Tonymancs
Pre-screening
Sun Feb 25, 2018 1:25 am
Hello everybody! Learning from the last time, I would be glad for every feedback to help me fix any problems regarding photos before uploading (B737+An-12). Thank you for helping a newbie again :)
https://www.flickr.com/photos/62439242@ ... ed-public/
jelpee
Screener
Re: Pre-screening
Sun Feb 25, 2018 5:02 pm
My thoughts:
1. Transavia B737: Aircraft is high in the frame. With the B737 family, and especially from this angle, the tail plays a larger part in the composition.Otherwise it is acceptable.
2. AN 128: Acceptable for me.
Happy to help out!
Jehan
airkas1
Head Screener
Re: Pre-screening
Sun Feb 25, 2018 9:02 pm
Both are high in frame for me, but otherwise seem alright.
Tonymancs
Re: Pre-screening
Sun Feb 25, 2018 9:59 pm
So I should center it with the tail as the highest point and the lower line of the fuselage as the lowest point? Again thanks for feedback.
Kaphias
Re: Pre-screening
Sun Feb 25, 2018 10:56 pm
There's really no easy rule to use for vertical centering. The best way I can describe my process is that I want to find the visual center line as if your image was weighted and you were trying to balance the top against the bottom. The fuselage holds a lot of "weight" because of it's area and width, but the tail offsets this somewhat because of it's height. However, because the tail doesn't take up as much area as the fuselage, it doesn't completely offset the "weight" of the fuselage. So in the case of your 737 photo, I wouldn't center between the top of the tail and the bottom of the fuselage... I'd think about halfway up the tail, perhaps. I also take into account the colors (light vs. dark), textures, and importance/prominence of various things in the entirety of my photo... but it's an intuitive process for me. You'll develop your own system and an eye for what the screeners here are looking for over time.
jelpee
Screener
Re: Pre-screening
Mon Feb 26, 2018 1:26 am
Good explanation by Kaphias. Try to center based on visual "Center of Gravity". Even with that there's some individual perception as indicated by Kas' and my view on the the An. A lot also depends on the angle. If the tail dominates the image, then it plays a larger role. In the B737, there seems to a lot of blank/empty space below the aircraft which makes is HIF.
Jehan
Tonymancs
Re: Pre-screening
Mon Feb 26, 2018 8:35 am
I'll try to study the subject more and play with cropping again. Thank you all for the help :)
Tonymancs
Re: Pre-screening
Mon Mar 19, 2018 12:16 am
Greeting again. I'am trying to upload a new one and would like you to judge it. Thank you for any reminders.
Blurto
Re: Pre-screening
Mon Mar 19, 2018 6:43 am
I've found that if you look at a thumbnail view you can get a better idea of the composition.
Tonymancs
Re: Pre-screening
Mon Mar 19, 2018 9:47 am
Thanks for feedback. Framed to 16:9 now.
airkas1
Head Screener
Re: Pre-screening
Mon Mar 19, 2018 10:17 am
In the 16:9 crop the aircraft is high in frame. Can't really judge the quality, as Flickr doesn't always display photos well.
Tonymancs
Re: Pre-screening
Mon Mar 19, 2018 11:05 am
Thanks for your advice, I repositioned the aircraft. In Flickr you can download the original file in full resolution.
https://www.flickr.com/photos/62439242@N08/40003450965/
vcruvinel
Support
Re: Pre-screening
Mon Mar 19, 2018 11:45 am
Hi.
For me this photo lacks some contrast.
Best,
Vinicius Cruvinel
Tonymancs
Re: Pre-screening
Mon Mar 19, 2018 7:41 pm
Thank you for your reminder. I pumped both contrast and saturation.
Tonymancs
Re: Pre-screening
Tue Mar 27, 2018 2:45 pm
Thank you for accepting the photo. Now I have this night shot of A345 that I don't know if WB, brightness and overall quality gonna be enough. All advice are welcome.
http://imgproc.airliners.net/photos/airliners/5/9/5/4919595.jpg?v=v40661753fad
https://www.flickr.com/photos/62439242@N08/39241951760/in/dateposted-public/
airkas1
Head Screener
Re: Pre-screening
Tue Mar 27, 2018 3:24 pm
It's got a yellow/green cast and needs more blacks and contrast. Should be easy to solve if you're shooting RAW. Also a bit soft.
Tonymancs
Re: Pre-screening
Wed Mar 28, 2018 9:45 pm
HarryLi
Screener
Re: Pre-screening
Sun Apr 01, 2018 5:21 am
Hi,
The colour looks ok now but it still can have more contrast i think.Besides, it also looks slight soft i think.
I did a quick editing which i think would be better by adjusting the contrast (Did not adjust sharpness and others) :
Harry
I am a Guangzhou Spotter. My photos are here : http://www.airliners.net/search?user=20 ... =viewCount :D
Tonymancs
Re: Pre-screening
Fri Apr 13, 2018 9:52 pm
Hi, thank you for your advice, but it seems engines are hopelessly soft, I fear adding more sharpness will the rest oversharpened. Anyway I got this shot from EDDK and a night shot:
http://imgproc.airliners.net/photos/airliners/1/8/2/4947281.jpg?v=v4367c3bee45
http://imgproc.airliners.net/photos/airliners/9/7/2/4947279.jpg?v=v416446d9565
HarryLi
Screener
Re: Pre-screening
Sun Apr 15, 2018 8:57 am
Czech Airliners : Looks overexposed to me and the colour looks weird kind of cyan i think.Also looks slight bllurry and OS to me.
Star Air: Looks low contrast to me.Also bit of underexposed i think. Sharpness looks iffy to me.
airkas1
Head Screener
Re: Pre-screening
Sun Apr 15, 2018 9:33 am
ATR: blurry, OS, overexposed, green
767: flat, too much noise reduction
Tonymancs
Re: Pre-screening
Mon Apr 16, 2018 8:16 pm
WB adjustment option of my editor is very limited. I'll try to fine tune it latter. Thank you for your advice.
Users browsing this forum: No registered users and 4 guests
