Tomskii
Pre-Screening (Tomskii)
Mon Feb 20, 2012 3:47 pm
Hey guys,
went out for spotting today and here's my first pic. I'm lets say fairly new to this when you compare me to others on here so I'm looking for valuable feedback on how to improve my aircraft photography and getting my images on Airliners.net
I think that this picture: http://www.airliners.net/ufview.file?id=145937&filename=phpXQhIpv.jpeg might need a tad sharpening but I'm not sure as I'm not working on my Photoshop pc but on my work pc.
Thanks for helping me out in advance!
Tom
Nikon D90 + Nikkor f4.5-5.6 18-105mm + Tamron f4-5.6 70-300mm
dazbo5
RE: Pre-Screening (Tomskii)
Mon Feb 20, 2012 4:04 pm
Quoting Tomskii (Thread starter):
Hi Tom,
Composition looks fine although i'd probably crop a little more from the left of the frame to even the amount of blue sky left and right of the aircraft. The front of the aircraft is a little blurry and even with more sharpenig, it's unlikely you'll able to recover that one I'm afraid. This is a common aircraft with lots of photos in the database so standards are a little higher than normal. What aperture / shutter speed did you use? I've not seen the histogram, but the contrast looks like it needs increasing a little too. Other than that, it's not a bad try.
Darren
Tomskii
Mon Feb 20, 2012 4:24 pm
Hi Darren,
Thanks for the info! I will be uploading more pics soon. As for the histogram and such:
Program (Aperture priority) A
Aperture: f8
Shutter Speed: 1/320s so it's a bit on the slow side, but that's because I've overexposed the pic a bit to keep the noise to a minimum.
Histogram: http://www.airliners.net/aviation-photos/misc/uf/145937/phpQB1nxb.jpeg
EDIT: What do you think about this one? Think my shutter speed might have been a tad too slow as well but I prefer hearing it from someone who has 'the eye'. It seems maybe a tad oversharpened to me but again I might be wrong!
http://www.airliners.net/uf/145937/phpTwDLf9.jpeg
[Edited 2012-02-20 08:39:37]
EDIT2: Or this one?
http://www.airliners.net/uf/145937/phpZqR68K.jpeg
[Edited 2012-02-20 08:48:34]
dazbo5
Mon Feb 20, 2012 4:43 pm
Maybe that's why the front of the aircraft is a little blurry compared to the rest of the frame. There's no problem in using ISO 200, most dSLR's produce little noise at ISO 200 to give you a little more shutter speed if needed. I regularly use ISO 200 in the winter months when the light isn't as strong so don't worry about increasing it. The histogram confirms the contrast I mentioned above.
Darren
dlowwa
Mon Feb 20, 2012 4:48 pm
First one is blurry and flat; second one is better, but too high in the frame.
Tomskii
Mon Feb 20, 2012 4:51 pm
Quoting dazbo5 (Reply 3):
Thanks darren,
I'm going out thursday morning again for spotting at BRU so. As for know please look at the 2 foto's in the editted msg above. Thanks again for all your help!
Tom
dlowwa
Mon Feb 20, 2012 5:21 pm
Quoting Tomskii (Reply 5):
It is soft. You might also want to convert the colorspace for your images to sRGB before you upload, as that's how they will be displayed on the web/when they are screened. Otherwise you are going to be seeing a difference in the colors between what you are working on, and what you upload.
Tomskii
Mon Feb 20, 2012 5:33 pm
It should already be set to sRGB, as for the 2nd pic. I suppose I should crop until the space below the plane equals the space above.
dlowwa
Mon Feb 20, 2012 6:34 pm
Quoting Tomskii (Reply 7):
It is not. It is currently set to Adobe RGB, and when opening the file in Photoshop, the colors are quite different from how they are displayed in the browser.
Tomskii
Tue Feb 21, 2012 11:33 am
Allrighty, i'll make sure to change that in photoshop then. As for the picture the flat one was the SN airbus Insuppose and the second soft one is the JetairFly right?
Tomskii
Wed Feb 22, 2012 10:03 am
What about this? It's the JetairFly again but recropped it and sharpened it. It is also in sRGB 16-bit. I feel like I might have oversharpened it, or maybe I'm just wrong. I used a guideline to put the plane in the middle but I still feel like (might be wrong again) that it's slightly too high in frame.
http://dl.dropbox.com/u/33281487/DSC_0015.jpg
Thanks for the help,
Tom
dazbo5
Wed Feb 22, 2012 12:11 pm
Quoting Tomskii (Reply 10):
It is a little oversharp and too high in the frame.
Darren
Tomskii
Wed Feb 22, 2012 2:39 pm
Sounds a bit dumb probably but how much should I get the airplane down in the picture. Seems I have some issues distinguishing the right ratio between upper and lower part of the plane at that angle.
dlowwa
Wed Feb 22, 2012 5:57 pm
Sharpening should be ok, but it is slightly high.
