airkas1
Head Screener
Re: Feedback on pictures
Fri Oct 20, 2017 8:56 pm
KLM: blurry/soft front section, overexposed sky, kinda backlit but it could work (no guarantee), needs a tighter crop. Quality insufficient for such a large size.
Delta: Backlit, low in frame. This one will not make it due to lighting issues.
AA, blurry, soft, high in frame, right in frame, underexposed, Quality insufficient for such a large size, needs CCW rotation. This one will not make it.
lightningzap
Sun Oct 22, 2017 3:01 pm
What to do about quality insufficient for such a large size?
HarryLi
Screener
Sun Oct 22, 2017 3:12 pm
You can try to use smaller size.
I am a Guangzhou Spotter. My photos are here : http://www.airliners.net/search?user=20 ... =viewCount :D
lightningzap
Sun Oct 22, 2017 3:38 pm
So I shouldn't export at the original size?
airkas1
Head Screener
Sun Oct 22, 2017 3:44 pm
For example, your AA B787 image is 2048 x 1225px. That is way too big to upload, but more importanly, the quality is poor at that size. You will need to resize to a max of 1920, but I recommend 1200px wide to start with. Afterwards, you'll likely need to put it through Photoshop (or similar) to improve it.
lightningzap
Sun Oct 22, 2017 4:15 pm
putting it through photoshop just to be able to export in png?
airkas1
Head Screener
Sun Oct 22, 2017 5:11 pm
Eh, no. Putting it through photoshop to improve level, color, sharpening, contrast, brightness, etc. Then save as JPG.
lightningzap
Sun Oct 22, 2017 6:39 pm
So theres a benefit of using photoshop over lightroom for this kind of stuff?
airkas1
Head Screener
Sun Oct 22, 2017 7:35 pm
No, either is fine to use for post-processing.
lightningzap
Mon Oct 23, 2017 12:01 am
https://imgur.com/hagRRNG
this is the before and after.
vcruvinel
Support
Mon Oct 23, 2017 10:58 am
In my opinion needs more sharpening and constrast. Maybe it's a little overexposed...But's not too much.
Just my opinion, better wait some comments from the screeners.
Best! :)
Vinicius
airkas1
Head Screener
Mon Oct 23, 2017 11:25 am
Ah, so I see. But my previous points are still applicable.
lightningzap
Mon Oct 23, 2017 5:48 pm
What can I do about this blurriness which in the first and last pictures?
airkas1
Head Screener
Mon Oct 23, 2017 6:43 pm
Unfortunately nothing can be done to fix those to A.net standards. It will require a better original photo.
lightningzap
Mon Oct 23, 2017 8:30 pm
How to do that though?
lightningzap
Tue Oct 24, 2017 9:12 pm
Camera was very still as I was leaning my arms on the railing on the atc tower catwalk so and the plane was far enough away for the aperture so do I need to buy better equipment?
airkas1
Head Screener
Wed Oct 25, 2017 8:55 am
By going out again and taking new photos.
Well, I'm not sure what you're shooting with now, so can't say if you need better equipment. But it could be that you mis-timed tracking it, that the focus wasn't good, etc. Light also wasn't great either.
So I suggest going out, go somewhere where you have the sun behind you and where you don't have the planes too far away from you.
lightningzap
Wed Oct 25, 2017 10:45 pm
I'm using t7i with 70-300 IS USM, planes are 250 meters away and it was center point focus on the plane. Also nothing I can do about lighting from there in the morning.
Also most of the planes I shoot aren't doing regular service so I can't go reshoot them.
airkas1
Head Screener
Thu Oct 26, 2017 9:41 am
Unfortunately there isn't much to do about it then. With that light, any photo will have trouble making it on here. The fact that the aircraft aren't regulars is unfortunate, but nothing to do about that. either.
lightningzap
Thu Nov 02, 2017 1:36 am
apart from light what do about sharpness
airkas1
Head Screener
Thu Nov 02, 2017 6:01 pm
Try to get steadier hands (i.e. hold the camera more still) when tracking the aircraft in front of the lens and make sure your camera/lens have the correct focus. The KLM for example I think had the focus on the wings and aft fuselage. Result: the front fuselage is blurry.
jelpee
Screener
Fri Nov 03, 2017 12:59 pm
A good source of light on the aircraft and an acceptable shutter speed (based on the focal length of the lens) will minimize camera shake resulting in sharper images. Looks like your KLM and Delta aircraft are backlit and not ideal for showing a sharp image. Perhaps you need to either position yourself on the opposite side or wait for the sun to move behind your position.
Jehan
lightningzap
Sat Nov 04, 2017 6:21 am
Jehan
Camera want shaky though, it was resting in my knee, with 2 hands and face and the IS in lens. Is it the focus type? Everyone told me to use one point af.
jelpee
Screener
Sat Nov 04, 2017 1:37 pm
I use single point focus and it works well for me. Take some images of static aircraft with the light coming from behind you and check the results. It will also confirm if your body or lens may be contributing to the lack of sharpness.
Jehan
lightningzap
Sat Nov 04, 2017 11:01 pm
Jehan
Pictures where light was coming from behind me were even more soft in some cases. Is 70-300mm IS USM a really bad lens then?
HarryLi
Screener
Sun Nov 05, 2017 12:45 am
lightningzap wrote:
Jehan
I don't think the lens is so bad and as i knwo that Soft problem could be solved by editing which means adding sharpness so if you feel that the photos are soft you can add more sharpness to it. I used to use 55-250 when i use 400D and that lens provided wrose sharpness than yours and what i have now but some of them were accepted finally by my editing.
lightningzap
Sun Nov 05, 2017 4:00 am
HarryLi wrote:
lightningzap wrote:
Jehan
All of the pictures which I show have 100-150 sharpness added with masking.
darazarbaf
Mon Nov 27, 2017 6:16 pm
I had the Canon EF 70-300 IS USM for some time. Couldn’t get sharp photos for most of the time. Decided to change it and now I’m happy with the decision I made. You might consider changing it and buy a more expensive lens if you want to see better results.
Aviation spotter located in Tehran. You can find my photos here: http://www.airliners.net/user/darazarbaf/profile/photos
Users browsing this forum: Kaphias and 3 guests
