• 1
  • 3
  • 4
  • 5
  • 6
  • 7
  • 10
HarryLi
Re: Pre-screening ---Harry
Fri May 05, 2017 1:49 pm
airkas1 wrote:
Centering is fine. Any lower will be low in frame.
:covereyes: ,yes i think is fine. And i am considering to upload it again. Is it worth uploading again ?
I am a Guangzhou Spotter. My photos are here : http://www.airliners.net/search?user=20 ... =viewCount :D
airkas1
Head Screener
Fri May 05, 2017 1:59 pm
Well, it's already been through the appeal, so nothing to do about it.
So I would just re-edit it and lower it a bit. Not by a lot, but by enough that it won't be seen as a reupload without change.
HarryLi
Fri May 05, 2017 2:42 pm
All right ,i re-edited it just now. Here is the comparison. What do you think ?
1. Rejected just now
2. Re-edited just now
:confused:
airkas1
Head Screener
Fri May 05, 2017 3:51 pm
You didn't place it lower, it's still more or less the same centering.
HarryLi
Fri May 05, 2017 4:02 pm
So... what about this one ?
airkas1
Head Screener
Fri May 05, 2017 5:03 pm
Yes, should be ok.
HarryLi
Fri May 05, 2017 9:51 pm
airkas1 wrote:
Yes, should be ok.
That's good ! Thank you kas ! ;)
HarryLi
Sat May 06, 2017 1:18 pm
I edited a Window shot just now. Is it ok ?
http://imgproc.airliners.net/photos/air ... 92fea5c054
HarryLi
Sat May 06, 2017 2:29 pm
airkas1 wrote:
Yes, should be ok.
Hello Kas, i have a photo which rejected by screener just now and the screener gave me only one reason ----- Soft
But i don't think it is soft. Is it worth appealing ?
http://www.airliners.net/user/photo-cor ... to/4346263
Harry
airkas1
Head Screener
Sat May 06, 2017 5:39 pm
The wingview looks ok (if it's not a double). For the rejected photo - you linked to the photo corner instead of the photo.
HarryLi
Sat May 06, 2017 5:48 pm
Oops ! Sorry about that . :shock:
Here is the correct link : http://imgproc.airliners.net/photos/air ... 388df6ba5d
airkas1
Head Screener
Sat May 06, 2017 6:39 pm
It's oversharpened, not soft.
HarryLi
Sat May 06, 2017 6:44 pm
:knockout: All right. I think I'd better re-edited it again. Thanks for your reply.
Harry
HarryLi
Sat May 06, 2017 6:51 pm
What do you think about this A330 ? It is in High Quality Queue now.
http://imgproc.airliners.net/photos/air ... 37fbc508c7
HarryLi
Mon May 08, 2017 4:54 pm
Hi guys, i edited some old photos that i took 2 years ago. Is it ok ?
http://imgproc.airliners.net/photos/air ... d750a77f3f (SQ A333)
http://imgproc.airliners.net/photos/air ... 445a7db0f3 (MD A343)
Appreciate your opinions here ! :)
Harry
len90
Mon May 08, 2017 9:46 pm
Harry,
The A330 the screeners agreed with my thinking and it was accepted.
The two year old photos was that the same equipment you are using now? Colors just don't look nearly as good.
SQ 330: Slight CCW rotation. Maybe like 0.25-0.50. May have a color cast there, just something looks off about that white
MD 343: Might also benefit from a slight 0.25 CCW rotation.
Sharpness and grain I can't judge on the current display I am using.
Len90
HarryLi
Tue May 09, 2017 3:18 am
len90 wrote:
Harry,
Hi, Len
Yeah, as you said, i used different camera before.I used 400D 2yrs ago but now i am using 5D2 and 700D . The color indeed seems strange but i am trying my best to revise it. Thank you for your advice i will make some ccw for them later.
Harry
HarryLi
Tue May 09, 2017 7:04 am
I re-edited the MD A343 again. The color seems better than before .