Quoting Tomskii (Reply 12):
It's not an exact science, but there are two things that can help: 1) try looking at the thumbnail version to get an idea of the overall centering, and 2) don't forget to consider the tail fin, as it is also part of the aircraft.
Tomskii
Wed Feb 22, 2012 6:32 pm
Quoting dlowwa (Reply 13):
That's where I go wrong I guess: the tail. As for the sharpening: you would bring it down just slightly if I understand you well?
Tom
dlowwa
Wed Feb 22, 2012 11:01 pm
Sharpening looks ok overall, like I said. I can only see a few jaggies on the flaps.
Tomskii
Thu Feb 23, 2012 12:20 pm
Quoting dlowwa (Reply 15):
Jep noticed that too. So if I just bring the pic a bit down and upload it to the queue I should be ok right?
EDIT: Wasn't exactly what you'd call nice weather today but hey. Went to the BRU General Aviation area and some Italian diplomatic just arrived in his D'assault Falcon. What do you think?
http://dl.dropbox.com/u/33281487/DSC_0113.jpg
[Edited 2012-02-23 04:59:15]
dlowwa
Thu Feb 23, 2012 6:20 pm
Unlevel and very poor contrast I'm afraid.
Tomskii
Thu Feb 23, 2012 6:33 pm
Both things can be arranged, will post re-edited tomorrow.
Tomskii
Fri Feb 24, 2012 1:38 pm
How's this? I did a small rotate on the pic CW as I thought the pic was not level (going down) from right to left. Secondly adjusted contrast.
http://dl.dropbox.com/u/33281487/DSC_0113%28re-edit%29.jpg
EDIT: Might be a bit low in frame now though, or is it just me?
[Edited 2012-02-24 05:38:59]
Tomskii
Fri Feb 24, 2012 2:49 pm
And I re-edited OO-JAS the jetairfly 737:
Is this better or did I put it too low in frame now? How's the sharpening?
http://dl.dropbox.com/u/33281487/DSC_0015%282%29.jpg
dlowwa
Fri Feb 24, 2012 11:57 pm
Quoting Tomskii (Reply 19):
How's this?
Still needs a tiny bit of cw rotation, and contrast is still not great, though I don't think you'll be able to do much more to improve it.
Quoting Tomskii (Reply 20):
Maybe a touch low, and color a bit strong, but might be passable. Sharpening should be fine.
Tomskii
Sat Feb 25, 2012 12:03 am
I'll get the colors down a bit and then see how it goes in the queue, do you think it stands a chance?
dlowwa
Sat Feb 25, 2012 3:52 am
Quoting Tomskii (Reply 22):
With minor corrections, yes.
Tomskii
Sat Feb 25, 2012 9:34 am
Hi again Dana,
Brought the saturation of the colors down a bit and reworked from the original to crop again. This time I lowered it a bit in comparison to the first edit, but it is higher than the second edit.
http://dl.dropbox.com/u/33281487/DSC_0015%283%29.jpg
dlowwa
Sat Feb 25, 2012 11:11 pm
Color still looks a bit off, but might be worth a try as is.
Tomskii
Sun Feb 26, 2012 10:08 am
Well to me the colors are quite right as I see those planes regularly, but I suppose you mean the sky.
Once again thanks for all help, pic has been uploaded,
Tom
Tomskii
Sun Mar 04, 2012 6:48 pm
Dana again thanks for all your help, has paid off! First acceptance on a.net
Tomskii
Sat Mar 10, 2012 11:02 am
2 more pics from today. Tell me what you think. 1st one has received 1° of CW. Second one I wasn't sure.
http://dl.dropbox.com/u/33281487/DSC_0003.jpg
Not sure if it needs a bit more lighting or not.
http://dl.dropbox.com/u/33281487/DSC_0013.jpg
dlowwa
Sat Mar 10, 2012 11:11 am
Both have very poor (low) contrast. The LH also seems a bit blurry.
Tomskii
Sat Mar 10, 2012 11:30 am
Quoting dlowwa (Reply 29):
Mmm weird I would've thought you would've said that about the SN one and not the LH one. Anyways I'll give the contrast a boost of the first one.
http://dl.dropbox.com/u/33281487/DSC_0003%282%29.jpg How's this?
http://dl.dropbox.com/u/33281487/DSC_0013%282%29.jpg
[Edited 2012-03-10 04:29:02]
dlowwa
Sat Mar 10, 2012 7:58 pm
I can see you've increased the contrast a lot on both, but to be honest because the light was pretty terrible to begin with, they only look a little bit better. You can try adding more contrast, but the benefit won't be that significant. Better to wait for nicer conditions next time.
