yousaf465
Pre-screening
Sat Dec 02, 2017 7:54 pm
https://www.dropbox.com/s/qbvoxwvngq25q ... 4.jpg?dl=0
Please comment on this photo for upload. any suggestions are welcome.
yousaf465
jelpee
Screener
Re: Pre-screening
Sat Dec 02, 2017 11:52 pm
The image has a yellow color cast and shows a lot of noise. It is also soft and the horizontal stabilizer is blurry. Regretfully, in its current form it will not make it. Probably not editable enough to offset the blurriness since you image is already at 1024 pixels on its long side. At smaller sizes, certain flaws such as blurriness are not visible as much as they are at larger sizes.
Jehan
yousaf465
Re: Pre-screening
Sun Dec 03, 2017 1:48 am
Jehan
Yellow color cast was the actual lighting at the airport, this is how I saw the image with Naked Eye. It can be fixed as it's a Raw file.
Blurry ? Camera was resting on stable platform, I used 10 sec timer, and aircraft wasn't moving.
yousaf465
len90
Re: Pre-screening
Sun Dec 03, 2017 5:24 am
I agree with Jehan. Remember there are multiple different types of blur that an image can have. There is blur from the image being out of focus. Depending on how the image was shot, f-stop, the depth of field of the image can ultimately suffer thus areas that are at a different focal length from the camera will show up as blurry/out of focus. Motion blur is something else which you would see from the camera being held in a hand etc. A stable platform is actually not as good as a tripod from my experience.
Sodium lights can cause a yellow/orange lighting. However, there is still seems to be more color cast.
Lastly, just out of curiosity what were the camera settings you used for this shot?
Len90
yousaf465
Re: Pre-screening
Thu Dec 14, 2017 1:17 pm
F14 10Sec ISo160
yousaf465
yousaf465
Re: Pre-screening
Thu Dec 14, 2017 1:24 pm
yousaf465
yousaf465
Re: Pre-screening
Thu Dec 14, 2017 2:31 pm
yousaf465
airkas1
Head Screener
Re: Pre-screening
Thu Dec 14, 2017 2:46 pm
The links are not working.
yousaf465
Re: Pre-screening
Mon Dec 18, 2017 9:45 am
links have been fixed. please advice.
yousaf465
vcruvinel
Support
Re: Pre-screening
Mon Dec 18, 2017 10:59 am
[ I'm not a A.net screener]
Hi! I think all of them need more sharpeness and contrast. The third is a bit HIF. But just my point of view. Hope I can help.
Best.
Vinicius
airkas1
Head Screener
Re: Pre-screening
Mon Dec 18, 2017 11:28 am
1) dust spot top of frame (above left side hor.stab.), quality seems a bit compressed (perhaps due to the hosting site). Image seems a bit soft.
2) soft, low contrast, high in frame.
3) soft, low contrast, high in frame, CCW.
yousaf465
Re: Pre-screening
Thu Dec 21, 2017 4:18 pm
yousaf465
yousaf465
Re: Pre-screening
Thu Dec 21, 2017 4:51 pm
Which one of these two is correct , the photo in post above or this one ?
yousaf465
yousaf465
Re: Pre-screening
Fri Dec 22, 2017 1:11 pm
Over-Sharpened ? any other issues ?
yousaf465
yousaf465
Re: Pre-screening
Fri Dec 22, 2017 2:31 pm
Fixed Sharpening, contrast and Frame
yousaf465
yousaf465
Re: Pre-screening
Fri Dec 22, 2017 3:31 pm
Image Another view
yousaf465
yousaf465
Re: Pre-screening
Sat Dec 23, 2017 6:47 pm
Is it ok for submission ?
yousaf465
yousaf465
Re: Pre-screening
Sun Dec 24, 2017 3:25 am
Guys please reply.
yousaf465
spompert
Re: Pre-screening
Sun Dec 24, 2017 9:27 am
Hi, the crop could be a bit tighter (leave less space around the edges of the plane, respecting the allowed ratios for uploading).
airkas1
Head Screener
Re: Pre-screening
Sun Dec 24, 2017 10:17 am
The derelict Cessna (?): second one is better in terms of color, but still blurry, noisy and quality.
First heli: not great, but perhaps passable
Second heli: not great, unbalanced crop.
Second photo of -BLH is better in terms of color, but still a bit blurry.
yousaf465
Re: Pre-screening
Sun Dec 24, 2017 5:58 pm
Thanks Spomspert and Airkas
Cessna 131k blurry ? Camera was resting on the ground with No wind around. Should I upload at higher resolution ?
For Mi17 58660 , I have retaken the picture will edit and reupload. Will try my luck with this version too.
Please comment on this 4R-MRE too. If quality is an issue I can upload at higher resolution.
yousaf465
yousaf465
Re: Pre-screening
Sun Dec 24, 2017 8:12 pm
Is it worth uploading at higher resolution ?
yousaf465
yousaf465
Re: Pre-screening
Mon Dec 25, 2017 3:41 pm
Please comment on Alouette photo .
yousaf465
airkas1
Head Screener
Re: Pre-screening
Mon Dec 25, 2017 5:39 pm
yousaf465 wrote:
Should I upload at higher resolution?