Is it ok ?
http://imgproc.airliners.net/photos/air ... ef7825a14f
len90
Tue May 09, 2017 3:30 pm
That equipment change makes a big difference. Colors are night and day between your two set-ups. Looks a bit better. Just wonder if it is still a little too dark/contrasty.
Len90
HarryLi
Tue May 09, 2017 3:46 pm
Yes, the quality of the photo has changed a lot . So i seldom to edit old photos . I am not sure about the exposure either. :beady:
HarryLi
Wed May 10, 2017 11:11 am
Is it ok ?
Can anyone give more advice ? :mrgreen:
jelpee
Screener
Sat May 13, 2017 4:07 pm
Color looks OK to me, but quality is very poor.
Jehan
HarryLi
Tue May 16, 2017 7:42 am
Jehan
Thanks Jehan ! I have deleted it from the queue. I agree with you that the quality is much lower than now. Maybe is because the old camera and the CMOS has become old.
Harry
HarryLi
Tue May 16, 2017 7:46 am
HarryLi
Thu May 18, 2017 3:10 pm
Hello guys, i edited a lovely special livery today and i love it very much.And this is my first time to see maybe is the last time because i heard that it will over soon.
http://imgproc.airliners.net/photos/air ... 961ce72d7a
The light is a little harsh but i think is ok. Is it passable ? Appreciate your opinions here !
Thank u for your time .
Harry
len90
Fri May 19, 2017 1:32 am
Lots of pictures...
EY A332: may be a bit OS on the tail and blurry on the window line... could just be the sun glare on it
IL-96s: IF both were taken around the same time they differ a lot in contrast and color. 96022 might be a bit low on contrast and over exposed
HU 789: Fine
HU 789 Kung Fu: Fine
SQ 388: Okay.
FX MD11: Okay
SAS 340: Low in frame
JAL 763: Looks to just be not of as good quality. That's tough lighting.
Len90
HarryLi
Fri May 19, 2017 11:14 am
len90 wrote:
Lots of pictures...
HU 789: Fine
SQ 388: Okay.
FX MD11: Okay
Yeah, more than before this time. And i agree with your opinions and i have re-edited the SAS and 2 IL-96s. Would u please help me have a look again? Thank you for your time again.
http://imgproc.airliners.net/photos/air ... 7bb0eec8e9 (SAS A343)
http://imgproc.airliners.net/photos/air ... c1695150c3 (RA-96022)
http://imgproc.airliners.net/photos/air ... 9e069dc32d (RA-96021)
Harry
HarryLi
Sat May 20, 2017 12:41 pm
airkas1
Head Screener
Mon May 22, 2017 11:00 am
A343: Look ok.
IL96 (22): Nice, but a bit high in frame.
IL96 (21): Looks ok.
A330: Looks ok.
A319: Looks ok.
HarryLi
Mon May 22, 2017 3:05 pm
airkas1 wrote:
A343: Look ok.
A330: Looks ok.
A319: Looks ok.
Hello Kas,
Long time no see. I have re-edited the IL96 (22). Do you think is better or ... ?
http://imgproc.airliners.net/photos/air ... f07f61c237
Thanks for your opinion.
Harry
airkas1
Head Screener
Mon May 22, 2017 3:42 pm
Yeah, it should be ok.
HarryLi
Mon May 22, 2017 3:43 pm
That's great ! Thanks a lot kas!
HarryLi
Wed May 24, 2017 3:28 pm
Hello Kas,
Would u please help me have a look these 2 ?
http://imgproc.airliners.net/photos/air ... 10cd319411
http://imgproc.airliners.net/photos/air ... 22f329efd5
Thanks~
Harry
airkas1
Head Screener
Wed May 24, 2017 3:55 pm
The 737 looks passable.
The 767 is soft, oversharpened and hazed. I would let that one go.