Tomskii
Sat Mar 10, 2012 8:30 pm
Quoting dlowwa (Reply 31):
Conditions indeed where sh*t, so if I understand you well you think it won't have any big effect if I work on the contrast anymore due to the poor light.
Tomskii
Wed Mar 14, 2012 5:53 pm
Picture from today (sun was setting) so I don't know if the orangy cast is an issue (as it's the normal lighting of the sun on the plane at this time of the day. Secondly I didn't exactly know how to crop a cockpit picture properly so feel free to give me advice on that  !
http://dl.dropbox.com/u/33281487/DSC_0044.jpg
Tomskii
Wed Mar 14, 2012 7:05 pm
And this one:
http://dl.dropbox.com/u/33281487/DSC_0025.jpg
dlowwa
Wed Mar 14, 2012 9:39 pm
Quoting Tomskii (Reply 34):
And this one:
Dark, and really poor/unmotivated crop.
Tomskii
Wed Mar 14, 2012 9:51 pm
And the first one? How would you crop it? Exclude the engine and just use the nose till the fwd door?
dlowwa
Wed Mar 14, 2012 9:59 pm
Quoting Tomskii (Reply 36):
And the first one?
Crop is better, but also a bit dark.
Pretty much any way other than what you did. Why did you crop it like that? Any specific reason, or was that simply what came out of the camera? Take a look through the database at previously accepted images to get an idea of what kind of crop is acceptable. That you can't find any similar to yours would be a good hint that such a crop wouldn't be acceptable.
Tomskii
Wed Mar 14, 2012 10:05 pm
So if I brighten the LX one up a bit, crop should be ok? Anyways I'll take a look at the db to have an idea how to crop it.
Tomskii
Thu Mar 15, 2012 4:25 pm
How's this now Dana? http://dl.dropbox.com/u/33281487/DSC_0044%282%29.jpg
EDIT: I suppose this one will not be able to make it because of quality/oversharpening? Or am I wrong?
http://dl.dropbox.com/u/33281487/DSC_0002.jpg
[Edited 2012-03-15 09:56:24]
EDIT2: Not sure about the cropping here and I suppose it might be a bit dark as well? http://dl.dropbox.com/u/33281487/DSC_0040.jpg
[Edited 2012-03-15 10:24:15]
Tomskii
Thu Mar 15, 2012 8:07 pm
And another one: I suppose (after looking up some images on Airliners.net) that this crop isn't good for Airliners.net either? Just want the confirmation  http://dl.dropbox.com/u/33281487/DSC_0007.jpg
Also please look at the pictures above, thanks for your help Dana!
dlowwa
Thu Mar 15, 2012 9:58 pm
Quoting Tomskii (Reply 39):
Should have a pretty good chance.
Maybe a bit os, but bigger problem is the harsh contrast.
EDIT2
Looks ok
Quoting Tomskii (Reply 40):
Better than the TAP, but if you want to be really safe, try to avoid cutting the engine.
Tomskii
Thu Mar 15, 2012 10:21 pm
Quoting dlowwa (Reply 41):
Not sure what you mean by os?   I've brought the contrast down a bit:
http://dl.dropbox.com/u/33281487/DSC_0002%282%29.jpg
dlowwa
Thu Mar 15, 2012 11:15 pm
Quoting Tomskii (Reply 42):
os = Over Sharpened.
Slight yellow tint, but otherwise looks passable.
Tomskii
Fri Mar 16, 2012 3:32 pm
Better? http://dl.dropbox.com/u/33281487/DSC_0002%283%29.jpg
dlowwa
Fri Mar 16, 2012 6:01 pm
Quoting Tomskii (Reply 44):
Better?
Should have a good chance.
Tomskii
Fri Mar 23, 2012 6:10 pm
The LX has been rejected, because I've left too much space on the top of the plane. Oh well, just a small re-edit and done
Tomskii
Wed Mar 28, 2012 4:47 pm
What do you think about these:
http://dl.dropbox.com/u/33281487/DSC_0021.jpg
http://dl.dropbox.com/u/33281487/DSC_0019.jpg
Not sure about cropping on the last one.
EDIT:
Suppose this one is too high in frame?
http://dl.dropbox.com/u/33281487/DSC_0027.jpg
[Edited 2012-03-28 09:54:49]
dlowwa
Wed Mar 28, 2012 6:02 pm
All three are a little soft and flat, but otherwise ok. Third one is a little low, but should be passable. It also has some dust spots.
Tomskii
Wed Mar 28, 2012 6:53 pm
Quoting dlowwa (Reply 48):
So a bit more contrast I suppose. As for the dust spots, only visible on the third?
http://dl.dropbox.com/u/33281487/DSC_0021%282%29.jpg
http://dl.dropbox.com/u/33281487/DSC_0019%282%29.jpg
[Edited 2012-03-28 12:03:47]
