vcruvinel
Support
Re: Opinion, Tips and Improvements
Thu Sep 14, 2017 3:02 am
jelpee wrote:
Re. the B727, needs a little more brightness (check right side of histogram) and IMO a touch of sharpening and some noise reduction in the shadow areas. Should be OK then.
Jehan
See if looks better now
vcruvinel
Support
Thu Sep 14, 2017 4:38 pm
Version 2 - Another Editing
airkas1
Head Screener
Thu Sep 14, 2017 5:26 pm
Still looks like a blurry original to me, which can't be fixed.
vcruvinel
Support
Thu Sep 14, 2017 5:35 pm
oh, ok. no problem. happens all the time. LOL.
another shot to prescreen
airkas1
Head Screener
Thu Sep 14, 2017 5:49 pm
The E550(?) looks nice and passable for me.
The B737 is a bit low in frame, cyan and soft. But all issues seem fixable.
vcruvinel
Support
Thu Sep 14, 2017 5:53 pm
airkas1, yes it's a Embraer EMB-550 (often know as Legacy 500 (IU-50)). I will upload now to the DB.
About the 737F I will do all corrections and upload again for approval.
many thanks as always
vcruvinel
Support
Thu Sep 14, 2017 6:44 pm
I have a doubt...This kind of shot can be acceptable?
vcruvinel
Support
Fri Sep 15, 2017 4:29 am
correct the cyan, put more sharpen and centralize the plane in the frame
airkas1
Head Screener
Fri Sep 15, 2017 6:19 am
The engine close-up will likely get rejected for motive, as the crop isn't that great.
The Sideral looks a bit underexposed still, there is room for extra brightness on the right side of the histogram. The moest right value to 240 or so. I also forgot to mention that it has a 'spot' in the sky in front of the tail. Better to remove that to avoid the dirty rejection. Sorry I missed that in the previous edit as well. Otherwise it looks ok to me.
vcruvinel
Support
Fri Sep 15, 2017 11:35 am
I will improve the brightness. I saw the spot, it's a bird. I will remove our little friend from there. Sharpness is ok?
airkas1
Head Screener
Fri Sep 15, 2017 11:49 am
vcruvinel wrote:
Sharpness is ok?
Yes.
vcruvinel
Support
Fri Sep 15, 2017 11:52 am
airkas1 wrote:
vcruvinel wrote:
Sharpness is ok?
Yes.
Ok, I will work in the other points you said. Many thanks
vcruvinel
Support
Fri Sep 15, 2017 6:13 pm
more brightness, dust spot removed. if need anything more just tell me
vcruvinel
Support
Mon Sep 18, 2017 2:35 pm
More shots to get the tem opinion
HarryLi
Screener In Training
Mon Sep 18, 2017 3:01 pm
VC-1 looks bit of OS to me.
Helicopter : You can give it more sharpen. It seems soft toward the whole body and the tail i think.And the tail also looks bit of Blurry to me maybe due to soft.
Tail shot looks better than another 2.
Harry
I am a Guangzhou Spotter. My photos are here : http://www.airliners.net/search?user=20 ... =viewCount :D
vcruvinel
Support
Mon Sep 18, 2017 4:17 pm
Harry
Harry, thanks for you feedback
This shot from Fab2101 is better?
About the Heli: I will sharp more
About the Tail Shots: It's ok from your point of view?
vcruvinel
Support
Mon Sep 18, 2017 9:05 pm
airkas1
Head Screener
Wed Sep 27, 2017 10:23 pm
FAB is blurry and yellow.
TAM needs some +10 contrast, some brightness from the right sid eof the histogram (value 240ish). Looks alright otherwise.
vcruvinel
Support
Thu Sep 28, 2017 1:37 am
I will forget about the FAB, no problem.
About the TAM, see the new image with the improvements you suggest: http://vcruvinel.com/fotos/PR-MYB/PR-MYB2.jpg
(I will use links from my hosting to prescreen now, my topic was getting to confusing, sorry!)
Thanks, airkas1!
HarryLi
Thu Sep 28, 2017 2:56 pm
Regarding to the TAM the latest one, the color seems weird. I assume that you took it with a glass in front of you. Adjusting the tone might be better i think.
vcruvinel
Support
Thu Sep 28, 2017 4:48 pm
Harry, many thanks for you feedback!
I think the colors seems kind of weird because the painting are fading (need to paint the plane again). There is no glass or other obstruction! When you say to adjust the tone, you say more constrast/saturation?
Thanks for you help and comments!
HarryLi
Fri Sep 29, 2017 3:21 pm
Hi,
I am not talking about the the plane's color is weird i mean the whole picture seems bit of green than normal i think. Especially the white part of the aircraft seems strange.And the saturation is ok i think. I did a quick editing for it here is :
You can compare it to yours.
:D
Harry
vcruvinel
Support
Mon Oct 02, 2017 11:28 am
HarryLi wrote:
Hi,
:D
Harry
Hi Harry,
Many thanks for the feedback and help! I saw the points you explain, and also aggree with you. The white seens a bit strange...I will compare my version and yours and improve the photo.
Thanks!!
vcruvinel
Support
Mon Oct 02, 2017 6:07 pm
Hey guys!
This kind of shot is acceptable? I got this before the sunrise...but it was a rainy day here.
http://www.vcruvinel.com/fotos/PR-SDM/PR-SDM1.jpg
It`s the original image I did not do any edition yet.
Thanks! :)
airkas1
Head Screener
Mon Oct 02, 2017 6:31 pm
That image is very blurry and will not make it.
vcruvinel
Support
Mon Oct 02, 2017 6:38 pm
Hey Kas, sorry. I uploaded the wrong version. Can you please see again this link?
