Waelalqutub
Pre Screening Please
Thu Aug 16, 2018 5:43 pm
Hello All,
Could I please get a pre-screening for this shot.
Thanks so much in advance
Wael.
dutchspotter1
Re: Pre Screening Please
Thu Aug 16, 2018 7:22 pm
A little oversharped; not sure whether it is level or if it needs some CCW rotation.
NO URLS in signature
Waelalqutub
Thu Aug 16, 2018 8:00 pm
Thank you for your pre-screening feedback.
However, I'm bit confused into what object to select as a CCW rotation, I personally went for the right side of the wall as its straight there also the blue stripes running down from the blue shelter on the left of the helicopter.
Shall I make the roof of the building as the main reference for CCW rotation?
Wael.
jelpee
Screener
Thu Aug 16, 2018 9:47 pm
Image has a yellow color cast for me. Level and sharpening is passable. FYI, I use either a vertical in the center of the frame. If that's not available, I select a distant horizontal reference.
Jehan
Waelalqutub
Fri Aug 17, 2018 12:21 am
Jehan
Hello Jehan,
Thank you for taking time in looking at my photo,
I have fixed the yellow cast :spin:
Is this better?
airkas1
Head Screener
Fri Aug 17, 2018 8:32 am
Hi Wael,
Second image looks fine to me.
Waelalqutub
Fri Aug 17, 2018 8:46 am
airkas1 wrote:
Hi Wael,
Hello Kas,
Thank you for taking time in looking at this,
I have uploaded it now.
Wael.
Waelalqutub
Fri Aug 24, 2018 6:15 pm
Good Evening all,
Could I please get these pre-screened,
1.Qantas 787 https://imgproc.airliners.net/photos/ai ... d4805fb7bf
2.Britsh Airways 773 https://imgproc.airliners.net/photos/ai ... 0271504de1
3.MEA A330 https://imgproc.airliners.net/photos/ai ... 7a906ba296
4.British Airways A320 Neo https://imgproc.airliners.net/photos/ai ... d29fe12542
Thanks in Advance.
Wael
jelpee
Screener
Fri Aug 24, 2018 11:39 pm
Hi Wael:
My comments below:
1. Qantas 787: Nose is blurry (soft at best). Image also needs more contrast
2. BA 777: Right side of the image has soft elements (engines) and blurred elements (main gear)
3. MEA A330: A littel more contrast and should be acceptable.
4. BA A320:Passable for me.
Jehan
Waelalqutub
Sat Aug 25, 2018 12:43 am
jelpee wrote:
Hi Wael:
My comments below:
Jehan
Hello Jehan,Thanks for your time in pre screening my pictures
I have fixed and applied your suggestion with the BA A320 left in the Screening Queue since its possible :)
here are my 3 pictures with fixes hopefully they are good to go now.
1.Qantas 787 https://imgproc.airliners.net/photos/ai ... 4e369d3d5a
2. BA 777 https://imgproc.airliners.net/photos/ai ... fb36bc2e92
3. MEA A330 https://imgproc.airliners.net/photos/ai ... c3a7c28360
Thanks once again
Wael.
jelpee
Screener
Sun Aug 26, 2018 12:17 am
Hi Wael:
1. Qantas 787: contrast looks good, but that nose still is showing blur. Not sure it will pass.
2.BA 777: I still see a lot of blur in the engine, gear and horizontal stabilizer. Again, doubtful it will make it.
3. MEA A330: Should be acceptable.
As for 1 & 2, perhaps you have some other frames that have less blur.
Jehan
Waelalqutub
Sun Aug 26, 2018 5:06 pm
jelpee wrote:
Hi Wael:
Jehan
Hi Jehan Thanks for that,
tell me what do you think about the latest fixes?
