ptrjong
D90 Error
Tue Oct 08, 2013 12:07 pm
Hi all,
My old Nikon D90 has developed an eletronic fault. The shutter still works, but photos are not being recorded and settings cannot be changed. The display on top says 'Err'. Photos on the memory card can still be seen and browsed through.
Removing the battery, or pressing the reset button on the side of the camera doesn't help. Are there any tricks out there for a deep reset maybe? Clickhappy in an old thread talks about a 'two-button reset', how?
The camera is due for replacement soon anyway. If I send it in for repair, is there any chance that this is going to be cheap, in your experience?
Peter
[Edited 2013-10-08 05:11:11]
clickhappy
RE: D90 Error
Tue Oct 08, 2013 11:53 pm
Hold down the two buttons with green dots next to them, give it a solid five count and then release.
ptrjong
RE: D90 Error
Wed Oct 09, 2013 8:24 pm
Thanks Royal. It doesn't help though.
Bestof79
RE: D90 Error
Wed Oct 09, 2013 8:51 pm
Hi Peter,
how about a Firmware update? Did you already try it? It will may help if the reset doesn´t work.
ptrjong
RE: D90 Error
Wed Oct 09, 2013 9:00 pm
Quoting Bestof79 (Reply 3):
Hi Andre,
I didn't think of that, it won't hurt to try it suppose. Thanks!
ptrjong
RE: D90 Error
Sat Oct 12, 2013 9:54 pm
I don't get the 'update' option in my camera under 'Firmware version'. I did put NKLD01009.bin on the root of the memory card.
However I googled a bit of course and somebody else with these symptoms had a broken diaphragm. Is there any way to check if it might be this?
ptrjong
RE: D90 Error
Mon Oct 28, 2013 1:26 am
This thread can be closed as far as I'm concerned - I'm now the happy owner of a D7100.
By the way I had a mental blackout - the broken camera is a D80, not a D90.
Peter