Thanks!!
airkas1
Head Screener
Mon Oct 02, 2017 8:35 pm
That one is also blurry and soft, sorry.
vcruvinel
Support
Mon Oct 02, 2017 9:03 pm
Many thanks for the feedback as always! I will work in others shots and put to prescreen soon!
Thanks! :)
Degupukas
Wed Oct 04, 2017 3:44 pm
thanks
HarryLi
Wed Oct 04, 2017 4:30 pm
Sideral : seems blurry to me.
GOL+ : The contrast seems could be more i think and the front gear letters and REG in the body seem to be blurry i think.
LATAM A320 : The purple fringe of it is serious and obvious and some parts seem to be OS to me.
The last one : The whole photo seems Blurry especially the plane and the light stick. Besides, the color of it looks weird. I think is too red or magenta.The color issue should be easy to deal with.
Harry
airkas1
Head Screener
Wed Oct 04, 2017 4:35 pm
B727: slightly blurry, CCW and double with the closeup?
GOL: low contrast.
A320: cyan cast and oversharpened.
Overview: blurry, motive (left aircraft blocked), will not make it.
vcruvinel
Support
Wed Oct 04, 2017 6:27 pm
GOL: low contrast.
Hey Kas, thanks for the feedback. I will improve my photos and post again to prescreen.
And about the B727: This shot was taken in another day and angle. It's consider a double too?
vcruvinel
Support
Wed Oct 04, 2017 6:28 pm
Harry
Harry, many thanks for you reply! I will use you and Kas feedback to improve my shots.
airkas1
Head Screener
Wed Oct 04, 2017 9:35 pm
No, different day is not double.
vcruvinel
Support
Fri Oct 06, 2017 1:58 am
Hey Kas, Thanks for the feedback about the double rule.
Harry, thanks for the feedback too, I`m correcting the others shots to improve and practice more the concepts, principal about the B&W and RGB Histogram. Many Thanks.
I correct the constrast from the PR-VBM (GOL). It`s ok now?
http://vcruvinel.com/fotos/PR-VBM/PR-VBM2.jpg
HarryLi
Fri Oct 06, 2017 3:35 am
The contrast of this one seems better than before ( I think there is little bit space could be increased).But i think the sharpness is marginal :roll: You can wait more replys ! ;)
Harry
vcruvinel
Support
Sun Oct 08, 2017 6:48 pm
Harry
Hey Harry, thanks for the feedback!
About the sharpeness, you say the whole aircraft or only some points?
airkas1
Head Screener
Wed Oct 11, 2017 3:01 pm
Contrast is better. Sharpening is not an issue for me, but now that I look again it's a little bright.
vcruvinel
Support
Sat Oct 14, 2017 5:00 pm
Kas, I will take from the scratch again as I renew some aspects froms my workflow. I will ask more opinions soon with new editions.
Thank you!
vcruvinel
Support
Thu Oct 19, 2017 11:46 am
airkas1
Head Screener
Thu Oct 19, 2017 1:08 pm
The Eurowings could use a bit more contrast, but looks passable otherwise
GOL is a bit bright, but otherwise nice. The Avianca seems to suffer a bit from heathaze, as the whole aircraft has a sort of blurrish feeling to it.
vcruvinel
Support
Thu Oct 19, 2017 3:46 pm
Thanks for the feedback :) See the new versions:
Eurowings with more contrast: http://vcruvinel.com/fotos/D-ABZK/D-ABZK.jpg
GOL less brighter: http://vcruvinel.com/fotos/PR-GUQ/PR-GUQ2.jpg
Avianca with better resolution (it's appears to has some heat haze, but I think it's the heat from engines, tell me your opinion!): http://vcruvinel.com/fotos/PR-ONR/PR-ONR2.jpg
Thanks!!
vcruvinel
Support
Thu Oct 19, 2017 10:05 pm
HarryLi
Fri Oct 20, 2017 2:45 pm
Hello,
I have compared the Eurowings to the another one that you posted before. I didn't see any significant changes and i think it still needs some contrast.
GOL looks better than the last one.
Avianca still looks bit of Heat Haze i think especially the tail.
Not quiet sure , it looks a little bit Heat Haze to me.
Harry
vcruvinel
Support
Fri Oct 20, 2017 3:42 pm
HarryLi wrote:
Hello,
Harry
Hey Harry, thanks for the reply.
I will put more contrast in the Eurowings.
I will see again the Avianca and verify if this one has salvation LOL.
airkas1
Head Screener
Fri Oct 20, 2017 8:59 pm
I also don't see any visual difference with the Eurowings.
The GOL is better
The Avianca still looks soft/hazed at the back & tail.
The Passaredo looks soft and hazed. Sharpening it will likely lead to oversharpened parts.
vcruvinel
Support
Sun Oct 22, 2017 1:07 pm
airkas1, thanks for the reply. I will improve the points you and harry said but i will forget the ones that have HH.
can I have some feedback in this one?
http://vcruvinel.com/fotos/PR-AZA/PR-AZA.jpg
HarryLi
Sun Oct 22, 2017 1:49 pm
Hi,
Regarding to the Azul.
It seems heat haze for me. The top of the aircraft and the title also the wing show heat haze i think.Besides, this one has Halo problem i think especially the tail part. You can check it by using Equalize in PS on your own i think but without using it you can see it clearly too. OMP, i don't suggest to upload this one. You can wait more answers of course !
Harry
airkas1
Head Screener
Sun Oct 22, 2017 3:48 pm
It's hazed for me too and will most likely not make it, sorry.