No, that will make it look worse. Perhaps the focus/DoF was incorrectly set. Either way it doesn't seem fixable for that photo.
A320: Blurry, low contrast, quality.
ALO3: seems passable
yousaf465
Re: Pre-screening
Wed Dec 27, 2017 3:36 pm
1/500s ƒ/8 ISO200 with center focus point right on belly of the aircraft.
yousaf465
HarryLi
Re: Pre-screening
Wed Dec 27, 2017 3:46 pm
This one looks soft to me and the some parts look bit of blurry to me mabye because of soft problem and i will resize it to 1200px or 1024px. Besides, it's bit of underexposed to me.
In addition, i am not sure that whether if you upload this one will reject for Similar or Double because you posted a similar Alouette here last time. I'll choose one of them to upload as the change of angle of them is slight. Last one seems better i think.
Harry
I am a Guangzhou Spotter. My photos are here : http://www.airliners.net/search?user=20 ... =viewCount :D
yousaf465
Re: Pre-screening
Wed Dec 27, 2017 4:11 pm
Harry
Thanks for the detailed advice.
Yes I will only upload one of these.
Which areas seems blurry ?
yousaf465
HarryLi
Re: Pre-screening
Wed Dec 27, 2017 4:24 pm
Harry
The "ARMY" looks so soft that i consider it looks blurry but it actually should be ok i think. I did a quick edit to it and i tried to resize it to a smaller size like 1200px or 1250px and then gave it more sharpness then it looks better. Besides, it also can have bit of more contrast too when you add some exposure to it.
However, to be honest , i will choose last one to upload as that one has better light condition and other aspects look better than this one too. As Kas commented before about that one it looks ok.
yousaf465
Re: Pre-screening
Wed Dec 27, 2017 4:38 pm
Thanks I will go with side shot as advised.
How should I improve this AH-1 Cobra Pak/US combination aircraft ?
yousaf465
HarryLi
Re: Pre-screening
Thu Dec 28, 2017 3:16 pm
Regarding to the AH-1, if you have another angle of it i would suggest you to change another angle as the light condition of this one is pretty bad i think.It looks bit of backlit i think.Besides, the contrast of it is definitely low to me.
Harry
yousaf465
Re: Pre-screening
Fri Jan 05, 2018 6:26 am
any issue with light or editing on this one ?
yousaf465
HarryLi
Re: Pre-screening
Sat Jan 06, 2018 11:38 am
The light condition is much better than the last one but it deserves more contrast i think. And ... not sure about others as the quality looks iffy to me.
Harry
airkas1
Head Screener
Re: Pre-screening
Sat Jan 06, 2018 12:02 pm
Low contrast and marginal quality.
yousaf465
Re: Pre-screening
Mon Jan 08, 2018 9:27 am
reworked. Please comment
yousaf465
yousaf465
Re: Pre-screening
Tue Jan 09, 2018 12:13 am
Image Should I upload this ?
yousaf465
jelpee
Screener
Re: Pre-screening
Tue Jan 09, 2018 2:28 am
Should be OK with a few edits:
1. Apply some clockwise rotation to level the horizon
2. A hint of brightness
3. There is a white speck located at about the middle of the cloud in front of the wing.
With the above, it would be acceptable for me.
Jehan
yousaf465
Re: Pre-screening
Wed Jan 10, 2018 12:05 pm
Jehan
I have edited as per advice.. Is it good enough now ?
yousaf465
yousaf465
Re: Pre-screening
Thu Jan 11, 2018 4:25 pm
good enough for A.net ?
yousaf465
airkas1
Head Screener
Re: Pre-screening
Thu Jan 11, 2018 4:34 pm
The first isn't great in terms of quality (and maybe also a bit overexposed). The second one has the sunlight illuminating dirty areas on the window, so for me that's a no-go.
yousaf465
Re: Pre-screening
Thu Jan 11, 2018 5:04 pm
Fixed the requested issues
yousaf465
yousaf465
Re: Pre-screening
Fri Jan 12, 2018 8:07 am
Please reply.
yousaf465
airkas1
Head Screener
Re: Pre-screening
Sun Jan 14, 2018 9:46 pm
Better, but still marginal quality.
yousaf465
Re: Pre-screening
Wed Jan 17, 2018 8:26 am
Can I upload this version ?
yousaf465
yousaf465
Re: Pre-screening
Thu Jan 25, 2018 10:12 am
Should I proceed ?
yousaf465
airkas1
Head Screener
Re: Pre-screening
Fri Jan 26, 2018 9:10 am
That's entirely up to you.
yousaf465
Re: Pre-screening
Fri Jan 26, 2018 9:17 am
Just in time
yousaf465
yousaf465
Re: Pre-screening
Fri Jan 26, 2018 11:53 am
Please comment for upload ?
yousaf465
HarryLi
Re: Pre-screening
Fri Jan 26, 2018 11:59 am
It looks oversharpened to me. Very obvious jaggys there. The upper right angle looks very dark,which makes me conside "Vignette" Reason.
airkas1
Head Screener
Re: Pre-screening
Fri Jan 26, 2018 12:00 pm
Oversharpened, noise, vignetting, quality.