1. BA 777 https://imgproc.airliners.net/photos/ai ... 0f5801634a
2. Qantas 787 https://imgproc.airliners.net/photos/ai ... 91ed995169
Wael.
airkas1
Head Screener
Sun Aug 26, 2018 6:02 pm
Qantas looks nice, BA could use a bit more sharpening,
Waelalqutub
Sun Aug 26, 2018 7:40 pm
Hello Kas thanks for that :) I'm really learning a lot from your tips and advice
really appreciate that allot.
Added more sharpening I hope its good to go now
https://imgproc.airliners.net/photos/ai ... b0ee3e6629
Miguel1982
Head Screener
Sun Aug 26, 2018 8:57 pm
Can't speak for Kas, but for me it looks perfeclty good now.
Waelalqutub
Sun Aug 26, 2018 10:38 pm
Miguel1982 wrote:
Can't speak for Kas, but for me, it looks perfectly good now.
Hello, Miguel, cheers for the heads up :spin:
Waelalqutub
Fri Aug 31, 2018 12:09 am
airkas1
Head Screener
Fri Aug 31, 2018 9:11 am
Both look alright to me.
Waelalqutub
Fri Aug 31, 2018 6:04 pm
i was Spot on this time then :biggrin: :bigthumbsup:
Cheers Kas.
Waelalqutub
Wed Sep 12, 2018 9:45 am
dutchspotter1
Wed Sep 12, 2018 8:17 pm
Qantas and Eurowings: yes colourful special
BA 744: engines look blurry, don't think the quality is good enough
G-EUPH looks blurry
Others look OK to me.
Waelalqutub
Wed Sep 12, 2018 9:17 pm
G-EUPH looks blurry
Thanks so much for the pre-screen that's kind of you
I would wait to see the final decision by a screener or head screener for confirmation
thanks once again.
airkas1
Head Screener
Thu Sep 13, 2018 10:23 am
G-EUPH looks blurry
I agree with this, but the Delta A330 has halos in the corner of the left wing/top fuselage.
I saw some of these photo (QF 787/AC MAX) in the live editing session you did, although I only caught a glimpse of it since I was at work. A very nice and interesting idea, but you seem to put a whole lot of editing into 1 photo.
Waelalqutub
Thu Sep 13, 2018 10:39 am
G-EUPH looks blurry
Hello Kas, thanks for that .. I will surely try to fix the delta
as for the editing honestly, this is the only method I have learned to use on photoshop..
I would love to know if there is a quick and easier way to edit using photoshop as this could save me more time etc
as for the delta with halos .. is there a way to get rid of them?
many thanks once again and have a great day.
Waelalqutub
Sat Sep 15, 2018 10:51 pm
Hello all, Could I please get these pre screened,
Thanks in advance.
Jet Airways >> https://imgproc.airliners.net/photos/ai ... 2c57adc1d3
Air Canada Max >> https://imgproc.airliners.net/photos/ai ... 04c5386a4f
Britsh Airways >> https://imgproc.airliners.net/photos/ai ... 18cc5e1d32
P.S do i have to set the (Dusk Dawn Night) Option for all three ?
airkas1
Head Screener
Fri Sep 21, 2018 1:29 pm
The 747 shows a significant color difference of the main sky and the sky between the flaps. (orange vs yellow). So I'd give you an editing rejection for that.
The MAX looks nice, although the sky has some circular banding. Would personally say passable.
The B777 is passable for me.
Dusk/dawn/night is only applicable if the sun is still below the horizon. Definitely not the case for the MAX and 747, for the 777 I don't know.
Waelalqutub
Fri Sep 21, 2018 3:35 pm
Kas thanks for that, I guess I will have to leave out the 747 for now till I can re-edit and re-upload it
I will leave the Max and 777 the Queue
Thanks again.
fsx98
Thu Oct 11, 2018 11:36 pm
I'm not very good of a screener, but I'm going to take a guess at those:
Turkish 737 MAX: blurry/soft, borderline underexposed?
