is not a judgement on your abilities, as your picture may be of a technical quality which may be very decent. However, due to the common nature of the aircraft photographed, the highest standard is applied to avoid substantial duplication.
When uploading you should always check our database for the amount of photos we have of the particular aircraft you are uploading. If a particular aircraft or registration is common in our database, you may increase the likelihood your photos of it will be accepted by photographing it from an unusual angle, under exceptional lighting conditions, or with interesting scenery in the background.
Note that the common rejection reason will always be given in combination with another rejection reason. This means that if your image gets rejected for QUALITY and COMMON the image is too common for the quality you provided.
We often get asked when an aircraft is common. This may vary. A general rule could be from about 60-70 images onwards. That number may be lower for an easyJet A319 or Southwest 737 because those are likely to be heavily shot in the future. Similarly that number may be higher for aircraft of which only one example exists and even with 200 images can be relatively rare in our database.
baldwin8
Fri Sep 06, 2013 11:40 am
"If a particular aircraft or registration is common in our database, you may increase the likelihood your photos of it will be accepted by photographing it from an unusual angle, under exceptional lighting conditions, or with interesting scenery in the background."
My rejection depicted the aircraft on touchdown of landing with one main gear smoking it's wheels and the other main gear still in the air. It was taken from a unique location at the airport I work, so to me and the people I showed it to, thought it was a rather unique shot. But I do understand the screeners reasoning as for this was not Wow enough.
Thanks for reading.
Joshu
Screener
Fri Sep 06, 2013 2:50 pm
I have a 76% acceptance rate right now using a T3i and a 55-250 lens. I would attribute this high number to two important factors:
1) Shoot in good light
2) Follow the A.net editing guide. I only have made minor deviations from that guide.
Washington-Baltimore Spotters Group
scbriml
Fri Sep 06, 2013 5:06 pm
Quoting baldwin8 (Reply 17):
I'm afraid you're missing the point.
1 - A shot of a 'common plane' (using this site's definition) doesn't have to be award-winning to be accepted. It does need to be very good in quality terms. It can be a side-on and still be accepted providing the quality is good enough.
2 - The 'common' rejection reason should always be combined with another rejection reason. If there's no other reason to reject the image, then it should, by definition, be accepted. For example, if a shot was rejected for 'level' & 'common', it would likely be accepted if the level part was fixed.
A real example - this shot of a BA A320 was accepted recently despite it being 'common' (with 107 images before mine was accepted). It's not jaw-droppingly stunning, but was of good enough quality to be accepted despite being 'common'.
Photo © Steve Brimley
baldwin8
Fri Sep 06, 2013 5:21 pm
Quoting scbriml (Reply 19):
Actually, my point was that the first screener had not rejected it according to my email and the upload was waiting for a second screener. The second screener had come up with so many reasons for rejecting, grainy, contrast, common...,plus a couple more. If it was so bad, I guess I didn't understand how it got passed the first screening, considering the other image of mine screened that day was rejected for just one reason.
I guess I failed to make myself clear enough on this issue.
Thank you
angad84
Fri Sep 06, 2013 6:26 pm
Quoting baldwin8 (Reply 20):
That probably means the first screener was sitting on the fence regarding the image as a whole - it may have been a nice dramatic shot but with technical issues (the other 6-7 reasons you mentioned). The first screener then flagged it for a second opinion from another screener who, when they got the chance to review the image probably decided that the technical issues outweighed the uniqueness of the shot.
I could be wrong, but this is what I've understood from the older "explain the screening process" threads and various screeners' comments in the photography forum over the past couple of months.
Angad
PositiveClimb
Fri Sep 06, 2013 7:07 pm
G'day everybody!
I have no idea about the global acceptance/rejection rate on the site, but for me personally I currently stand at a 86% acceptance rate:
I only have a mere 50 images in the db, as I re-started spotting just recently, but I am quite pleased with this acceptance ratio. Nonetheless, I have no illusions at all about my photographic skills, and I am sure that having a good acceptance ratio over here is in no case an indicator for how good a photographer you are.
Shooting in good conditions and having a solid post-processing workflow surely helps in having a solid acceptance rate, but in my case leads to having more 'safe', means non-artistic photos uploaded here. Anyway, I hope that with becoming more experienced, I will one day be able to take some photos which are at least half as jaw-dropping as many of those uploaded by all of you each and every day
Fabian/PositiveClimb
A380 - love at first flight!
eskillawl
Fri Sep 06, 2013 9:08 pm
I currently have 52 percents, but it varies both up and down.
Photo equipment: Canon EOS 60D | Canon 70-200 F4L USM | Canon 18-55 3:5-5:6 |
relic
Fri Sep 06, 2013 9:30 pm
I am at 62 percent at tne moment.Has been higher.Had a break for about a year,Maybe im just losing that edge to see what is acceptable and what is a no no .