HarryLi
Wed May 24, 2017 4:05 pm
Well~ maybe is time to let it go ... last time screener rejected me with haze too ~~~~
What about this ? The window shot ~ I posted here last time but screener rejected me with quality and screener recommended me that to use smaller size so i use 1200px instead of 1500px.
http://imgproc.airliners.net/photos/air ... 5c2c790536
Thank you for your valuable time !!! :)
Harry
HarryLi
Sat May 27, 2017 12:26 pm
Hi guys, i try another one of this : http://imgproc.airliners.net/photos/air ... c037d73fcb
Is it ok ?
Harry
HarryLi
Tue May 30, 2017 1:37 am
airkas1 wrote:
A343: Look ok.
A330: Looks ok.
A319: Looks ok.
Hello Kas, both of the night shot has screened. The A319 has accepted by screener but the oneworld A330 was rejected with OS & Noise but i don't think it has this issue. Is it worth appealing ? :confused:
Harry
len90
Tue May 30, 2017 2:47 am
Is it ok ?
Harry
To me it still looks like quality issues persist.
Len90
HarryLi
Tue May 30, 2017 3:49 am
len90 wrote:
Is it ok ?
Harry
:( what a pitty.
airkas1
Head Screener
Tue May 30, 2017 10:40 am
- The A330 is not OS for me, noisy isn't that bad.
- I would let the B767 go. Light is quite marginal and just not a super shot in total. I would wait for better circumstances to shoot it in.
- The wingview looks passable.
HarryLi
Tue May 30, 2017 10:48 am
Got it Kas, many thanks for you ! And i appealed that photo just now , waiting for the decision now.
Harry
HarryLi
Tue May 30, 2017 11:46 am
Hi, Kas
Sorry to disturb again. I edited some photos recently but some of them i am not pretty sure if they can be passable so would you please help me have a look ? Thank you for your valuable time !
http://imgproc.airliners.net/photos/air ... aa1c1c3afa (CUA B738)
http://imgproc.airliners.net/photos/air ... 99e15cc92f (CA B738)
http://imgproc.airliners.net/photos/air ... 4e682870e3 (UNI-TOP AB6 )
Best wishes,
Harry
HarryLi
Tue May 30, 2017 2:15 pm
Hi, Kas
Best wishes,
Harry
And here is one more :
http://imgproc.airliners.net/photos/air ... a2aac8b47c
HarryLi
Sun Jun 04, 2017 2:20 pm
:confused: Hi, Kas . The wingview was rejected by screener with Blurry only this reason. But i didn't see Blurry even the original photo i didn't see it .
I think this one can be passable. I appealed it just now.
HarryLi
Sun Jun 04, 2017 10:46 pm
I received the appeal decision just now. The HS still rejected me with Blurry and left a personal message. He said that : the background is blurry. :crying:
I really don't understand why it is not allowed. Is it now allow ?
And this is my second time to upload this one , last time the screener and HS told me that soft told me to use smaller size would be ok so i used 1200px and now become Blurry ? Background Blurry ?
HarryLi
Tue Jun 06, 2017 3:57 pm
HarryLi
Wed Jun 07, 2017 12:06 pm
airkas1
Head Screener
Wed Jun 07, 2017 5:32 pm
CUA: passable for me
CA: soft windowline, otherwise OK
UNI: not super, but passable for me
EK: bit on the bright side
Wingview: as long as the subject (a wing for example) is sharp, we generally don't reject for a blurry ground scene. Except when it just creates a messy photo and it looks ugly (I've had that happen to me before).
CUA: same photo as posted earlier...
CA: same photo as posted earlier...
CH: heathaze, oversharpened
SU: passable
Mahan: bit oversharpened
Dragonair: passable
CZ: passable
HarryLi
Thu Jun 08, 2017 2:52 am
SU: passable
Dragonair: passable
CZ: passable
Thank you for your reply Kas. You mean the EK is a little bit overexposed? And i wonder that is it worth uploading the wingview again ?
airkas1
Head Screener
Thu Jun 08, 2017 10:09 am
I would probably let the wingview go. And yes, the EK is slightly overexposed and I think it will look better when toned down a little.
  • 1
  • 3
  • 4
  • 5
  • 6
  • 7
  • 10