Turkish retro: looks quite passable
Gulf Neo: looks passable
MEA: looks passable
ULS Cargo: looks passable
A330 Troy THY: needs CCW rotation
Tunisair A330: same as A330 Troy THY
Royal Maroc 767: could use a little CCW rotation
Emirates 777: low in frame?
Singapore: needs CW rotation
Air Algeria: could use a little CCW rotation
Iraqi B744: slightly low in frame
Kuwait: low in frame, needs CCW rotation
Etihad 787: slightly low in frame; needs CW rotation
Bahrain Royal: slightly low in frame
These opinions are the best of my ability; I will have other screeners better decide on these photos
Aviation junkie + computer expert!
Waelalqutub
Sat Oct 13, 2018 10:13 am
MEA: looks passable
Hello Thanks for your pre screen much appreciated
JakTrax
Tue Oct 16, 2018 7:39 pm
Generally in agreement with fsx98 re most of them but definitely do not agree with the 'low in frame' opinions - they all look okay to me and could even stand being a bit lower.
fsx98
Tue Oct 16, 2018 8:37 pm
One reason why I gave "low in frame" is because although there are planes in the subject on some photos, I'm much more concerned about the open spaces above the subject matter in some.
As I have said in the earlier post, I'm not good in screening photos in this kind of complexity, as I usually take photos of aircraft with no other aircraft in the background.
Waelalqutub
Sat Feb 09, 2019 7:18 pm
Hello Everyone,
today I have received some rejections on my uploaded pictures in which to me seemed fine and nothing wrong with them and was wondering if i should appeal most of them or not.
would appreciate your feedbacks
Thanks.
1.https://imgproc.airliners.net/photos/ai ... 2878a4821b (Low Contrast)
Although the clouds in the background were dark naturally without editing adding contrast would make the picture underexposed or shall I just add more contrast to it?
2. https://imgproc.airliners.net/photos/ai ... 2216990970 (Common & Soft)
3. https://imgproc.airliners.net/photos/ai ... 74923feca3 (Soft - Underexposed)
4. https://imgproc.airliners.net/photos/ai ... 88b19392ab ( Low Contrast)
5. https://imgproc.airliners.net/photos/ai ... b5ded03fac (Underexposed)
6. https://imgproc.airliners.net/photos/ai ... 0bd29cc069 (Soft Vignetting)
7. https://imgproc.airliners.net/photos/ai ... e1963ed406 (Under Underexposed)
airkas1
Head Screener
Sun Feb 10, 2019 12:46 pm
HI Wael,
G-VINE: could use a bit more contrast, but passable as-is.
CS-TTA: needs a bit more sharpening. Should be fine after.
G-VKSS: agree. Looks like the sun diseappeared just at that moment, making the airrcaft look darker.
Air Canada: looks like it could use some +10-15 contrast.
UA: +0.20ish exposure and +15 contrast (ballpark figures).
G-RAES: agree on soft, don't see vignetting.
VT-ANI: looks passable
Waelalqutub
Sun Feb 10, 2019 7:17 pm
airkas1 wrote:
HI Wael,
Hi Kas,
Thanks for your time in looking this up for me :bouncy:
will make the adjustments as required & re upload
Waelalqutub
Sun Feb 10, 2019 10:15 pm
Could i please get this pre screened
https://imgproc.airliners.net/photos/ai ... d461b65deb
does it look like it's over sharpened & also is 1100 pix ok or shall I reduce it to 1024px
Waelalqutub
Sun Feb 10, 2019 10:27 pm
If it's over sharpened would a blur tool help on PS if so what opacity would you recommend
Thanks again
Wael.
airkas1
Head Screener
Mon Feb 11, 2019 12:10 pm
The A350 looks alright.
jelpee
Screener
Mon Feb 11, 2019 6:47 pm
A "Yes" for me as well.
Jehan
Waelalqutub
Mon Feb 11, 2019 8:42 pm
Thanks, Gentlemen I will leave it in the queue then
Users browsing this forum: Google Adsense [Bot], Runway28L and 7 guests