Andy
baldwin8
Fri Sep 06, 2013 10:07 pm
I have searched "Photographers Corner"and can't find where to see my photo acceptance/rejection ratio.
Could someone tell me where I would see it?
Thank you
mjgbtv
Fri Sep 06, 2013 10:20 pm
Quoting baldwin8 (Reply 25):
As far as I know it only appears on the upload page like Fabian's screenshot above.
acontador
Fri Sep 06, 2013 10:50 pm
Hi Craig,
Actually, there are a few issues not (necessarily) correct within your statement. That part in the screening email that says something like "You have another 3 pictures which have passed first screening..." means that these 3 pictures have been viewed by at least one screener (we can discuss the poor choice of the word "passed", but that's another story), it does not mean that one screener didn't find any problems with it. For example, it may be that the first screener sees that the pictures has some issues due to the bad light, and thus highlights those for the next one with a comment. At the same time, he may not be sure about the correct information supplied by the uploader, so he also leaves a comment in this respect. Some pictures (usually borderline ones in terms of quality and/or motives) are seen by more than two-three screeners, but that is not the rule.
Also, please note that we always try to include all issues we see in a picture when rejecting as a help for the photographer for him to recognize and try to improve the edit, even if some of these issues by themselves might not be of such a degree as to solely warrant a rejection. As Steve correctly pointed out, "common" is meant to tell the photographer that this particular registration is already well covered in the database, and thus the quality standard required will be a little higher, and is therefore not a stand-alone rejection reason.
Finally, as you may appreciate, screening is a tough task if you want to do it correctly, and within the screening team we aim at the highest possible level. Add the usual time constraint (nobody has spare time these days...), and you'll quickly realize that while we try our best, mistakes can and will happen. The good news is that any uploader can help us, by uploading only their best pictures (don't choose the angle you like but the best quality), by adhering to the few rules we have, and if you happen to get a rejection please realize that this is not personal, nobody thinks that you are a bad photographer, but we only judge the picture as per our acceptance guidelines. In the end, we want to accept you picture, and that is what matters most for us.
Andres
Just sit back, relax and have a glass of Merlot...enjoy your life!
bricejohnson
Sat Sep 07, 2013 1:05 am
You can find it on the upload page (like mjbtv previously said).
Happy shooting!
Calvin
Calvin
JOAOCS
Sun Sep 08, 2013 1:27 am
I don´t think the screening process is reliable nowadays. Maybe there are too many photos for the screeners, maybe there´s another reason, I don´t know. Uploading is not a pleasant task anymore; on the contrary, it is very frustrating.
I´m being politically incorrect, call me cynic.
[Edited 2013-09-07 18:37:22]
NPeterman
Sun Sep 08, 2013 4:12 am
Quoting joaocs (Reply 29):
I would not be so quick to condemn. Are there photos that sometimes raise my eyebrows a time or two, certainly (although that number spiked considerably during the MAKS priority period for what it was worth). However, as a whole, I certainly see no issues with the screening criteria or process as a whole. Over the past 3+ years I have been uploading I have certainly had to adjust some of my processes to ensure my standards were up to those enforced here, but my acceptance rate has gradually climbed to the mid 70's here, and has hung around there for a while. The appeals process certainly seems to work in my opinion-had a rejection that seemed somewhat iffy overturned just in the last week or so.
Were I to levy a complaint against the process, it would be that I have to wait so long to be screened and upload consecutive batches. We all get rejections, but speaking for myself, I can say that they make me more conscientious in my shooting and editing, and I certainly cannot complain about that!
N
JOAOCS
Sun Sep 08, 2013 6:44 pm
You are at mid-70 acceptance ratio; mine dropped to 0% and nothing I try works.
I talk reliabity and that´s reliability I mean. Last week I had a rejection: "soft". Ok, no big deal, I started CS6 and applied a subtle sharpening, saved, sharpened a little more, saved under another name, sharpened a little more, saved again. I reuploaded the first one. Result: "oversharpened".
I think I´m done with plane photography, for some time or for good. I have a buyer for my D800; photography is not important; it´s a simple hobby, no big deal. Today I´ve been shooting racecars with the D300, a camera I like; maybe I´ll sell it also, maybe I´ll keep it, I don´t know.
Airliners.net took me to photography three years ago; now I´m moving to greener pastures. It was a good time, for the first year. Life´s good.
eskillawl
Sun Sep 08, 2013 7:34 pm
Quoting joaocs (Reply 31):
So for you planespotting is nothing else but Airliners.net? There's no planespotter that's not uploading to Airliners, and everyone that doesn't can't be considerd a planespotter? The majority of the planespotters, Id say do not upload to this site, but they're still enjoying the hobby!
What I want to say is that you should stop focusing on your rejections here and start focusing on your actual hobby.
Eskil
